Tooth bar
/ Tooth bar #1
CMV
NC
Kioti NX4510HST (previous LS XJ2025H, JD 500C)
I have a digging project for a friend coming up so want to get a tooth bar ordered this week. so 2 questions:
1. Titan, BXpanded, WR Long, etc...does brand matter? Will be occasional use and I don't expect to be doing huge amounts of digging - I understand my little machine isn't an excavator. Inexpensive but functional is what I'm looking for - suitable for "homeowner use".
2. Has anyone bought one for an XJ2025? If so, I need the size to get. Tractor in the shop right now so I can't measure the inside length of the bucket. Specs just say 50" bucket, but looking at how the tooth bars attach, looks like I would need a fairly precise measurement.
Does it have to be a bar? Bigger machine like a backhoe just has holes in the bucket and you bolt the individual teeth on. Can I do something like that or is the bucket too lightweight and requires the extra strength of the bar? Can I just drill some holes and use this: 7 Bucket Teeth Assembly 6737322Y Bobcat Style Bolt on Flush Mount Pin Skid Steer ? Or would whole bar assembly be much better?
/ Tooth bar #2
The whole tooth bar only needs two holes, faster less work to install , Call BX the might know what one fits your model
/ Tooth bar #3
I bought the BXepanded Piranha tooth bar a year ago. Great tool, as I leave it mounted all the time. You need to measure your bucket inside measurement for the BX model. The attach fitting on each end are malleable so they can conform to bucket surface. Mine digs well but is really helpful when I am clearing small trees and saplings....it pulls them right out of the ground.
/ Tooth bar #4
You will bend your bucket lip if it is not reinforced which is what the toothbar does in addition to providing teeth. I have owned 2 toothbars, a standard toothbar I bought from Kubota and a Piranha. The piranha is much, much better. A word of caution: the bucket is meant to scoop, not dig. You aren't going to be doing a lot of digging with a bucket. You may need a backhoe or a excavator.
/ Tooth bar #5
"You aren't going to be doing a lot of digging with a bucket. You may need a backhoe or a excavator."
I agree for the most part. Unless you are digging above grade, like into a bank to relocate dirt and rock for fill elsewhere. That's where a bucket with a toothbar does a great job. For digging alone, I prefer a toothbar over the Piranha. But I can see where a Piranha would excel for removing brush and saplings.
/ Tooth bar #6
"You aren't going to be doing a lot of digging with a bucket. You may need a backhoe or a excavator." I agree for the most part. Unless you are digging above grade, like into a bank to relocate dirt and rock for fill elsewhere. That's where a bucket with a toothbar does a great job. For digging alone, I prefer a toothbar over the Piranha. But I can see where a Piranha would excel for removing brush and saplings.
For removing thick low growth, the ratchet rake works very well also.
/ Tooth bar #7
Use caution when digging with a CUT or an SCUT FEL. Take shallow slices and try to keep the pressure even across the whole bucket width, as opposed to one only one side - try not to take big bites or regularly cut with the corner of the bucket. There is a reason they are not called FEDs (front end diggers) as the arms really should not be stressed side to side a lot - they can be deformed or actually can fail under heavy digging - I've seen posts on here where owners had had a FEL arm fail.
That said, yes a tooth bar is a great assist in digging and I believe will actually reduce the stresses on your FEL as you dig. Here's what Airbiscuit said in another post and I think it is generally accurate, "A tooth bar greatly lessens the "attack area" of the bucket, and it's like having twice the horsepower and traction. I have also found a tooth bucket easier to work that gnarly mass of roots and sod. Companies like Titan and Piranha make good bolt on tooth bars for your bucket."
/ Tooth bar #8
What they wrote.
My two Kubota's wear Piranha's all the time. I can even slip my clamp-on loader forks over them. Remember your tractor has a FRONT END LOADER. Not a Front End Dozer (FED)). If you can break up whatever you need to move BEFORE loading it you'll do a lot better. For example run a box blade through packed soil with scarifiers fully extended, then use the FEL to move it.
Many people have bent FEL's by using them as FED's. Unbending is not always easy or inexpensive.
/ Tooth bar
project is digging into a hillside to create a fire pit area. I think I can do it with some teeth. Small bites at a time, but think I can get it done.
Tractor is at dealer anyway for some repair work. They said they can order one and install for $400. Since already there and they can have it ready to go by Saturday think I'll just go that route
/ Tooth bar #10
What they wrote.
Do they interfere at all with loading gravel, dirt, or road base?
/ Tooth bar #11
Sounds good. The loader will do the job but, just like with most things and a CUT, it just takes a bit more time in the seat. Certainly better than shovel time! I never could find the ignition switch for one of those.
/ Tooth bar #12
CMV, you should do just fine with the advice given here and what you are contemplating.
And common sense goes a long way as you learn what you can and can not do or shouldn't be doing. ;)
/ Tooth bar #13
I had plans to do some pretty heavy digging with my tractor. After reading a lot of post on here regarding digging, I decided not to try to use my tractor as a dozer but instead as a tractor/ loader.
I ordered a 78in box blade from everything attachments and will be ordering a piranha tooth bar since when I started a thread on tooth bars, everyone said piranha.
The best way to dig with a tractor would prob be a old moldboard plough, you can cut 8-10in at a time and use the loader to remove the material, another old moldboard is a heck of a lot cheaper than a FEL. When I get my box blade I can also dig a little but moldboard would be way faster since that’s what it’s designed to do but you would be limited to just a few feet.
/ Tooth bar #14
Or a Freno on the TPH, I have one of these bought at an auction along with a buzz saw. I bought it for the arches and TPH stuff but I might keep it to dig with.
/ Tooth bar #15
I have a Piranha Tooth Bar and have done some serious carving out of my hillside using my FEL.
No problem with dirt, gravel, sand... as the PTB has a flat bottom and works great back dragging. Also put a couple hooks on top of the bucket as well.
/ Tooth bar #16
Ditto on 747driver's post.
The tooth bar makes digging allot easier
I have the Piranha also, easy to drill the holes and install yourself.
I dug a hole for a root cellar with mine in the side of a hill, 30' X 20' and about 8' deep.
/ Tooth bar #20
I think my 10' backhoe would do that easier & quicker than my front bucket with a tooth bar.
Worksaver 3 Point Post Hole Digger (A65640)
Worksaver 3 Point...
THIS WILL BE A TIMED ONLINE AUCTION! (A65640)
THIS WILL BE A...
Woods 15ft. Batwing Mower (A65640)
Woods 15ft...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A65563)
2008 Hino 268...
New/Unused Wolverine 6 Way Dozer Blade (A65583)
New/Unused...
