Box blade versus grader
/ Box blade versus grader #1
jmt1271
MO
Kubota L2501
I'm putting together my order for a b2650 and loader.
We own 10 acres and between the main driveway and a second driveway to the barn, I have about 1200 feet of gravel to maintain.
On my last tractor, at my previous property I had a box blade. It would get the job done but I never felt it was easy to use.
For those that have used both, from a moving rock and grading perspective, which implement do you think would be most efficient for managing my driveways?
Any particular models I should consider? Would prefer to stay with landpride if possible to simplify the ordering process through kubota dealer. Thanks.
/ Box blade versus grader #2
I have a mile long gravel driveway. I own a roll over box blade, rear blade and land plane grading scraper. By far - either the robb or the rear blade is the most difficult land engagement implement to master. Conversely - the LPGS is one of the easiest to master. I use all three on my driveway.
Rear blade - winter snow removal and to pull material up and out of the driveway ditches
ROBB - move material from here to there
LPGS - to make things really smooth, take out the ripples, fill small potholes
If I had only one implement it would have to be the rear blade. As difficult as it is - it WILL do more tasks than either of the other two. AND with continued use I WILL become more proficient.
/ Box blade versus grader #3
I have only a box blade. It is not easy to use but I'm getting better. Since I am still building roads I think it's the best implement for me right now. I plan to get or build a plane down the road for maintenance.
I can't see ever wanting just one since they have different uses. If I had good roads that just needed maintenance I'd get the land plane and watch for a used bb or blade. I frequently see decent used options for those 2, I don't remember ever seeing a used plane around here.
/ Box blade versus grader #4
If you going with a box blade, order the rear remotes because you will want a tnt. Also be sure to order the telescoping links. They aren't standard on the open station.
/ Box blade versus grader #5
BLAAAAT - you guys East of the Mississippi and all the used equipment that's available. I've been here in Ea WA state for 36 years and used agricultural equipment has been ZERO. I gave up looking about 25 years ago and just resigned myself to buying new.
I will definitely second skipperbrown on the rear remotes. I have a hydraulic top link and its probably the best addition to my tractor. Hydraulic top link adjustment for your ground engagement implement overcomes frustration and time wasted and allows perfect alignment of the implement. Definitely well worth the money.
/ Box blade versus grader #6
Initially I only had a box blade and tried to make that work to maintain the 850' gravel driveway. It got the job done - sort of, but not really, and was a bit frustrating to use for maintaining a driveway. Later I popped for a rear blade and it works so much better. I cannot only tilt the blade (have TNT) but can also put it at an angle and thus can grade/sweep the gravel to the middle of the road and create a nice crown which is the key to maintaining a nice driveway. Now when I go to maintain the driveway I don't even think about using the box blade.
The box blade has it uses, but in my opinion is not ideal for maintaining a driveway and the rear blade works so much better. A land planner would be even better but they are not cheap. A rear blade is inexpensive and works for me.
/ Box blade versus grader #7
I have both the box and grader blades. Both each serve separate functions. I like the BB for digging up material with the rippers and letting the box get full to where I can move it to the place I need the material at. It does take some time to learn how much to adjust the box angle. I have a sliding grader blade, which really makes it nice to make and maintain ditches. With a sliding blade it lets you get the blade offset to either side so as to get the rear wheel away from the edge. I don't have R Remotes...just a few manual turns on my top link or a few turns on my telescoping lower right link sets my angle. I maintain 1/4 mile stone mountain road.
/ Box blade versus grader #8
You can loosen (with ripper teeth), and move, material with a box blade.
You can SHAPE material with a rear blade.
/ Box blade versus grader #9
In my opinion, the ETA units are the best in the size range for your tractor. Longer, taller, heavier than the competition
But if you want to stay with Land Pride, I'm sure that it will work well for you also. :thumbsup:
/ Box blade versus grader #10
I maintain 1 1/4 miles of private road and several 200+' driveways. 35 years ago, the road was red shale and I used a box blade for maintenance. Red shale is soft and prone to washouts which made the box blade useful in moving large amounts of material to fill ruts and potholes. Unfortunately, this needed to be done several times per year and after every heavy rainstorm.
20 years back, I spent the money and topped the red shale with a 6 inch layer of modified gravel. The project required 2000 tons of material. My neighbor and I did the work ourselves. He used the box blade behind his tractor and I used a landscape rake behind mine. The two implements complemented each other nicely. After the stone was down, I quickly found the landscape rake was a much better tool for the job. Equipped with gauge wheels, scarifier, grader blade and T&T kit, it's the only tool I need for road maintenance. After not using the box blade for several years, I sold it.
/ Box blade versus grader #11
That is a neat rake. I have never seen one with a box and scarifiers.
/ Box blade versus grader #12
I am not familiar with the term "modified gravel"
Are you using "modified" crushed gravel, or "modified" washed gravel.
In either case, what is being used as the "modifier"?
I don't see how you can angle your rake, so how do you pull in gravel from the edges?
Are you able to keep a meaningful crown on your driveway using the rake?
2000 tons...big money (200 loads?) at 10(?) tons per load.
/ Box blade versus grader #13
2RC Modified is a product produced locally by several quarries here in NE Pennsylvania. It consists of crushed Pennsylvania bluestone with sizes ranging from 3/4" down to stone dust. It packs down to a smooth almost concrete like surface. it is used by the state DOT and many municipalities as road surfacing material. It wears well and is fairly easy to apply. The stone surface can be seen in several of the attached pictures.
The York landscape rake does angle hydraulically, although it isn't obvious from the pictures. The angle cylinder is circled in the 5th picture. The top and tilt kit is what makes the implement so versatile.
Tilting the rake allows me to put a good crown on the road which is necessary to shed water on the steep portions of the roadway.
Yes, at just over $15K ,the project wasn't cheap. It took 95 tri axle loads at between 20 and 23 tons per load. The property owners who share the road contribute to an association which paid for the project. We saved almost $10K by doing the work ourselves.
/ Box blade versus grader #14
I purchased plates that easily bolt and unbolt on to the ends of my grader blade. Works great and provides most of the function of a box blade.
Actually added a setup to use the teeth from my box blade and now rarely use the box blade.
/ Box blade versus grader #16
View attachment 544112 View attachment 544113 View attachment 544114 View attachment 544115 View attachment 544116
Ah... now it all makes sense.
Without the 2nd group of pictures I could not see that the rake could be angled.
What you call modified gravel, is often called 3/4 minus in other areas of the country.
With that rake, you are able to maintain a significant crown, which few understand the importance of.
I have about $25K (+14K for electric) invested in constructing my 2000' driveway, through a heavily forested area, and graveling, so I know more than I would like to, about cost.
/ Box blade versus grader #17
Thats a neat idea, a rear blade and box blade in one.
/ Box blade versus grader #18
A quality stone surface is indeed expensive but it pays for itself over time. In the 20 years since the initial $15K investment, annual material costs for repair of wear spots and washouts has averaged about $250 per year. Maintaining the old red shale road cost 4 or 5 times that requiring weekly attention .
/ Box blade versus grader #19
I sure do like that set up.
The hydraulic top link allows you to lift the rake high enough to pull material off the top of a pile and level it completely without using the FEL. I find this to be one of the more useful features of the rig.
/ Box blade versus grader #20
We maintained 3 miles of gravel road for 10 years with a DIY drag.
Generally did it 3 X/yr and dragged with an old Willis jeep.
It was 8ft wide X 8ft long with chains to pull from 2 corners to both ends of the Jeep bumper.
It consisted of 2 long 'sides' with 3 blades, well being all wood (yes 6 X 6's notched and bolted together)
The 'blades' were ,(front and back) angled in same direction while the center was opposite angled and slightly sharper angle.
(idea being the 2 same angled would pull sideways while the center Opposite angle) would counter react. It worked!)
Being all wood we lagged 3/8 X 3" flat steel as our 'cutting edges' That also worked.
The 3 blade design allowed scalping of the high spots and the angling of the blades forced the loose material to migrate sideways to fill the dips.
2 passes and we had a beautifully graded dirt (LOL/gravel) road.
The road served some 40 chalets and the guests plus delivery vehicles so I was well used.
Hills were the main challenge as washboard developed rapidly and that mainly due to automatic transmission shifting midway that caused the start of a bump that over time developed into washboard. (We instructed drivers to shift into 2nd and accelerate B4 and not on the hills. Helped a lot.)
If welding is in your capabilities by all means weld up using 3 x 3 or 4 x 4 angle stock.
(I recently did so using scraps I had on hand for a friend, smaller in that it is 4' wide X 4' long., he loves it for his gravel aisles at his storage locker facility)
IMHO it accomplishes all that box blade will do and possibly even better, but surely at a better price.
2006 Chevrolet Silverado 2500HD Ext. Cab Knapheide Service Truck (A61573)
2006 Chevrolet...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
Ditch Witch 6510 DD Trencher 4x4 (A62613)
Ditch Witch 6510...
RoGator RG1300C (A63688)
RoGator RG1300C...
