New tires on old trailer
   / New tires on old trailer #1
ThirdMan
Saint Charles, MO
LS MT125
We just bought a used two horse strait in (title says 1974) with two axles. This is my first trailer, but my wife has hauled horses in the past. The previous owner has replaced the floor, lights, sanded and painted it. They got a third horse and needed to upgrade. The tires need to be replaced as the sidewalls are showing cracking and the spare is blown out. The current tires are P215/75R15. Reading around I should be putting ST tires on it, but I am not sure which size (as 215/75R15 is not a a standard size in ST). Should I be putting on ST225/75R/15? I was thinking of just heading over to a tire place or Walmart and buying a set at $50 a tire for them to put on.
   / New tires on old trailer #2
I seem to read about many people on TBN replacing ST tires with LT.
Bruce
   / New tires on old trailer #3
Bruce
I'm not sure what options there are in 15" Lt with a decent load rating. I ran into this on my toyhauler and wound up getting load range E trailer tires for about $100 each.
   / New tires on old trailer #4
If you have the clearance the 225 will work, otherwise you can go down to a 205. I really like the Gladiator QR25 tires, just put a set on my equipment trailer and have another set on my dump trailer. Really impressed with them, especially for the money. I got mine off ebay.
They have the st225/75r15 in C through E range.
   / New tires on old trailer #5
Regardless of which you buy look at the load rating on the side of the tire. Add up the weight of your trailor, horses, saddles gear, water, and other cargo and then buy a heavier duty tire. Tire issues hauling some boxes or boards is one thing. Tire issues loaded with horses is a major issue.
Load range E is about all I buy anymore. Less side wall issues and resulting trailor ride issues.
With 7 trailors, livestock, goosenecks, utility, box, and a little but heavy welding trailor I have learned its cheaper and safer to buy a higher load rating tire. Horse trailors are subject to hot weather and pavement, gravel roads, trail access paths, pastures and other conditions that many trailors never see.
   / New tires on old trailer #6
With more than one axle light truck tires don’t have the sidewall strength to allow turning with a full load.
My life has been changed since I learned why there are tires specifically for trailers.
Growing up I understood that trailers are where old truck tires get a new life and go to die. Still trying to convince my father otherwise.
   / New tires on old trailer #7
I'd definitely go with an ST tire, as mentioned, LT tires are too stiff in the sidewalls to allow for a tight turn. There's been a lot of good reviews in the Goodyear Endurance with a 2830 load rating.
That's the tire I plan on putting on my 5th wheel camper next year
Thanks for the suggestions about ST tires. Looking at load ratings 4 tires on a small two horse will easily be sufficient at D or E. Thank you for the brand suggestions, those are in the price I was budgeting for.
   / New tires on old trailer #10
Lol. Pretty much the same here.
Hay Spear for Tractor (A51573)
Hay Spear for...
JOHN DEERE HX14 LOT NUMBER 266 (A53084)
JOHN DEERE HX14...
Kubota Salt-Spreader (A52384)
Kubota...
2015 Linde H35D 4,350lbs. Diesel Forklift (A51691)
2015 Linde H35D...
New/Unused 250 PVC Safety Traffic Cones (A51573)
New/Unused 250 PVC...
2021 CATERPILLAR 420 XE BACKHOE (A51246)
2021 CATERPILLAR...
