Oil & Fuel Mobilfluid 424
/ Mobilfluid 424 #1
MickeyDBC
Gold Member
Dime Box,Tx
Kioti RX7320PC & NX4510HST
Blew a pinched O-ring on the spoolvalve endplate on my RX7320 and pumped a lot of hydraulic oil out (ended up having to add 4 gallons to fill it back up). The manual was very specific about what fluids were compatible and the generic Tractor Supply 303 was not one of them. The Kioti branded fluid was higher than a cats back so I called the oil supplier in Austin that we get a lot of weird oils for my cnc mills from (they are the local commercial Mobil dealer) and they carried Mobilfluid 424 which was on the approved list. Ended up being $39 a 5 gallon pail delivered so I bought the 4 that they had in stock. 424 is also a listed as a direct swap for Kubota UDT. I have about ten hours to go until the 50 hour service, so one less thing to buy.
/ Mobilfluid 424 #2
Well if Mobil says it meets spec you just saved a boatload of cash. Nice.
/ Mobilfluid 424 #3
I couldn't imagine Mobilfluid 424 for that price. I paid over $90 for a 5 gallon pail some years ago. I went to Kubota SUDT2 now that the Kioti is out of warranty. I believe the Kubota semi synthetic is a better fluid for a HST equipped tractor, but the Mobilfluid 424 was a good fluid. So if you got it for $39 a pail, you stole it. :) Also being in Texas, you probably are not concerned with cold weather, like we have here at times. That is one reason I looked into the SUDT2 for it superb cold weather qualities.
/ Mobilfluid 424 #5
That's a good price for 424. In the future, JD20C is the same stuff.
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
JOHN DEERE 1210A GRAIN CART (A64277)
JOHN DEERE 1210A...
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
2009 V.E. ENTERPRISES 130BBL VACUUM TRAILER (A65643)
2009 V.E...
