Alternator Belt
/ Alternator Belt
I do believe you should install a block heater or lower radiator hose heater. I would invest in a small Honda generator for those times when you have no power close. I'd never subject my tractor to cold, dry starts in the winter.
Unless you crank your engine over a couple of minutes before starting you are in effect try starting your engine as far as oil flow I use 100 percent synthetic oil ..have no problem with oil flow...? ....
/ Alternator Belt #22
Yes, it certainly appears that you know your Tractor and are not a stranger to winter headaches. Hope you get it figured out.
/ Alternator Belt
Have no doubt That I will , never seen this before during all my years with diesels ... just thought maybe someone here might have an ideal as to what causing this being this is a LS tractor form. ... Some good ideals but so far none has located the issues ....
/ Alternator Belt #24
Alternator spins free also no noise ... Alternator shouldn't get hot when starting engine.
Doing some brainstorming here:
I suspect a bad alternator bearing that doesn't show problems except after a certain degree of side load. Maybe this will work without taking it to a shop to be tested.
Take the belt off the alternator. Put it back on the alternator pulley only with the rest hanging off the side of the tractor. Hold both sides of the belt and pull hard on it back and forth to spin alternator a bit with a strong side load on the bearings.
Or if you can rig up a rubber wheel in an electric drill, use it to spin the alternator while side loading it.
Bruce
/ Alternator Belt #25
What size is your alternator? 50-60 amp or 100+.
If you are pulling the battery way down and then the alternator is maxing out, it would be pulling hard.
Is your alternator pulley polished or glazed?
Is your belt the right width for the pulley? I have seen belts that were to narrow and would run in the bottom of the pulley, if they do they have very limited power transfer, they need to grip the sides of the pulley. If it has a half inch wide belt try a 5/8 width one.
/ Alternator Belt
Book calls for "A" belt did look a bit small for the pulley but that's what came from factory...Don t knothinkw about the amps will check when I place the altnator on a tester this evening...Thinking you may be on to something
/ Alternator Belt
Sorry for the typos dang phone keyboard to small
Do believe you may very well be on to something....
/ Alternator Belt #28
If a belt is too small even if it's set to 'factory tension' it will slip under load, it requires the squeeze of a V groove to create friction, and the groove has 2X the amount of surface area that the bottom of the pulley has, so a wider belt may well cure the issue, I've actually seen this on mower decks where folks have replaced with the correct length belt but too narrow and it will smoke in heavy grass load.
/ Alternator Belt
_called dealer , he is calling in factory rep. Going to test alternator this evening after work ...dealer says it's a 85 amp
/ Alternator Belt
Just got a call back from dealer , factory rep thinks it's the air pump , kind of doubt it being it's not driven by this belt ,will check to be sure , if it was locked parts from it's belt could have damage the fan /alternator belt..seems they have history of getting water in them and locking up when below freezing......
/ Alternator Belt
Air pump had slipped , alternator checked out electrically bearings could still be bad ...next step is to wait for some clod weather and have someone start the tractor while I watch the pump and alternator pulleys ....marked both with paint pen ..waiting on some old weather...when all else fails return to the basics
/ Alternator Belt #32
Short story on the antifreeze. The guy was running straight water and antirust for a while during early fall. A sudden cold snap came one night. He over heated. Ice had formed in the pump. Pulley turned, shaft turned, impelled didn't. Sounded a little similar to your cold weather problem.
I'd pull the alternator off, or at least the belt, and see if there is any wobble to the shaft and that it turns easily.
Done that. Just back from John Deere they say my radiator is the problem
/ Alternator Belt
Only have trouble in cold weather , check with a mechanic ,he thinks something is breaking down in the alternator when dips below freezing , LS has sent me a replacement ...going to install and send the old one to a local repair shop for a full rebuild an see if they can locate the problem.....got to love LS some other brands would have left me holding the bag.....
/ Alternator Belt #34
Hopefully, this will solve your cold weather starting problem. Very odd problem, to say the least. Glad LS is stepping up.
/ Alternator Belt #35
When the belt is slipping get a IR temp gauge and see what pulley is hot. If it is the alternator I would suspect you have some sort of short that is causing the field to be on full at crank. How is that air pump driven? When it won't crank loosen the belt and see if it starts. Then check each pulley to see what is tight. Might be tight only under a load of a bearing is going and binding when a side load is applied but I would think you would feel some roughness. If you think it is the alternator you can pull the connector to the back as well to se if that changes anything
/ Alternator Belt
Dealer sent me a new alternator, problem seems to be solved
Taking old one to shop for repair...
/ Alternator Belt #38
Great news. Please keep us posted on what they find.
/ Alternator Belt
Alternator and water pump are on a common belt .
Air pump his it's own belt
The air conditioning pump has its own belt also and all tree are a diffent size....
/ Alternator Belt #40
Hah, have followed this discussion.
I'd venture a wild guess that the cold shrinks a bushing in the alternator to the point of seizure.
OK, a wild guess but for sure a possibility.
Only 2 things run on that belt. Alternator and water pump and you eliminated the pump.
What else could burn up a belt? also the new alternator now runs OK.
So, sounds like a good polishing of the alternator shaft and or reaming of the bushing would cure the problem.
Generally alternators have a ball bearing at front end with bushing at the rear.
On the positive side it sounds like U have a responsible dealer.
Unverferth 632 (A64119)
Unverferth 632...
2016 FREIGHTLINER CASCADIA 125 T/A DAYCAB TRACTOR TRUCK (A59912)
2016 FREIGHTLINER...
(1) 24X9.50-12 TIRE W/ 5 LUG RIM (A64280)
(1) 24X9.50-12...
Brent 420 Grain Cart (A63688)
Brent 420 Grain...
CADMAN 4500 WIDE BODY HARD HOSE TRAVELER (A63291)
CADMAN 4500 WIDE...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
