Old Hoe Needs new life
/ Old Hoe Needs new life #1
Backyard Hoe
Calais Maine
JCB 1400B
Hi all
Have an old JCB 1400B and looking to upgrade the slow hydraulics on the machine. Seems I need plenty throttle to get any sort of efficiency from the machine. The main pump is getting noisey so I'm thinking that might be the first place to start looking, and secondly check the hydraulic system pressure at suggested test points.
I have already re-worked injectors and fuel pump. Engine is running fine.
Can anybody suggest or heard of a replacement steel design for the glass doors which so often break?
Also does anyone have any idea of the hoe lifting capacity? I need to lift blocks weighing around 3300lbs ea.
Thanks for your time and
Have a great day!
/ Old Hoe Needs new life #2
Sorry. Can't help. I just clicked on this thread because I thought it was about Stormy Daniels. :eek: :D
/ Old Hoe Needs new life #4
Hydraulic pumps lose efficiency with wear. Replacement is probably in order. Rebuild without a test stand to run it in on is risky.
/ Old Hoe Needs new life #5
I nominate this ^ for the funny post Hall of Fame...:D
/ Old Hoe Needs new life #6
I also thought this was going to be about Sunday's 60 Minutes as well.
KOMATSU D51PXI-24 CRAWLER DOZER (A65053)
KOMATSU D51PXI-24...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
ALLMAND MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
2027 . 500k BTU...
PALLET WITH 3 ELECTRIC CHAIN HOISTS AND ONE MANUAL CHAIN FALL OUTBOARD MERCURY PARTS MOTOR (A66738)
PALLET WITH 3...
