Hard start
/ Hard start #1
sdcarter00
Jesup, Ga
2012 CubCadet RZT
Have a Cub cadet RZT that refuses turn over, have to remove air filter and spray starting fluid, then it fires right up! What adjustment do I need to make? Thanks
/ Hard start
It has a Kohler Courage 23cc
/ Hard start #3
Sounds like you have a battery with insufficient CCA, cold cranking amps. Look at labels on battery and post spec's.
The starter is not getting enough power to turn the engine over on the compression stroke. The ether fires faster and pushes the engine past the compression stroke.
Lawn and garden tractor batteries have short lives compared to automotive ones.
If you connect larger battery temporarily (do not use jumper cables) see if it starts.
Newer tractors have flyback diodes everywhere and they are very easy to blow using jumper cables.
Dave M7040
/ Hard start
Dave M7040
Thanks!
/ Hard start
Dave M7040
340 CCA, battery is about 3 years old
/ Hard start #7
When you say it doesn't turn over, do you mean that the starter won't crank the engine or that it doesn't fire? If it doesn't crank, you have a battery, cable, starter etc. problem. If it cranks but doesn't fire until you spray starting fluid, you have a fuel problem. Perhaps the choke isn't closing, the float level is low in the carb, kinked fuel hose etc.
Bob B.
/ Hard start
Bob B.
It cranks, but will not start
/ Hard start #9
I had the same problem with my RZT50. Took it to my local cub dealer 2 weeks before warranty ran out and they fixed it. Apparently there's one to many holes in the choke plate. (Pollution crap) I believe they brazed it shut and it starts perfect now. They will not fix it if it's under warranty.
/ Hard start #10
If you have this model: Cub Cadet RZT 50 KH
Then here is a link to the engine shop manual:
http://www.kohlerengines.com/engines/onlinecatalog/pdf/32_690_01_EN.pdf
Lots of good info there.
This engine uses a pulse type fuel pump. To check operation, remove the fuel line from the carb, point the line away from the engine and then crank the engine. If pump is working, fuel will come out of the hose end.
sdcarter00 - Welcome to TBN
Richard
/ Hard start #11
I know this is old, but I went through this with my Cub Cadet LT1045. I had to crank it for about a minute total, on and off before it would pop off and when it did, it ran great. But on cold start, it always took wayyyy too much cranking. I replaced the battery, fuel filter, fuel pump, and other things trying to figure it out. If I sprayed a bit of gas into the carb and then started it, it would pop right off.
The problem was the fuel cut off solenoid on the bottom of the carburetor bowl. It was toast and block flow to the carb when I turned the key on. I replaced it this morning and after two years of this problem, I have my old lawn tractor back.
The part was $10.50 on amazon.com for aftermarket.
/ Hard start #13
very easy. Just disconnect red lead wire, then unscrew it from the carb with (I think) 1/2" open end wrench. Put the new one in, reconnect the wires and you are done. The original had just a red 12V+ wire that has an in line connection and the solenoid grounded through the body. The new ones have a 12v+ and 12V- wire. The red 12V+ goes to the same in line connection and the 12V- goes to a ground source. There was one right next to the carb that I used. That's it. Done. Once you get the shroud off so you can access the carb, it is as simple as replacing a spark plug really.
/ Hard start
Now I am having trouble finding the part! Lol
/ Hard start #16
sdcarter: Do you mean the new part or the old part still on the mower?
/ Hard start
The new replacement solenoid, it's a Kohler Courage SV720
/ Hard start #18
Chances are good that it would be the same solenoid as I used. I think that one is used on many of the Walbro Carbs.
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
2013 Ford Taurus Sedan (A64194)
2013 Ford Taurus...
Picnic Table (A64127)
Preliminary Listing / Full Catalog Coming Soon! (A62177)
Preliminary...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
Coleman Go Cart, 2 Seater, Gas Engine (A65640)
Coleman Go Cart, 2...
