12' Bat Wing With L6060
/ 12' Bat Wing With L6060 #1
SDT
SE Indiana
Multiple Fords and Kubotas
Still shopping for a BW mower and one alternative that I'm considering is a 12' BW so that I could use it with my L6060 if I sell my M9960 at some time in the future.
I've seen the Woods BW 12, the Land Pride RC2512 and have a brochure for the Bush Hog 1812 but will not see one for a couple more weeks.
Yesterday, I learned that the RC2512 is available with the optional self leveling hitch, often specified on 15' BWs. It is my understanding that this feature allows the BW to follow uneven ground better while also making hitching easier for one man. I do not believe that this feature is available on the BW 12 or the 1812 but am not certain.
When I asked one of the nearby Kubota dealers to quote the RC2512 with the optional self leveling hitch, I was told that only the standard swiveling clevis hitch could be used with the L6060 because the vertical distance between the PTO shaft and the draw bar was insufficient and the hitch would interfere with the PTO shaft. I have not been told this by the other nearby Kubota dealer but will ask.
Does anyone have experience with this?
Also, I would like to hear owner's experiences with the so-called self leveling BW hitch in general. Such hitches are universally available on 15' BWs and I may buy one of these. Sometimes the self leveling hitch is an extra cost option.
SDT
/ 12' Bat Wing With L6060 #2
Sorry, no help on the mowers, but I am curious why you want to get rid of your bigger tractor and keep the smaller one? Both are bigger then what I have, and my goal is to get a bigger tractor so I can pull a 15 foot batwing mower. You seem to be the only person on TBN who wants a smaller tractor that has experience with both.
/ 12' Bat Wing With L6060 #3
Good morning Edie and SDT. No make that 2 people. Please see my post about swapping a M6800 for a Grand L5740.....I just made that trade last week. I traded the larger tractor and 15 foot batwing for the smaller tractor and 12 foot batwing. I really wanted a hydrostatic drive.
SDT....I have absolutely zero problems hooking up my Landpride 3615 batwing or my little landprind 2512 batwing. Actually the 12 is much easier. My opinion is that option IS NOT needed.
/ 12' Bat Wing With L6060 #4
SDT,
Tractor envy here. M9960 very desirable machine, would take very high interest rate or family emergency to consider downsizing. Is HST a significant advantage using a batwing mower?
At any rate , Kodiak offers a 15' mower with a 50 hp requirement. Just a FYI for comparison.
I'm 68 years old and will downsize in the foreseeable future.
I use my L6060 with a 6' rotary cutter, which is as large as I can use to mow much of my area due to obstacles and terrain. Indeed, I still keep a VERY good 8N with Sherman combination transmission for use with a 5' rotary cutter in some areas where even the 6' cutter does not do a job good enough to suit me.
The M9960 was purchased to make mowing of my larger parcels without obstacles less time consuming, which will help enable me to stay here longer. I do not need a 90 PTO HP tractor, nor a BW but a 6' mower and comparably sized tractor is needed. When I went shopping for a more user friendly 60-65 PTO HP tractor to replace my MF 2635 (don't get me started) for use with a 7' Woods BB840X mower that I already had, I was planning to buy a 7060 but thought the 9960 to be a better deal.
Having bought, the 9960, I decided to replace the 7' mower, which I never really liked with a mounted, 8' twin spindle cutter, not yet knowing that 12' BW mowers were available. This was attractive as the transport width was small enough to easily move into and out of my barns. I once owned a 10.5' mounted cutter that was both HEAVY, awkward, and did not follow the ground as well as does a BW. I didn't like it much either and sold it last summer.
Once I started looking at 12' BW mowers, which are light weight, I looked also at the much more common 15' BWs because some of them were not too much more expensive than the 12' versions and will likely sell much easier in the future. It seems that everyone wants a 15' BW.
That's how I got here, and am considering a 12' BW only because I could use it with my L6060 in the future after selling my M9960, so long as I do not plan to move too fast.
No, a HST it not an advantage when using a BW. Indeed, it is a disadvantage because it is inefficient.
FWIW: My L6060 uses nearly three times as much fuel to mow the same parcels as my, previously sold, MF 533 (2007 version of the 135) used using the same mower. The HST, FWA and other creature comforts, do, however allow me to finish in less time and with less wear and tear on me. The L6060 also uses much more (probably, twice as much) fuel to mow the same parcels with my 6' mower as does my M9960 uses using the 7' mower in EPTO. Hydrostats are wonderful but inefficient and expensive. They are also not at all tolerant of improper maintenance.
SDT
Does your 2512 have the optional self leveling hitch?
There is no issue using the 2512 with standard equipment swivel clevis hitch with the L6060 (or 5740). It appears that the issue is interference between the self leveling hitch and the PTO shaft due to insufficient vertical clearance between the PTO shaft and the drawbar, and then only when cresting rises, etc.
SDT
/ 12' Bat Wing With L6060 #8
SDT
Sorry, that was over my head I am not sure I understand........but I do not think mine has the optional self leveling hitch. It has trailer lights that I did not ask for.
/ 12' Bat Wing With L6060 #9
I wasn't familiar with a "self leveling hitch" (Land pride call's it a "performance hitch") so I just had to look it up. https://www.landpride.com/ari/attach/lp/public/manuals/330-725m.pdf
The bottom diagram show's it requires 8" to the c/l of the PTO shaft to the top of the drawbar. There is also a 14" dimension from the end of the PTO to the c/l of the drawbar hole.
/ 12' Bat Wing With L6060 #10
I am thinking that your L6060 would pull a 15 foot batwing, but doing so would be all that it could handle, not something that I would do to a good tractor. My M7040 is slightly (very slightly) more HP and the previous owner had a Rhino 15 foot BW that he said he pulled with it. I am not sure that he did, because the hydraulics on the M7040 were not set up to run the BW. I put it behind my JD2555 which is 2wd, and a couple more HP, and it handles it, but knows it is back there. The JD would probably handle it better if it didn't have so many rough hours on it. (70 Hp). Point of all this, stick with the 12 foot if you are going to pull it with the L6060.
David from jax
/ 12' Bat Wing With L6060 #11
A rhino TS12 would be a good one to look at also. As for a 15 footer you need to look at the tongue weight they can be pretty heavy for a smaller tractor.
/ 12' Bat Wing With L6060 #12
David from jax
What do you mean the hydraulics were not set up to run the batwing mower?
Only considering a 15' BW for use with my M9960.
SDT
Good information.
There is only 7" vertical spacing between the PTO shaft and the top of the drawbar on the L6060. I'll no longer consider it.
SDT
David from jax
The L6060 is not nearly enough tractor for a 15' BW and I would consider such only with my M9960.
I would consider only the light weight 12" BW with the L6060.
SDT
/ 12' Bat Wing With L6060 #16
I considered keeping my 15 foot landpride batwing for the 5740....but that batwing is really really heavy. I know the PTO would spin the blades....I mean shoot, I could spin the blades with my hand turning the PTO shaft.....however for traditional use I "THINK" too much....kind of wish I would have kept it to try it first before trading it in.
/ 12' Bat Wing With L6060 #17
Quote Originally Posted by sandman2234 View Post
David from jax
The M7040 does not have enough rear remotes. My JD2555 only has two, so I made a "T" to run the two outer wings at the same time and the center on the other one. I inquired as to what it would cost to install more on the Kubota and it appears about $1800 is what it will cost. I may do it at some point, but for now it keeps the JD2555 busy. The only reason for me to own a batwing is to mow closer to the pond bank up at the Church. Most everything else I do is too tight for a batwing. If my trailer would haul both the tractor and the batwing at the same time, I might haul it to Georgia and mow the property up there but for now a traditional mower works fine.
David from jax
/ 12' Bat Wing With L6060 #18
SDT
Understood, and a very good decision in my opinion.
David from jax
/ 12' Bat Wing With L6060 #19
David from jax
David from jax
My 5740 only has 1 set of remotes and the batwing is plummed to run that way. After it lifts the unit off the ground then the hydraulic fluid is diverted to the wings to fold up. That is why I was asking. You only have to have 1 set of remotes to operate a batwing if it is plumed corectly for it..
/ 12' Bat Wing With L6060 #20
How do the wings float? Seems if you put it in float everything would come down. I guess if you have your height cylinder adjusted correctly with shims it would be ok though
Brett
2015 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2015 Chevrolet...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2012 COMPTANK CORP. 130BBL FIBERGLASS ACID TRAILER (A67714)
2012 COMPTANK...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
2019 Harley-Davidson FLHTP Electra Glide Motorcycle (A66738)
2019...
