Windshield washer fluid to load tires?
/ Windshield washer fluid to load tires? #21
Hi ok someone mentioned FOAM where and who would do that? and at what cost? that would bed the ticket if it is affordable,,.
/ Windshield washer fluid to load tires? #22
Foam (more like solid rubber product) is added by tire shops specializing in doing this. It is expensive and time consuming to replace tires when they wear out. It basically has to be cut off with a sawzall. The foam product itself is expensive. I have heard the ride is rougher also. BUT you sure don't have to worry about flats ever again, and it adds good ballast to the tires. Look for tire shops specializing in working on construction equipment.
/ Windshield washer fluid to load tires? #23
Hiya
Well windshield washer fluid is just water with a touch of ammonia and maybe a surfactant and detergent. It's density will be the same, give or take, to plain water. Hence no advantage to weight. I can't think of any reason why the washer fluid would be good or bad for the tyres. Waste of money compared to plain water.
Mike
That's not correct....windshield washer fluid has an antifreeze in it....freeze temperature is well below the freezing temperature of plain water.
But do ensure the windshield washer fluid used is the winter blend!
As the OP lives in NY state, he'll need that freeze protection.
I've had windshield wash fluid in two tractors...the third (my first tractor) had CaCl.
My opinion is CaCl gets a bad rap. It's been in a lot of tractor tires for decades with few issues. But if there is a leak...well, it's rough on the rims.
/ Windshield washer fluid to load tires? #24
I am in NY like the OP. We can't use plain water for risk of freezing. I have 39 gallons in each of my rear tires. I figure it added almost 550 lbs to the rears. Beet juice would have added about 300 lbs. more weight but was also much higher in cost. The washer AF I used is good for -20 deg. F.
/ Windshield washer fluid to load tires? #25
Will windshield wash dry out the rubber in the tires, as ive seen others say it would. If so how long would that take?
Also heard a local here say to use used vegetable oil filtered and was wondering if its ever been heard of or done. What would be the reasons against it?
/ Windshield washer fluid to load tires? #26
A foam filled tire is going to ride rough and you will lose considerable traction, unless you are working in a junkyard/salvage yard why would you even consider it.
Even heavy off road hard rock mining equipment doesn't use it.
/ Windshield washer fluid to load tires? #27
I thought I'd solve my leaking air problem on the front tires one of my ZT mowers by purchasing the solid wheel-tire. I run them with low pressure for a soft ride. Big mistake. as stated, solid tires are solid, just like running on a steel wheel with no tire on it. So if a foam filled tire is like this, plan on a bumpy ride. As far as traction goes, you probably won't have them on long enough to test for traction capabilities.;)
On washer fluid, my last fill (little over half a tire full) was such. Cheapest thing I could find and since it is rubber safe, didn't worry about it hurting the tire.
/ Windshield washer fluid to load tires? #28
I purchased airplane fronts from Gensco several years ago after tiring of fixing flats on my 4610 SU. 18 plys go a long way for thorn prevention. They have been worth every penny. I'm installing 12 ply industrials on the Ford now for hogging. Hopefully they will prove more thorn resistant than the 6 ply AG's they are replacing.
As far as WWF I purchased a few cases at Advance on close out couple weeks ago for .99 per gallon. Good to -20 degrees. That is what I am going to load my rears with.
/ Windshield washer fluid to load tires? #29
My rear tires are filled with Rimguard. 770# per tire. Water = 8.35 pounds per gallon. Rimguard = 10.85 pounds per gallon. Any work on my filled rear tires will be handled by Les Schwab Tires - locally here in Cheney. They will come right out to my place and provide any service I might need.
/ Windshield washer fluid to load tires? #30
RimGuard is the best (for maximum weight), but is the most expensive option.
RimGuard is not available in many areas, is installed by dealers, and makes a sticky/gooey mess if it leaks, or must be drained.
/ Windshield washer fluid to load tires? #31
Rimguard is indeed messy and sticky when you get a leak. Anything you load a tire with is also going to make if a bit more difficult to plug a leak (tubeless) due to the moisture in the tire - just something to consider - not something to prevent one from loading the rear tires as it is much less expensive (unless you use Rimguard) than buying wheel weights.
2023 JOHN DEERE 333G SKID STEER (A65053)
2023 JOHN DEERE...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
360 Y-Drops (A65640)
