Cultivating new field
/ Cultivating new field #1
Larus
Clarkesville, GA
Kubota L2501DT, LA525FL, BK77 Backhoe, PD15 PHD, DD APP60-5-01+ Plow, DD 200-5-050D+ Disc Harrow
I am plowing and discing a pasture that has only grown fescue for 20 years. I am a new farm owner and have my first tractor. I have made several passes with an all purpose plow and one pass with the disc harrow. I see videos on youtube showing soil really getting worked by these tools. I feel like I am only scratching the surface. The plows pulled up some rocks and large clumps of sod/soil, but there is still plenty of grass growing. I have clay/loam and a lot of rocks. Maybe there are still too many large rocks to prevent cultivation. I am not sure. Any advise will be appreciated.
/ Cultivating new field #2
Say Larus, when I start on a new field, I use my tiller first then my plow. If I used the field last year, then I use the disc first and then the plow.
With a lot of big rocks, then I would get a reverse tine tiller. I have a forward till as I don't have a lot of big rocks.
/ Cultivating new field #3
I would recommend spraying the field before you work it. You are asking for a lot more work and repeat work trying to deal with sod "the old way". I suspect you will be doing it anyway, because you won't rid yourself of 20yr old fescue otherwise. Roundup/glyphosate, wait 2 weeks, then have at it.
I just completely redid my waterways which were ancient fescue. I sprayed them, then moldboard plowed, then left them over the winter. Disced them the next spring, shaped the waterways, and planted KBG/Orchard. This winter, I did the same with a hillside I plan on terracing for an orchard. Much nicer than trying to kill grass simply by tillage.
/ Cultivating new field #5
Dirt Dog 200-5-050 Disc Harrow has 18" diameter pans, spaced 9" apart.
The max depth an Disc Harrow with 18" pans will penetrate is 6" to 7".
In my area Fescue roots grow deeper than 7".
I think you will have to spray with Roundup/Glycophospate to eradicate the Fescue.
Dirt Dog Manufacturing >> Disc Harrows Tillage - 200 Series
http://www.tractorbynet.com/forums/...ing-three-point-hitch-mounted.html?highlight=
The Dirt Dog APP will penetrate 14" deep if your tractor can maintain traction, but spacing between the tines is wide.
(Photo #1 + #2)
/ Cultivating new field #7
Gotta use a moldboard plow for turnover.--chisel plow , not good.--disk won't chop up grass chunks/rootballs/ or rocks.
If you have that many rocks, big or medium, then you won't do much farming.--- as already said,--chems. is the only way to kill the sod. The rocks will have to be removed either by hand or by a rock-picker machine before trying to work/plant the area.
This is not something that will be done overnight either. it can take a long time depending on how long you stay on top of the project. good luck and hang in there! thanks; sonny580
/ Cultivating new field #8
Cut as short as possible,spray,plow...........roto-till or disc.
/ Cultivating new field #9
For breaking sod, you need a moldboard plow with colters.
Case IH 45 3-Bottom MOLDBOARD PLOW (used) ; 1-8-999-3276 … SALEM FARM SUPPLY, INC. | salemfarmsupply
The size of the plow is the width of the furrow, so a 16" plow will cut a 16" wide furrow, a 12" plow will cut a 12" wide furrow, etc. You need to size the plow to your tractor. A 35 hp tractor will pull two 14s pretty easy. You need to take it pretty slow if you have a lot of rocks. It will turn over a fist sized rock no problem, but if you hook a big rock it can break the nose off the plow share. After plowing I have cleaned up rocks in a field with a repurposed potato picker dumping into a stone boat.
Oliver Potato Digger - TractorShed.com
/ Cultivating new field #10
Agreed.
To work well chizel ploughs need lots of horse power in front of them.
After plowing 6-8 times and discing 6-8 times, most of the rocks are gone and the fescue is dead. Well, 95% of it. It is actually looking like a seed bed now.
/ Cultivating new field #14
A rock rake or landscape rake may help you move some of those rocks out.
I would like to get a landscape rake. I think it would be helpful in the garden and on the gravel drive. I could use it to collect mulch from the forest.
BOBCAT 68 INDUSTRIAL GRAPPLE BUCKET ATTACHMENT (A60736)
BOBCAT 68...
2018 CATERPILLAR 262D SKID STEER (A62129)
2018 CATERPILLAR...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61307)
2021 Takeuchi...
1006 (A61166)
1006 (A61166)
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
2023 Kubota L6060HST Compact Utility Tractor (A61307)
2023 Kubota...
