   / Your last generator Maintenance Run #1,491
If it is fuel related... only a whiff needed. (Provided it is not flooded)
I have seen people spray what appears to be half a can of the stuff.
   / Your last generator Maintenance Run #1,493
Yup, I've seen engines destroyed with that stuff!
I really don't have any engines around that are in so bad of shape, that they need it, so I don't keep that stuff around...
Best use I've ever seen for a can of ether is, to fire it over a lit lighter, to shoot those guys in shop in the azz, that are always standing around doing nothing!!
SR
   / Your last generator Maintenance Run #1,494
So I have to update my log. Maintenance run not required. We have a power outage. Thankfully she fired right up and is running the well, furnace, sump and some lights no problem.
Wife thanked me for having the circuit for the microwave and one outlet in kitchen wired in. We could make coffee.
Coffee and hot food during an outage :thumbsup: If it's a long one, you will be popular with neighbours !
Snow/ice your way, or just wind ?
Rgds, D.
   / Your last generator Maintenance Run #1,497
The last time I ran my generator was just a test run. I had it given to me and wanted to try it out.
I had it hooked up to the 220 outlet in the barn and fired up the Kubota Tractor. I cannot get all 20 KW's, 83 Amps out of the 3 point hitch Generator, but enough...
So I go in the house and start loading up the generator by turning on high load appliances like our electric wall oven. KABOOM! The common shorted out from the rainstorm the night before that left 3 inches of rain in the ground, and with no ground hooked to the generator it had no where to go but blow one of the resistors on the 110 volt side. It never tripped a breaker or blew the 100 amp fuse as my father was right there to shut it down, but next time I will be sure to ground the Generator first.
Obviously being what it is, I will have a dedicated building for it where it is permanently hooked up and grounded well.
   / Your last generator Maintenance Run #1,498
Rgds, D.
Yeah and with that outlet working we can run the griddle. So could to eggs bacon and pancakes.
Power went out about 439 am and came back on 7 pm.
We just had high wind. Gusts of 50 mph range.
Good reminder about grounding.
Rgds, D.
A bit windy here today, but not that bad...... Mother Nature helping with your maintenance runs !
Rgds, D.
2017 Ditch Witch SK600 Mini Skid Steer (A54865)
2017 Ditch Witch...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56129)
2017 FREIGHTLINER...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
42013 (A51691)
42013 (A51691)
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
