RTV Hand throttle
/ RTV Hand throttle #22
Works, just pull to approximate rpm then twist to fine tune, to cancel, just push center button.
Awesome, definitely a bargain!!!!
/ RTV Hand throttle #23
I ordered one like this and fabricated a couple brackets to mount it. There is a knock out by the dump lever for the control and it works just like the factory throttle at quite a savings.
VCGTX6 by BUYERS PRODUCTS - CABLE,VERNIER ADJ LKG CONT,6ft
I was wondering about that, as when I saw a picture of the Kubota kit, it looked just like the remote throttle adjuster we had at the rear of a diesel truck I drove for construction work back in the 1980s. We'd use it to rev up the engine before using hydraulics. I suspect any generic remote throttle will do as long as you can adapt the cables/brackets to work.
2016 FORD TRANSIT CONNECT PASSENGER VAN (A59914)
2016 FORD TRANSIT...
New/Unused CFG Industrial QK16R Mini Excavator (A65583)
New/Unused CFG...
2022 EZ-GO ELITE...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
