maybe upgrading from a M5040 to a M7060 cab
   / maybe upgrading from a M5040 to a M7060 cab #31
I guess I need to stay away from a 12 speed tranny so I don't learn what I am missing. I mainly mow with my tractors and have always managed with an 8 speed.
Time to put my head back in the sand,
David from jax
Yep, I guess so. :)
   / maybe upgrading from a M5040 to a M7060 cab #32
Yep, I guess so. :)
The 8 speed will work but the 12 speed upgrade is a great value for what it includes, much higher hydraulic flow and epto come with it and it also has a much higher road travel speed of almost 25 mph. If that is not enough to convince someone then the higher resale should do it.
   / maybe upgrading from a M5040 to a M7060 cab #33
lpigott,
Many posters have a propensity for spending money belonging to others, Note, the OP has located a "new to him" tractor. When purchasing used, the options menu is replaced w/ the "as is" reality.
If the tractor selection is NOT taking place at the dealer showroom, the bells and whistles scenerio is quite moot. Let's review: Does tractor meet OP needs? Can OP afford the cost? Is resale the biggest concern today? Did the previous owner just demonstrate resale value as he just sold the blanking tractor? . Does rubbing all the options the tractor does NOT possess in the OP's face really help the OP? Available options are noted in post 23, OP made a decision. I hope this tractor serves him well.
   / maybe upgrading from a M5040 to a M7060 cab #34
Road speed is irrelevant to me. It's the slow, the "working" speeds I care about. And I was a bit upset that 1st gear on my new Kubota with the 12 speed is roughly equivalent to 3rd gear on my ancient John Deere. Love that super-low speed when working in tight places.
   / maybe upgrading from a M5040 to a M7060 cab #35
Adding creep speed is well under $1000 installed by dealer and gives you 6 gears slower than L1
   / maybe upgrading from a M5040 to a M7060 cab #36
lpigott,
You obviously did not take my post as intended! The first line was the only one directed to the OP. The rest to the 1000s of others likely to read this thread to address the advantages and value of the 12 speed.
I had a few hours off today and I was able to installed a radio in the cab and change the oil and fuel filter. I noticed the oil filter has not been changed since it was new and I had some trash in the fuel separator. Break in oil..... 180 hours...... Just a little maintenance on the new used girl. I am off most of next week and I am planning on cleaning it up a bit before I have to start cutting again.
The folks who have the M7060. Does your tractor have a power steering noise when turning?
   / maybe upgrading from a M5040 to a M7060 cab #39
I do not notice any noise or hear the hydraulic pump whine when I turn the wheels on mine... how's the level of your hydraulic fluid?
   / maybe upgrading from a M5040 to a M7060 cab #40
Mine makes no noise from the steering at all. The entire tractor overall it by far the quietest tractor I have ever been around, and I have been around a lot of tractors in my day! As said above, low fluid level usually accounts for noise.
2018 Forest River Flagstaff Pop Up Trailer (A59231)
2018 Forest River...
Hays LT-1 Tender (A56438)
Hays LT-1 Tender...
Deere 333G (A53317)
Deere 333G (A53317)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56438)
2006 Heil Tanker...
2013 Ford Explorer SUV (A59231)
2013 Ford Explorer...
