Help me manage my expectations for this tree puller, please
/ Help me manage my expectations for this tree puller, please #21
/ Help me manage my expectations for this tree puller, please #23
Tree of Heaven is a nasty tree for sure and grips the ground pretty tight. With it's rhizomes I would agree with teg and Oldoak. Kill it first. The best luck I have had is similar to their experience. When encountered I saw (or lop off if small) and any surrounding suckers and immediately cover fresh cuts by painting it with undiluted Roundup (depending on concentration, maybe a half and half mix of water and RU).
Once dead and dry it can be ripped or chopped out with much less effort if needed. Hitting a large green stump with an ax is more bounce than chop. It does seem to like to grow near buildings around here. Dealt with it at other locations, luckily never seen it on my property.
/ Help me manage my expectations for this tree puller, please #24
Please help me understand how big a tree this tree puller will pull out of the ground. Yes, I know that will depend on a great many factors, including but not limited to: tractor size and power, tree species and age, wet or dry soil, etc. etc. etc. I have a ton of that crap Tree of Heaven (Alanthus Altisima) that I need to get rid of. Most of them are in the 2"-8" in size or so.
This tree puller implement is up for local sale. It appears to be a Titan Attachments tree/post puller, see pics and web site:
Titan site: Tree Fence Post Puller Skid Steer Attachment Quick Attach Bobcat Kubota Case
From TractorData. com, here are the specs for my FEL fo my Kubota L4330 tractor:
Loader type: Kubota LA853
Height (to pin): 113.6 inches [288 cm]
Clearance, dumped bucket: 89.8 inches [228 cm]
Dump reach: 20.1 inches [51 cm]
Dump angle: 45
Rollback angle: 40
Breakout force (lift): 3,125 lbs [1417 kg]
Lift to full height (at pin): 2,374 lbs [1076 kg]
Lift to full height (at 500mm): 1,764 lbs [800 kg]
Bucket capacity: 0.5 cu yd [0.4 cu m]
Bucket width: 72 inches [182 cm]
Thanks for your help!
I just bought this exact setup last week. I have mostly sandy and rocky soil in New Hampshire. I bought it specifically to thin out my woods. I have hundreds and hundreds of evergreen saplings that need to be moved. My Mahindra 2538 pulls everything up to 5" out like butter. I've found that if a tree is stubborn, just clamping the jaws on it and rocking it will loosen it up enough to at least be able to drag it out if you can't lift it directly up. Regardless, it beats the heck out of getting on and of the tractor with a chain. I'd recommend it. Look at post #185 here. http://www.tractorbynet.com/forums/mahindra-owning-operating/377997-what-did-you-do-your-19.html
l have a very similar tractor/loader combination(L4240/854).I have spent ten years clearing our over-grown property;manual cutting,hiring large Ag Tractors with big bush-hogs,building a tree shear ect.
Best thing I did was to hire a Skid Steer with a forestry head;he did more in four days than I did in ten years;plus no brush piles.Expensive but finally done.
On the post puller;I would be very concerned with pulling larger trees and them being top heavy and flopping your tractor over(if you were able to pull them at all).
I did that last summer. Was supposed to be for 8 hours of work, but he only got 4 hours due to maintenance and equipment breakdown issues.
Total bust on getting rid of it all, especially the stumps/pungi stakes due to all the rocks we have around here. His forestry head was slinging and throwing rocks like you wouldn't believe. That limited how deep he could go (i.e. none) and that left me with a bunch of pungi stakes. So now everything I go over the area to bushhog it down I risk cutting a tire. :(
Depending on how close the trees are, you could cut each tree with a saw at about 3' dropping it on the ground. Then use the 'puller' to remove the short stalk and root ball. This way you don't risk the bigger trees falling back toward the tractor and you can use the puller to bring the tree to a place to burn or cut into smaller pieces, safely..
I have a Titan tree shear, and it is a powerful tool. It has a 5" diameter cylinder to close it's jaw and cut up to 12" trees, but it needs to be carefully positioned, and wind has to be taken into account, as well as topography to make sure nothing comes back at the operator/tractor. Having a canopy and tilting the shear away from the tractor helps protect the OP, but things can get away from one quickly...
What is the seller asking for the puller and why is he selling it?
Also, if you buy it, put any tree you're pulling as close to the back of the jaw/upright, (fence) as possible to give the most control over the tree you're pulling, and give a downward tilt to the front of the jaw - away from the tractor to provide control over which way the tree leans. Test out the open/close time so you know in advance the recovery time- in case you need to let a tree fall away from you/your tractor as needed.
Uh, how about a big fat "NO!" on that. I'm +62, broken back with shot knees, walking around trying to cut down hundreds of trees ain't gonna be happening! If it was, I'd already done it.
The seller was asking $675 for it and I believe he is a regular farm equipment seller on Craigslist. I called him and he's already sold it but he may have another in a couple weeks or so. That's OK, I'm not in any hurry.
I built a puller. Next to the Grapple, it's most used FEL tool. Wouldn't be without one. A new one locally built here can be bought for $1200.
Here's an example on my old L4400 Kubota.
I built it to also be used on 3pt. Would be very easy to add that modification to the one you pictured.
Ok, good to know. It appears your L4400 FEL is very similar to my L4330 FEL.
And you're right, I can always modify it to work off the 3ph.
Thanks!
Ok, Been here and done it (...and learned a thing or two) If I were to do it again, I would KILL the tree first, paint a 50/50 mix of Garlon4 and diesel on the trunk of the trees. Do it a few times during the year for the first year. Kill what comes up the next year and hopefully you might control them.
What happen to me is that I had a 6 ton trackhoe (friend rented for the week and he had some extra time on it). Took care of the job of ripping out the trees in no time. Pulled the tree up by the roots... no problem. WRONG, Tree of Heaven (From Hell) sprouted all over the place. Each rootlet decided to become a new tree... you would be hard pressed to win this battle. I had to spray a bunch for the next 6 years before I decided, they were all gone. Kill them before the tree knows that you are at war with them!!!
Believe me when I say that... Ripping them out of the ground will just pizz them off...
See my previous post. If walking around and drilling/spraying worked, I would've laready done it. It does work, don't get me wrong: I'm simply not physically capable of wakling around and killing hundreds of trees.
I can however, operate a tractor and puller (coupled with bushhogging them later to keep them down).
With such a variety of locations and tree species this might not be correct guidance. I've pulled thousands of trees. I've never ran across this problem you speak of. Generally the machinery running the puller is limited on what size tree it can pull. In the 6" and down category there won't be enough roots left to allow regrowth. Speaking strictly in Missouri.
teg is exactly right about ToH: It grows and expands by both seedlings and rootings. And it also reacts very aggressively against being attacked or killed.
The plan here is to uproot as many as I can, then bushhog the now cleared area to keep them from coming back up. After a couple cuttings, they will finally die out due to exhaustion.
Another outstanding post! Your 2538 is just slightly smaller than my L4330. The 2"-6" trees are what I'm targeting since they are too big for my bushhog and too many of them for me to walk around cutting/drilling/spraying them.
Thanks!
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2019 BOBCAT E32I EXCAVATOR (A59823)
2019 BOBCAT E32I...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
2023 GMC 1500 Seirra Elevation Crew Cab 4X4 Pick-up Truck (A60352)
2023 GMC 1500...
John Deere XUV825E (A61307)
John Deere XUV825E...
