3 point carry all, build or buy?
/ 3 point carry all, build or buy? #21
3RRL said:
ovrszd,
That is one sweet dump/carry all you made. Adding the hydraulic dump cylinder will make it perfect.
Outstanding work!
Thanks Rob,
Coming from a guy who can build anything, that's quite a compliment!!! ;)
/ 3 point carry all, build or buy? #22
ovrszd said:
Good point. Should have added this picture. I totally forgot about a latch mechanism until I dumped a load of firewood. Necessity being the driving force ya know. So I went back in the shop and added this latch on one side. Then after I noticed the twist I was putting on the box with just one latch, I added a second on the other side. Ultimate goal is a hydraulic dump cylinder after I get rear remotes added to the tractor.
I never noticed the birdhouse smokestack until someone else mentioned it the first time I posted that picture. I couldn't have shot that better if I tried!!! :p
Sweet:) :) Simple and well designed.
JC,
/ 3 point carry all, build or buy? #23
Wow, I'm impressed and also embarassed.
I didn't do a search for/about any carry-alls before I just built my trash hauler//general yardwork assistant yesterday. An I was (still am) so happy to have built a useful attachment out of scrap lumber laying around.
I had to buy two 2lb boxes of screws [one 3" & one 1"] cause I didn't have enough on hand, the angle brackets, and one quart of paint but still stayed under 20$.
But, it's sure not as cool as the metal dumping one is!! Oh well, little steps at a time. Here are some pictures anyhow.
Greg
/ 3 point carry all, build or buy? #24
Greg
No need to be embarassed at all. You used what you had available and workable. I did the same. Looks great to me. You'll use it a LOT!!!
Is that a forklift 3pt attachment on your tractor??? That's slick.
I use my tote box to haul firewood into my shop in the winter. I put the quick hitch on the tractor so I can haul in a load and set it by the stove, unhook the tractor and use it for other tasks. You could do something similar with your fork style attachment. Looks great to me!!!
Update, my shop burned two years ago. My totebox was hooked to my tractor with a full load of firewood. Needless to say the tractor was a loss. But I still use the box. It ain't quite as purty no more. :(
/ 3 point carry all, build or buy? #26
Wow, I'm.... embarassed.
Greg
don't be.
you needed something and built it.
I have plenty of 1-of tools and things I built that have less features than a commercial product.. I needed them and built em and use em.
soundguy
/ 3 point carry all, build or buy? #27
Greg
Heck I like your idea of using what looks to be pallets with your carry all.. You could build a few varieties, one for garden supplies, another for log cartage, etc. Back up, lift it up and on your way...
/ 3 point carry all, build or buy? #28
For me, building something carries with it the satisfaction of having done so, so I will often spend more in materials than it would have cost to buy it manufactured. Other times, it costs me less in materials, but I spend way too much time making it.
When it comes to buy vs. build, in most instances, if you are building something that can be bought, it is usually less expensive to buy. However, if what you are buying would have to be modified to fit your needs, then it can be advantageous to build it your way the first time.
Dave
/ 3 point carry all, build or buy? #29
Ovrszd, Sorry to hear bout your shop & equipmt burning up. I know what that's like; lost my whole place in the '07 Witch Creek fire. Yep, it's a 3 pt lift, same type tool as many pictures I've seen on TBN of carryalls from various places. Mine is a Woods and I use it alot, course that's cause I can't yet afford forks for the loader. Someday! I can probably haul firewood with mine too, but I just gotta be careful loading it in...I'm not as solid-built as your metal dumper!!
Soundguy, Thanks for the kind comment, made me feel alot less embarrassed.
Lovethesmellofdiesel, Yup, it's actually an oversized pallet I got from work. Paper haulers use those bigger ones to deliver paper to our school and I got to looking/thinking and figured hey I can adapt that! It's actually about 1 & 1/2 pallets combined together. It's sure strong enough for my uses thus far. I've yet to mount some brackets to hold shovels, rakes, etc. etc. But I'll get to it soon.
Thanks guys and keep on tractorin' Greg
Edit -- Sorry Ovrszd, I said it was a Woods - I was wrong it's a Gearmore 3pt lift.
/ 3 point carry all, build or buy? #30
For me building mine was mainly for fun and learning to weld but I need one anyway!!! I had planned on using a winch with mine but decided I didn't need it. Mine has a base that is free floating and removable. It also doubles as a sprayer (boom and tank mounted on a wood base). It works as a pallet forks/lifter for my water tank. Also, it carries my ballast, a 55 gallon drum full of concrete (uses a strap to hold it in place).
Thread on the build from 2007: http://www.tractorbynet.com/forums/build-yourself/108680-carryall-twist.html
/ 3 point carry all, build or buy? #31
I opted to build vs buy. Using 2" x 2" x 1/4" angle iron and treated plywood for the bottom, it ended up heavier than I probably needed, but it works well and you could put 750 lbs on it if need be.
I had a 3 point hitch weight bar that I use in the winter for snow plowing and decided to use it as a platform mount. My carry all is large enough for a chain saw, tools, fuel, bar oil, log chains etc. Bungee cords strap it all on.
It has a single pin mount on the Top Link and steel pads that rest on the tapered arms of the weight bar. The result is that I can carry weights on the weight bar and have the carry on at the same time. Having the extra suitcase weights + the weight of the "carry all" really helps keep the rear tires on the ground when grappling logs.
Brewdog
/ 3 point carry all, build or buy? #32
definately make it yourself. i am having a ball making my own implements, at some point i will have to stop because i will have none left to make :laughing::laughing:
/ 3 point carry all, build or buy? #33
As is clear "Pretty" is not on my agenda. I did offer to paint it, (PINK" :laughing:)
But the tractor owner had a fit.
Nice 1/4" steel diamond plate bottom. Way more than he needed, all he has ever carried is a Beer Chest. :laughing:
/ 3 point carry all, build or buy? #34
I like his idea of using a steering wheel to adjust the top link.
/ 3 point carry all, build or buy? #35
i've seen some old toplinks that did have a ring around them for easy adjustments.
i was toying with that idea using rebar as my wheel.
soundguy
/ 3 point carry all, build or buy? #36
I built mine 5 years ago. Been trying to break it ever since but it won't break with my 20hp. It cuts, hauls, dumps and is a superb finish grader with my top and tilt. Couldn't do without it. Can take off the bed and install forks on the main frame or other attachments that will fit in a 2x2 hitch reciever.
/ 3 point carry all, build or buy? #38
I bought mine, structural steel in my area is hard to find now since Potomac Steel closed few years back. It was easier to hadn over the money at TSC.
/ 3 point carry all, build or buy? #39
I’m buying mine from TSC tomorrow. I don’t own a welder or I would attempt to make one. Learning to weld is a goal I have though
/ 3 point carry all, build or buy? #40
I got a used set of 3pt pallet forks - I found these more useful that a dedicated carryall - I have several different boxes built for different thing and I can just back up grab them and go. Just my .02
2013 HERCULES ALUMINUM KILL TRAILER (A60736)
2013 HERCULES...
2012 SOUTHERN 130 BBL VACUUM TRAILER (A60736)
2012 SOUTHERN 130...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A61307)
2006 Heil Tanker...
2008 Toyota Solara Convertible (A61569)
2008 Toyota Solara...
2008 DRAGON PNEUMATIC TRAILER (A58214)
2008 DRAGON...
