haying equipment questions
/ haying equipment questions #1
jerseycows
crown point,ny
john deere 3520
Hello all,
My wife and I bought an old dairy farm down the road a bit and with barn setup, pastures, and hayfields we are going to be in a much better setup for us and our cows. I will have 30-40 acres to hay and already own a JD 3520 (37hp and 30pto hp). I have been researching haying equipment all winter to use with the 3520, and there's not a lot of it. I'm looking at an Enorossi sickle mower (6' double action), Rossi 2 basket tedder, and Case 8420 or Massey 1734 round baler. I already picked up an old JD rollabar rake with dolly wheel. This equipment is all fairly local and I can afford it, tractor and rake are paid for. I would like to get a drum mower with conditioning or a New Holland 472 haybine but can't swing the cash right now. The Rossi sickle mower is the one I have concern for as sickles generally have a less than ideal reputation (clogging when it's thick and no conditioning), but the double action on the newer sickles seems to be an improvement in terms of clogging. I'm not sure what king of grasses I'll be dealing with as another farmer down the road has been haying it for a number of years and I have yet to catch up with him to inquire. He uses a haybine. Any thoughts on these new sickles? Should I not waste my time and money and go for a drum mower or haybine despite that would double the cost
Thanks,
Mike
/ haying equipment questions #2
If you don't have a conditioner you will have a hard time getting your hay dry enough to bale. Unconditioned hay will need 4 good drying days.
Sickle bar mowers can do a good job of mowing but a discbine can also mow much faster.
/ haying equipment questions #3
Have any neighbors you could partner with on putting up your hay? In SE Texas $25 per bale or going in on shares works out pretty good and you won’t have to try and make your tractor do it when it’s not really made for that kind of work
Brett
/ haying equipment questions #4
You are going to be moving pretty slow to run a hay bine with a conditioner but I think a 7' hay bine is your best bet unless you can find a stand alone conditioner. Trying to get hay dried without cracking the stems is a tall order especially if you need 4 solid days of drying to get it done.
Four days to dry huh? That's what salesman don't tell you. Sickle mower is no longer an option, I'll have to find a way to collect myself a haybine or drum mower with conditioning. My neighbor might be able to help me but he works a day job along with running his own farm so I don't feel real confident he could help. I'm also considering a larger tractor because I know the 3520 is kind of small. The mower I originally found was at Salem Farm Supply, I'm guessing Lou knows the boys over there.
/ haying equipment questions #6
Been there once or twice.
A discbine with the flail conditioner will do a good job but they need some horsepower.
/ haying equipment questions #7
If you go with a sickle bar there is the option of a pull behind crimper or pull it in a separate pass. There are some of these still around but for the cost of an old haybine I wouldn't mess with it if your hay is alfalfa or clover. If it is grass hay it will dry in three days - I do that all the time without crimping. If it was crimped it could go in two.
That baler is going to be real tough on your tractor. I would suggest to get an older ag tractor as they are very cheap but are much stronger in the PTO area. A 50-60 hp should do you nicely. that would also run a haybine or discbine.
/ haying equipment questions #8
You are buying a tedder, then you can cut with a sickle bar.
Unless weather is real different between where you are in NY and me in NS Canada, no way 4 days to dry hay. Mowed with a sickle bar for years, never took 4 days to dry hay. Tedder is the key. Cut Monday night, bale Wed afternoon typical.
/ haying equipment questions #9
If I mow on Monday afternoon with the discbine after giving the dew a chance to get dried off, if we tedded Tuesday rake Wednesday noon start baling late afternoon best case on heavy ground with a good yielding grass or alfalfa. Lighter yielding drier gravelly field a day earlier. Not getting conditioned add at least a day from what I've seen and done.
It also depends on the quality of hay you are trying for, late June early July first cut yields high fiber low protein poor digestibility good for beefers not dairy. Depending on regrowth that may cure faster. Trying for high protein high TDN, around here grass needs to be cut before it heads. Which will be late May early June quite often hard to bet the showers with dry hay, A lot of first cutting goes to haylage or now wrapped baleage to beat the weather. Second and third cuttings lighter yields hotter dryer easier to get bales.
/ haying equipment questions #10
Are you keeping or selling the hay? If selling, for the horse market?
/ haying equipment questions #11
You can easily run the 472 haybine. I can run all day in high range. (see attached video). You need a double acting hydraulic circuit for tongue swing and a single acting one for header lift.
2:censored:813 2411 - YouTube
Not sure you have enough grunt to run a round baler, though.
Thanks for the words of wisdom everyone. I would like to get a mower with conditioner and am interested in a Terra drum mower with conditioning from tractortoolsdirect.com or a NH or JD haybine. The drum will cut 4'4" wide at a pretty quick pace and a haybine about 7' and a bit slower than the drum. I like local dealers with a parts department, and I like American products from American companies. Our hay will be for our own use only feeding dairy cows and calves, and my team of draft horses. It sounds like the sickle will work but something about it doesn't feel right. As I type a haybine makes sense because I can upgrade my tractor to it, which will most likely be a JD 4 or 5 series. I've had 3 dealers and 2 owners tell me a Case 8420 or Massey 1734 will be fine with my current tractor. They both require 30hp and make a 4x4 bale. What size tractor is in that you tube clip? It doesn't seem very big.
Mike
/ haying equipment questions #13
Another cheaper option would just be go to silage. You could mow with sickle, discbine, flail, bushog whatever, one day, then use a flail chopper the next day after it is wilted down past the 70% moisture content and put it into a horizontal bunker. It is a lot cheaper, faster, no waiting for drying weather and less equipment to buy and maintain. Heck you don't even need to have a place to store the feed. Just pack it down with your tractor really good, cobver with plastic and weigh it down.
/ haying equipment questions #14
We ran a 477 for years when we had cattle. That and an old roller bar rake with a square baler later updated to a round baler. Parts are plentiful for those old haybines. Just have to keep things in perspective and maintain them. If I was assured parts support for the drum mower conditioner that would interest me.
/ haying equipment questions #15
Mike
I have a similar mower from Small Farm Innovations but without the conditioner. I really like the way it cuts, the limiting factor is how fast I can drive and stay in the seat in my lumpy fields, which is about 5-6 mph. It gives a lawn-like cut. It's been tough so far and if I hit a rock it's easy to replace the blades and they're not expensive. However, an ambitious year for me might be 10 acres. That 4-foot mower starts feeling really, really small when it's time to mow a big field, two acres per hour is a good rate.
I don't have a tedder but I have a rake that has settings for spreading and windrowing. The spread setting leaves the hay standing up. My normal routine is to mow, then spread, dry for 3 days then windrow and bale. Depending on conditions I may spread again. It's very humid here but that seems to make good hay.
I agree with the other posters that you're going to need a bigger tractor to round bale.
/ haying equipment questions #16
Hello all,
Thanks,
Mike
You do not have enough HP to pull a drum mower with a conditioner. A double action mower is a great tool but only in a pristine field with no rocks and debris like branches or trash thrown out. On the other hand, a drum mower will last a lifetime short of wrapping one around a telephone pole. A hay bine is old technology, you'll be done mowing with a drum mower before you can start with a haybine. Your grass hay will have to dryoff before a haybine can be used. A drum or disc mower can mow anytime in any conditions as fast as you can ride in the seat of the tractor. A 165 drum mower can be purchased new in your area for around $3,500.
/ haying equipment questions #17
We have a older Ford 522 5x5 round baler that we run behind our L3830. It makes it work for the last foot or so (we usually stop at a 5x4 round bale), but it handles it.
Aaron Z
/ haying equipment questions #18
I had a Hesston 530 for a little bit that made a 42x48 bale and it spent as much time wrapping twine as it did rolling a bale it seemed like.
/ haying equipment questions #19
We found that if I make 4' bales, I can make a bale in about the same time as it takes my wife to pickup a bale and run it to the barn.
Aaron Z
/ haying equipment questions #20
Hello all,
Thanks,
Mike
You might want to consider a small square baler. I doubt your tractor has enough power to do large round bales. Check with the manufacturer for the min hp requirements for whatever baler you are considering.
Tractor Tools.com has drum mowers that have conditioners on them. I bought a Galfre 190 from them about 3 years ago and it has conditioning plates on the drums. It doesn't windrow the cut hay like other drum mowers so you may not need a tedder. I have not needed one but we have relatively low humidity and or hay dries quickly after cutting.
2025 Spirit Electric Scooter (A61569)
2025 Spirit...
Quick Hitch Skid Steer Attachment (A61567)
Quick Hitch Skid...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
MASSEY FERGUSON 255 TRACTOR (A62130)
MASSEY FERGUSON...
2025 80in. Hydraulic Rotary Tiller Skid Steer Attachment (A61567)
2025 80in...
