Modification to bush hog...
/ Modification to bush hog... #1
kebo
Elite Member
Lexington, SC
2001 John Deere 790 4x4, bar tires
I saw this picture of a JD bush hog on craigslist and noticed a modification on it that looks pretty slick. At least, if it does what I think it does.... looks like someone mounted a disk on each front corner that is made to rotate? If that's what they are for, when you hit a tree or fencepost that should help keep the corner of the bush hog off of the tree or post. Has anybody seen this done before?? It seems like if it was a great idea, more bush hogs would have them?
/ Modification to bush hog... #4
You see similar wheels on boat docks to deflect a boat along the dock.
Also used in other applications so not a new idea
Dave M7040
/ Modification to bush hog... #5
Brush hog or bush hog, technically interchangeable but not really mowing bushes but rather brush. So mow the brush and trim the"bush". All I have to say about that.
/ Modification to bush hog... #6
This I like. :thumbsup:
Sorry, but in the south they are all called bush hogs. :laughing:
/ Modification to bush hog... #8
/ Modification to bush hog... #10
Similar protection wheels are a accessory for the left side of Grasshopper zero turn mowers to protect the deck while mowing close.
/ Modification to bush hog... #11
Go on, I'm listening. >8-]
/ Modification to bush hog... #12
Nice addition to a JD rotary mower, or any other brush mower, including a Bush Hog.
David from jax
/ Modification to bush hog... #13
Use the term brush hog in my area and nobody would know what you are talking about. A Coke can be any almost any soft drink and Bushog can be any rotary brush cutter.
/ Modification to bush hog... #14
I own two bush hogs. One is a shredder and one is a finish mower. I have never called either a brush hog.
I do like the wheel idea. Thanks for posting!
/ Modification to bush hog... #15
I think we should call them "slashers." Sounds much more violent and I like that! Also I want to start spelling tires properly with a "y" and eliminate the letter "z" and replace it with an "s." You realise that I'm being sarcastic.
However, the wheelie dealie thingy is a great idea!
/ Modification to bush hog... #17
Anyone need a cold pop?
/ Modification to bush hog... #18
Mcfarmall,
It seems that when one is being sarcastic or facetious, it is necessary to state your intention, lest it be misinterpreted and misunderstood by folks lacking a sense of humor.
In some pockets of the country words such as "brush" are only spoken at one's own peril and in extreme cases, the mere utterance may illicit the death penalty, or some other irrational response. Mea Culpa despite the encyclopedia definition equating bush and brush cutters.
In my tiny little corner of the planet, a "coke" may only be interchanged w/ a Pepsi, and at that, still requires a verbal permission.
We argue the sublime because topics of substance require actual thought and factual content, or is that also in dispute?
Sublime in this context = high moral authority, lest we start a new word assault tirade.
/ Modification to bush hog... #19
Mcfarmall,
True. But good communication facilitates good information transfer. It's the same reason we have English classes (or whatever your countries native language is). If everybody is using the same agreed upon communication standard, the is no, or at least a lot less of a chance at miscommunication.
/ Modification to bush hog... #20
Fallon,
Your turn to be the voice or reason. At times, it seems that miscommunication in the forums is more intentional than accidental or incidental.
I do NOT exempt myself from the statement above. Everyone has their moments.....
YALE FORKLIFT (A63291)
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A61572)
2025 BrushFox...
CASE INTERNATIONAL 3900 DISC HARROW (A63291)
CASE INTERNATIONAL...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
2020 John Deere 8R280 (A64119)
2020 John Deere...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
