What have you done to your Branson today?
   / What have you done to your Branson today? #201
I like the chain link hose clamped to your cylinder, ptsg. I tie mine up with a piece of rope, but your method is a much better. One other thing I did was tape the end of an old tape measure to the cylinder sticking out toward the back so I could see at a glance the exact amount of cylinder extension I am set at. This is particularly helpful when box blading.
   / What have you done to your Branson today? #202
Thanks Cougfan! I had this big chain laying around, but it only had like 15" length. Couldn't really use it for anything so I just snapped a link from the chain. I also didn't want to weld anything to the cylinder to avoid distortion. It worked out nicely.
That's also a great idea with the tape measure. It's not very common to use box blade over here so I don't really need it but would be nice to see how much it creeps and would probably be faster to attach implements as you can get the length preset.
   / What have you done to your Branson today? #203
Did the 55 gallon barrel ballast last night. Genius and thanks to whoever came up with that idea. Just waiting for the concrete to set.
   / What have you done to your Branson today? #204
Got a hydraulic top link and Gearmore box blade with hydro rippers installed. Going to do some backfilling tomorrow. Most likely next item on the list I'm going to find out right away is a dose of beet juice/rim guard ballast in the tires. My wheels oddly enough don't seem to have any mounting holes for cast iron wheel weights.
   / What have you done to your Branson today? #205
Hauled some logs to process for firewood on this bad boy trailer. It was a military all purpose 4’ x 10’ trailer with 6k lbs rating. Made logging forks for it. Did a cord today and my boys have approx 9 more cords to do. It’s real handy to have this trailer so I wouldn’t have to shuttle the logs with just the grapple. Definitely a time saver!
(Yes, this is the trailer I’m considering painting to match the Branson)
   / What have you done to your Branson today? #206
I like the trailer. Wish I had one like it
   / What have you done to your Branson today? #207
Is that a third function valve for a grapple? What did you do for the switch on the loader control?
   / What have you done to your Branson today? #208
Thanks! Definitely lucky to have this!
On the joystick, yes it is. Got it that way from the dealer when I ordered the 3rd function & 2 rear remote setup.
   / What have you done to your Branson today? #209
Setting culverts. Working in covering them up currently. Tractor was just barely able to lift each culvert.IMG_20180326_152019.jpgIMG_20180330_145005.jpg
   / What have you done to your Branson today? #210
Interesting. The offering from my dealer was a diverter and I didn't like how it ran the hoses. It did have a replacement loader handle that incorporated the switch and kept the factory shape. Unfortunately only available with the full kit.
2014 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A58214)
2014 HEIL TRAILER...
2015 Nissan Rogue SUV (A56859)
2015 Nissan Rogue...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2015 Ford F-550 Stellar 7621 7,500LB 3 Ton Crane Service Truck (A56858)
2015 Ford F-550...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
