New to me Kubota L2850
/ New to me Kubota L2850 #1
davedj1
Jackson, NY
Kubota L2501
I drank the orange koolaid Sunday :)
I need advice on what oil and filter to use to change the oil. It looks pretty black but I'm not sure if that's a diesel thing or it's just dirty. I'm going to change it anyway then I'll know. Any idea on how much oil I'll need. He gave me a new air filter which I installed today, the old one wasn't too bad but I had the new one. I dated it and put the hours on it so next time it will be known info.
Thanks,
David
Some details here:
TractorData.com Kubota L2850 tractor engine information
Download this manual "L2550 Ops.pdf" it covers your tractor...
Index of Kubotabooks/Tractor Owners Manuals/
New to Diesels? 5 minute after an oil change, and it looks like it needs it again... 15w-40 is diesel rated.
Best tasting koolaid is the orange :)
Thanks for the tips and yes, I'm new to diesels but had thought that's why it looked so black...lol
I just like to know that it's fresh.
Thanks for the links.
/ New to me Kubota L2850 #4
How many hours are on the tractor? Are you planning to do a full oil change? Motor/Transmission/front axle? I would change out the front axle oil... pretty easy, no filters just slow draining. Replace with gear oil. Transmission usually can last for quite a while...
/ New to me Kubota L2850 #5
L2850 is a solid machine. Friend of mine bought one new in 1986, it's been thru he!! and back between him and his boys, and even me at times. I put a new clutch in it about 3 years ago. Had about 1700 hours at that point, still runs like a top. I'm sure yours will do well for you.
/ New to me Kubota L2850 #6
If you are not using a OEM filter, Napa can pinpoint which filter you need. Many of the older tractors are listed in their books. As far as oil, I used to be a die hard 15W40 fan, but nowadays I am converting everything over to 5W40 synthetic. The cold weather starts are so much faster and less starter wear.
/ New to me Kubota L2850 #7
Orange is some good Kool aid....you need to post pics once you get'r shined up now!
Hey thanks all.
It has the shuttle shift transmission, runs great with no smoke or blow by.
The tractor has 2200 hrs on it, the bucket and cutting edge are in great shape. Over all the tractor is in decent shape, typical scrapes, rust and faded paint.
I'm not sure it can be shined up ...LOL It has a Woods loader on it and a hydraulic top link and a new battery.
I have mixed feelings about the turf tires, they are easier on my lawn (I bought this primarily for moving my firewood) but figure a R4 would probably be better in the woods where I get the firewood. I have chains so maybe the turf tires will be OK.
/ New to me Kubota L2850 #9
Your going to like L2850 :thumbsup: don't forget to add rear light for night use.
/ New to me Kubota L2850 #10
Nice looking machine! Even from a distance it’s easy to see that someone took care of that tractor.
I had turfs on my first tractor and hated them. Having tried most standard tread types (except rice), I find R4 tires to be the best all-around tread for my use. Opinions and use requirements vary widely, so no disrespect to the R1 and R3 folks!
/ New to me Kubota L2850 #11
Hi, Nice tractor good luck:thumbsup:
/ New to me Kubota L2850 #12
I have been amazed what wet sanding and buffing can do. Maybe this will be the machine you can lear on.
/ New to me Kubota L2850 #14
My 2550 is the same case for all. Multiple drain points though if you are changing it out.
/ New to me Kubota L2850 #15
Cheers thanks ,I should have asked on my last post what oil the transmission uses , it has been suggested that it should be kubota udt whick i think will be equivalent to the oil for mf , jd , nh wet brake transmissmions.
/ New to me Kubota L2850 #16
This may get me banned from the site but I just use regular hydraulic fluid and change it out every 400 hours and have had no issues.
/ New to me Kubota L2850 #17
UDT is needed for tractors with hydrostatic (HST) transmission. The L2850 has gear-type trans and hydraulic pump(s) so regular multi-purpose tractor oil is fine.
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
2R ROTARY HOE (A63291)
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2023 Boxer 700HDX Compact Skid Steer (A63109)
2023 Boxer 700HDX...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
