ares 630 rz quadrishift gearbox problem
/ ares 630 rz quadrishift gearbox problem #1
AntonB
Reunion Island
various
Good day to all.
I have a problem with the clutch not disengaging so I can change the gear range ( 1 - 4) everything else is working ( revershift not even jolting) the quadrishift works well 1 to 4 and when I press the clutch the tractor slows down/speeds up as you would suppose it should do. but In order for me to get the tractor moving I have to start it in a specific gear range.
I apreciate all input and thanks in advance.
Anton
/ ares 630 rz quadrishift gearbox problem #2
:welcome:
To the TBN forum Anton. You came to the right place to get answers.
But not from me as I have never heard of your tractor. I am sure someone on here will be able to help.
/ ares 630 rz quadrishift gearbox problem #3
I think you may have better luck if you can find a Renault/ Claas specific online forum. Not many forum members here familiar with Renault tractors
:welcome:
Thank you, I hope so too
2018 Case 650M OROPS Dozer (A62679)
2018 Case 650M...
2014 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2014 CATERPILLAR...
EZ-Steer Controller and EZ-Steer Motor (A65640)
EZ-Steer...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
Cedar Boards (A65640)
Ford 3930 Tractor (A65579)
Ford 3930 Tractor...
