Windshield washer fluid to load tires?
/ Windshield washer fluid to load tires? #1
rthrbhntg
Delaware Co NY
Kubota MX5100
In the process of deciding on my first tractor. One of the Kubota dealers I have been talking to said they load the tires with windshield washer fluid. The other dealer says beet juice. Any reason one vs the other?
/ Windshield washer fluid to load tires? #2
Hiya
Well windshield washer fluid is just water with a touch of ammonia and maybe a surfactant and detergent. It's density will be the same, give or take, to plain water. Hence no advantage to weight. I can't think of any reason why the washer fluid would be good or bad for the tyres. Waste of money compared to plain water. As to beet juice, have no idea.
Calcium chloride solution is often used to fill tyres as its density is considerably higher than plain water as you can get quite a lot of CaCl2 to dissolve in the water, increasing the density.
Mike
/ Windshield washer fluid to load tires? #4
If you are going to load your tires(In NY state) don't use straight water,it will freeze.Windshield washer fluid will weigh about the same as water 8.5lbs per gallon,Rim Guard is 30% heavier,at least according to their web-site.The dealer is referring to Rim Guard as beet juice,which it is.
Expensive,ya a little but I feel it is worth it.Maybe have the dealer throw is as a perk for purchase.
/ Windshield washer fluid to load tires? #5
Hiya
Mike
Here, in the northern US and Canada, windshield washer fluid has a -25F rating achieved through the addition of methanal or similar, to prevent freezing. RV anti-freeze is slightly more costly, but often has a lower temperature rating. RV anti-freeze is also non toxic.
Beet juice, either generic or brand name is somewhat costly. It is also non-toxic, as a rule, and also has is a pretty good anti-freeze.
IIRC, beet juice has a bit more weight per gallon.
/ Windshield washer fluid to load tires? #6
Hi bp fick
Ah .... now I understand why they use washer fluid. Its not really washer fluid then but pricy water and methanol. Surely water and some metho added would be cheaper than washer fluid.
Anyhow now I understand.
Mike
/ Windshield washer fluid to load tires? #7
We have used WWF for years. Its cheap. I bought a 55 gallon drum of -20 WWF 3 years ago for $40.00 at the local oil distributor.
Chris
/ Windshield washer fluid to load tires? #8
Ive always just put 2 gallons antifreeze per tire then fill with water. No problems with freezing. Cheap 2.
/ Windshield washer fluid to load tires? #9
Our dealers here use WWF, I don't know of anyone who uses Rimguard, if it had been an option, I may have considered it. My concern was finding a farm tire service company that could replace it if I got a flat.
/ Windshield washer fluid to load tires? #10
Hiya
Mike
Windshield washer fluid is usually some mix of methanol.... at least in the US it is. There's some environmental issues if you puncture a tire.
You certainly don't want to put plain water in your tires...
Rim Guard (Beet Juice) is good stuff but pricey. It's environmentally safe and weighs more than methanol.
/ Windshield washer fluid to load tires? #11
I have the beet juice (Rim Guard) in my tires from Elkunds and everything I have read says that that is the way to go, but maybe expensive. No problems with mine. Are you only looking at Kubota's?
/ Windshield washer fluid to load tires? #12
Is there any problem with rust from the WWF?
/ Windshield washer fluid to load tires? #13
Welcome to TBN!
Actually, no. Windshield washer fluid is formulated to be safe to use with most metals, plastics, and rubbers. The good stuff won't freeze until -20F also. I use it in my lawnmower tires. I poked a hole in one of my rears and had to replace them (after having the fluid in for about 5 years), other than the fluid turning from bright blue to a nearly clear fluid with a slight grey tint, there was no noticeable damage to either the rims or the inner parts of the tires.
/ Windshield washer fluid to load tires? #15
I have beet juice in mine. Calcium chloride from the road is killing my truck - rust. I'd hate to put it in my tires. Wishshield washer fluid, like antifreeze is toxic to living creatures. Seems like beet juice makes sense. Been down to -25F and no problem.
/ Windshield washer fluid to load tires? #17
On a totally different level... Windshield washer fluid is meant to be sprayed on your windshield, which in turn ends up on the ground anyway... The EPA would throw a fit (and rightly so) about folk using traditional antifreeze as windshield washer fluid. The toxicity is much higher and much more persistent in antifreeze. Granted you can get some high end WWFs that have all sorts of exotic chemicals for bug wash and deicer and whatever, but the plain jane cheapo stuff is mostly water with just the minimum detergents and chemicals needed to make it do the job as advertised.
Don't over-pressurize and watch what you're running over. If ya spring a leak do your best to recover it for future use, no matter what you use.
/ Windshield washer fluid to load tires? #18
Hiya
Mike
Windshield washer fluid is not just plain water here in Minnesota. What do you think would happen at 20 below zero? It really contains iso propyl alcohol about 50 percent+/- so it doesn't freeze.
/ Windshield washer fluid to load tires? #19
My brother just replaced the WWF in our M8540 after a recent flat and it's rated to -20 which is about right for our area. It took 80 gallons.
