The B2650 count down has begun!
/ The B2650 count down has begun! #401
The sleeve should not rotate on the bolt. It should be stationary with the yolk/ frame.
I would have to believe the bearing/bushing that turns is in the wheel itself.
Took an extra day off work for the holiday.
Got the tiller and parts all sandblasted and primer and painted today.
Going to let it all dry a few days then re assemble with new hardware and new decals.
Did that thing is going to look like absolutely showroom New! Mine is going to look good from a distance but it will obviously not look like new, beings that I don't have a sandblaster there was no way for me to make it look that good. There used to be a local industrial sandblasting place about 30 miles away but they closed up a few years ago and there's nothing within any reasonable distance of me.
/ The B2650 count down has begun! #403
Thanks!
My buddy does sandblasting and painting for a living. I was going to use his setup. But I ended up just using my harbor freight 110lb pot. My brother in law works at a sand plant so the sands free. Didn’t take to long to get it stripped down to bare metal. I was in a hurry and never let the paint dry much between coats so I am sure it will take forever to try. But looking at the forcast I won’t even be needing the tiller for at least a few weeks. I am going to let it dry for awhile and then decal it. I bought all new hardware to replace every bolt and nut I can get to.
I spent 104$ at the dealer buying all the new decals/parts from landpride. Really money I didn’t need to spend but it will look new. I could have just ran it the way it was when I bought it. But what fun is in that
I did sort of the same thing I spent a little over $400 at the dealer for the new Wheels and stickers and belt that I wanted to make it as close to New as I can. I also replaced the we're bushings that insert into the ends of the tube where your gauge wheels slide up in, and I replaced the coil spring that keeps the tension on the Belt. The only mechanical Parts I didn't replace are the spindles themselves but they still feel very tight and they all took Greece easily.
/ The B2650 count down has begun! #405
Got all the pieces successfully moved into the garage and turned the heat on.
Shining pretty good
Sweet! That looks awesome!
/ The B2650 count down has begun! #407
Thanks, I always have to put a little twist on things. I painted the brackets that the lower links go on, the skid shoes, and the parking stands black. I like a little contrast in colors. Should look good in the end.
The restoration of my Land Pride FDR2572 finish mower has come to the end... Almost. I've but one thing left to do, change the gear box lube over to Amsoil.
Question, there is a pipe plug on the top horizontal plate to fill, there is a pipe plug on the rear facing wall of the gear box that I assume is the fill level because it is just above the bottom of the bearing. I hope I'm not being an idiot here.... How does it get drained?
I see the vent sticking up, the fill, and the level plug. No freaking drain plug! Okay, call me an idiot, but when your done... Tell me the procedure to drain, flush and properly refill.IMG_20180406_171352519_HDR.jpgIMG_20180406_171328796_HDR.jpgIMG_20180406_170759590_HDR.jpgIMG_20180406_170813003_HDR.jpgIMG_20180406_170830105_HDR.jpg
/ The B2650 count down has begun! #409
I asked the Kubota dealer service that very question. He said that they (he) sucks the gear oil out with a vacuum pump. I didn't like that answer, so I lifted my (mower deck in this case) with the FEL and let it drain that way. IIRC there was a drain plug under the gear box frame, but couldn't hardly get a wrench on it.
Cheers Rock.
Mike
/ The B2650 count down has begun! #410
Are you guys using rattle cans to do your paint jobs? They sure look good.
Cheers Rock.
Mike
That's really going to make me angry.
If I have to scratch this paint to flip it over with the loader... I'm going to turn green and smash some stuff.
I brushed on Rust-Oleum Kubota Orange from tractor supply. At 10 feet it looks like a show car. At 2 feet... It still looks plenty freaking great for a tractor implement!IMG_20180403_053710105.jpgIMG_20180403_053632963.jpgIMG_20180403_053557300.jpgIMG_20180403_053757202.jpg
/ The B2650 count down has begun! #413
Larry,
Is rust oleum your tractor supply’s main paint line?
Only place around here to get rustoleum a tractor and implement series is menards. But they only have about 4 colors. And kubota orange is not one of them.
Our local tractor supply carries valspar paints.
/ The B2650 count down has begun! #415
Thanks, Y'All. You do nice work.
/ The B2650 count down has begun! #416
I see the vent sticking up, the fill, and the level plug. No freaking drain plug! Okay, call me an idiot, but when your done... Tell me the procedure to drain, flush and properly refill.View attachment 547462View attachment 547463View attachment 547464View attachment 547465View attachment 547466
Sorry to burst your bubble Larry, but no drain plug. I have used turkey baster with hose I stole from my wife to suck it out. I had my gearbox off when I painted the mower, and dumped it then.20160317_143427.jpg
/ The B2650 count down has begun! #417
If you have a shop vac you can make a pretty simple pump -- stick some stiff wall tubing down your gear box vent hole and run it to some sort of container that can withstand suction (plastic juice jugs are usually OK for this). Seal the tubing to the container best you can, doesn't need to be perfect. Then make another hole in the container and suck through it with a shop vac. You should see the gear oil get pulled into the container.
Alternately, you can buy a simple oil change pump for about $30, which is handy for all sorts of projects (I use them to change oil on outboard motors when the boat is still in the water). It works like a pump sprayer in reverse.
/ The B2650 count down has begun! #418
466.JPG468.JPGThe hard way Rock and others.....but works... as an FYI
Cheers,
Mike
/ The B2650 count down has begun! #419
Got everything put back together today. Just need to get two more thumb screw bolts.
The large landpride decal ripped like crazy when i peeled the back off. Made me mad for how much they all cost.
I was able to carefully place the rest on though and you can稚 even tell.
The black contrasting parts look ok. But I should have just painted it all orange. But oh well.
Looks pretty good with all the new decals and shines like crazy. Unfortunately it will just get dirty from here on out. Lol
I drive the tractor a few miles to my son's girlfriends house and removed some shrubs that she doesn't want. I have more to pull, but I'm waiting on PA 1 call to come mark out utilities first, I suspect that her gas, water and power all come to the home directly along side and beneath the other shrubs. That will make things difficult.
The backhoe and loader work so much better after shimming the hydraulic pressure up! Now it has plenty of hydraulic power.IMG_20180407_164538259_HDR.jpgIMG_20180408_120946579.jpg
2021 CATERPILLAR 306 CR EXCAVATOR (A64279)
2021 CATERPILLAR...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
