Alternator Belt
/ Alternator Belt #1
Kc8ehd
Gold Member
Hinton Wv
LS XR4040C
Got tractor back from dealer after an hard to start when cold issue , was just getting a loud thump when key was turned , if I could get the engine to turn over it would start ..they replaced glow plugs , fuel relays ECU , don't understand why ? And finely they replaced the starter after 6 weeks the tractor was back , first cold morning "CLICK THUMP" ok sounds like a battery to me , replaced battery with a Napa gold ...and it started right up , now to the vbelt ...cold morning and snow had several tries to get tractor to start , glow plug cycle than crank after 5 or 6 times it starts ... notice smoke coming from under hood shut it down ,found broken fan belt of course had to order belt , anyway replaced belts all was fine weather had warmed up and it started every time all seemed well , weather turn cold again go to start same thing 5 or 6 30 seconds cranks to get tractor started battery light came on smoke coming under hood shut it down ...Alternator belt was smoking ... and melted belt crumbs all over alternator.... ( yes it was tighten to spec with a belt gauge) restarted engine to see what was locked up and it started and ran just fine battery light out fan turning , went ahead and use the tractor for about 2 hours ...question is just what could be causing this , alternator ? Starter shorting ?
I'm at a loss I did buy a spare belt hate to change it before I locate what's causing this.
/ Alternator Belt #2
Could be alt or water pump ?
/ Alternator Belt
That's the only two Fuctions of this belt
Thinking alternator that's where most the burnt rubber was , only does this when a hard load is put on battery , never had this problem until starter was replaced ...( May have nothing to do with it but is a suspect)
/ Alternator Belt #4
Take the alt out have it bench tested , spin the fan by hand to check water pump I blow the alt out with air when I clean the front screen always full of dust maybe the bearings are seizing up when it gets hot
/ Alternator Belt
Water pump free , didn't detect any noise
Alternator spins free also no noise ... Alternator shouldn't get hot when starting engine.
/ Alternator Belt
Not for sure will check , deep green in over flow bottle , same as came from dealer two years ago
/ Alternator Belt
Na alternator get harder to turn as load increases , only parts the dealer change was glow plug , fuel relays ECU and starter wasn't doing this before I had it serviced...
/ Alternator Belt
Checked antifreeze minus fortythree ( -43 )
So that's not the problem......back to alternator, bearing going out , voltage regulator or starter shorting
/ Alternator Belt
Could see how no or little antifreeze could cause a problem
Used tractor most of the day with no trouble at all...outside temp in the 30s ....only time I have this problem is when I have to crank the engine more than 5 or 6 sessions
The last time it was 8 degree ...I have used the tractor 10 hours with many starts ( warmer temperatures only had to crank the engine over 1 or 2 times to get it to start....next cold day I have someone try start it so I can watch and see what's happening. Thinking it's most likely a bearing or a bad voltage regulator over taxing the fields in the alternator... just a guess.......thanks for all the replys at least I know what not the problem.....yes I checked each and every one...all were good points
Still looking
/ Alternator Belt #10
Dealer would be down there on his own time to figure out the problem. Looks like he threw a bunch of expensive parts at it though. Hope they weren't on your dime. I do realize that intermittent problems are hard to track down sometimes but that is ridiculous.
/ Alternator Belt
$6000 IN PARTS NO CHARGE BUT ALSO NO FIX
/ Alternator Belt #12
Try running it with the wires off the alt see if it makes a difference
/ Alternator Belt #13
I’d take the belt off and try running it. Keep a close eye on the temperature gauge because you’ll have no cooling.
/ Alternator Belt #14
Very interesting puzzle.
/ Alternator Belt #15
Cycle the glow plugs twice before you try and start it and see if that makes a diffeerence
/ Alternator Belt
I do doesn't seem to help , not really concern about the hard starting when temp is below 20 degree as long as it starts in a few tries ....can in stall a block heater to help in this matter. Some diesels are just hard starting ...
What concerns me is burning off the fan belt..after it starts...there are times when I need to leave tractor where I have no access to electrical power...
/ Alternator Belt #17
I do believe you should install a block heater or lower radiator hose heater. I would invest in a small Honda generator for those times when you have no power close. I'd never subject my tractor to cold, dry starts in the winter.
/ Alternator Belt
I live 3 miles from a main road , during times of of expected deep snow I park tractor at end of drive way don't really have room in car to carry a generator...never had trouble with last tractor.......
/ Alternator Belt #19
Guess you shouldn't get that cold in Wv. Some diesels are just a bear to start and some aren't. I've used propane weed-burners also, to heat things up some. Usually doesn't take much.
Please let us know what you find out about your starting and belt problems.
/ Alternator Belt
Listen real close , tractor will start at temp of 18 below zero
My trouble is alternator locking up after the longer cranking times during colder weather ...lost two belts so far ...and of course have to remove the other two belts to get t o this one.....have never had this type of trouble with any other diesels I have owned ......
2023 KUBOTA SVL97-2 SKID STEER (A65053)
2023 KUBOTA...
2020 Case TV370B (A64126)
2020 Case TV370B...
LOOK! (A63109)
LOOK! (A63109)
2008 JLG 3246ES 32ft Scissor Lift (A64553)
2008 JLG 3246ES...
2022 EZ-GO ELITE...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A64194)
2022 Power Screen...
