Tires Upsized front r4 tires on L5030
/ Upsized front r4 tires on L5030 #1
slowzuki
Elite Member
New Brunswick, Canada
Kubota L5030 HSTC, MF 5455, Kubota M120, Allis Chalmers 7010
My L5030HSTC has about 400 hours on its latest set of R-4 tires which has left the front ones completely bald while the rears just lost their whiskers.
I drive a lot of road miles in the winter, which seems to be hard on the fronts.
The stock 10x16.5 R4's are too small, and the slip ratio is a few % underdriven in the front of these tractors while they should be overdriven.
A friend borrowed my tractor and rolled a tire off the rim, then shredded the tire so I bought 2 new 12x16.5 R4's.
They seem to be just about right in ratio to the rears and theres a little more sidewall to run a bit lower pressure.
Price was right at 155$ each and there is all kinds of room/clearance to the loader frame. Just putting this out there for other L30 series owners with the same stock wonky tire ratio.
/ Upsized front r4 tires on L5030 #2
Good to know, it won't be long before I need to replace my front tires.
/ Upsized front r4 tires on L5030 #4
Is 400 hours typical? Seems like I get more than that but only maybe 25% of my tractor time is loader related.
/ Upsized front r4 tires on L5030 #5
Mine has the originals with 950 hours. I am going to replace them because of a cut, otherwise the still have some life in them.
/ Upsized front r4 tires on L5030 #6
:laughing:
Good - My tractor has 25 hours on it now and it was quite an expense (for me) so I always struggle with whether I should feel guilty running it whenever my return on investment is really quite low - Meaning that I am not directly making money with the tractor - I am doing a project that I think will make my place better (some might argue it was better before I started).
I figure though other than changing oil I really should be good for a lot of years. Maybe the battery at 7 or so years and at my rate sounds like the tires will last a long long time. I figure I will put about 75 or so hours a year on it and that means the engine should last about 75 or so years - Maybe 6000 hours.
I was going to replace the tires on my last tractor when my farmer friend told me they had 1000 hours left in them - I sold it 6 years later and they looked the same - New owner didn't object.:laughing:
The rears are stock, I think they are 17.5 x 24's on all the 30 series when you get R-4's.
The fronts wore off from road use, I'm sure. Tractors that don't drive on pavement, with our soil will have the tires dry rot off before they wear out. My Michellin's on my massey have 4000+ hours on the original rears and 2000 hours on the fronts.
The turf tires that were on my L5030 the first 600 hours looked like new when they were swapped for r-4's.
BTW "Mechanical Ratio of the L5030 is 1.564 with 0-5% allowable lead."
/ Upsized front r4 tires on L5030 #8
:laughing:
Sounds like maybe your grandkids will be the ones buying new tires.:laughing:
/ Upsized front r4 tires on L5030 #9
On solid footing how does it shift out of four wheel drive when using the tractor after changing to the larger tires?
Better than before. Previously I'd have to lift the front tires with the loader, find some dirt or rock back and forth because the front are lagging so much.
Was originally a 3% lag on the fronts as new, before losing the 3/4" tread off the tire. Would bind bad right before replaced.
The new larger tires are a 5.5% lead when inflated. Slightly more than its supposed to be but should fall within spec once they wear. I also tend to run really low pressure on the fronts which shrinks the rolling circumference putting it closer to spec.
/ Upsized front r4 tires on L5030 #11
Read slowzuki's first post again...it's not the hours, it's the road use...tears 'em up.
The road here is chip seal which is extra hard on tires.
/ Upsized front r4 tires on L5030 #13
Whats been the rear's air pressure?
Embarrassingly I don't know. They are loaded to higher than the valve stem so the rims don't rust and I value my tires gauges too much to fill them with CaCl to get a reading.
An off the cuff guess is maybe 15-20 psi? I haven't added any air in the 5 years I've owned the tractor. I've always wanted to lower the pressure to see if it would ride better in the field but I then figured the flatspotting would be worse in the winter.
/ Upsized front r4 tires on L5030 #15
Not to revive an old thread, but I was curious if these 12-16.5's fit on the same wheels as the stock 10-16.5's? I have an L5740 on order, and would be interested in upsizing both the front and rears (12-16.5 front, 19.5-24 rear). I mow on soft ground quite often, but I don't want turfs. I looked on Firestone Ag's website, and got some specs:
size - 10-16.5 12-16.5 17.5L-24 19.5L-24
rim width - 8.25 9.75 15.00 16.00
diameter - 30.4 32.7 48.9 51.5
circumference - 90 98 145 151
The stock L5740 tires are 10-16.5 front and 17.5L-24 rear. I'm not sure if this is the correct way to calculate the ratio, but when I divide the rear circ. by the front for stock sizes, I come up with 1.611. Upsize to the 12-16.5 fr and 19.5L-24 and I get 1.54. So this wouldn't change the ratio as much as just upsizing the fronts and leaving the rears stock (1.47).
I'm just curious if anyone has done this, and if they will fit on the same wheels. BTW, an MX5100 uses 12-16.5 fronts and 17.5L-24 rears. I'm not sure why Kubota doesn't use the larger front tires on the larger L-series?
/ Upsized front r4 tires on L5030 #17
I wonder how the tractor goes in and out of four wheel drive? We have found that the rear tire should should have a flat foot print just like the front tires to engage the four wheel drive easily on hard surfaces. BY running to much air in the rears you are always pushing the front end and of coarse scuffing the fronts casuing premature wear.
Front tires should get about 1500 hours plus of wear when a good balance of air pressure is used, it does make a difference as to when you feel they are worn out!
/ Upsized front r4 tires on L5030 #18
How did you make out overall up-sizing to the 12-16.5 tires? Any issues?
/ Upsized front r4 tires on L5030 #19
Never understood why L series used the smaller R-4 size. My MX 5100 is comparable in size and 12 x 16.5 is the standard R-4 front tire. The footprint of the 10" width would seem to exert excessive ground pressure on improved landscape surfaces, especially in using the FEL, loaded to capacity. Shortsighted thinking on Kubota's part ?. Other manufactures of this
size tractor seem to employee the 12" R-4. (Mahindra, an example) The L series rear tire sizes on L and MX are the same for Industrial Tires.
Yes the original 10x16.5 is way too small for the loader capacity. The 12x16.5 are good, I've got just under 3000 hours on the tractor and wore out two more sets of 12x16.5's. Ran a set of 32x12.50R15 on implement rims for a winter (they have better traction in snow) and now am running a set of 33x15.50R15 intended for all terrain scissor lifts on the wide turf tire rims. They are my new favourite. Work great in soft fields, no deep ruts. Lower pressures that ride nice still support the loader capacity.
The are slightly too much lead just like the 12x16.5, and is more noticeable with rears being nearly worn out now. The pics are from a few years ago when I put them on. Again, the chip road travel is what kills them. My M120 is eating its front set of 14.9x24 as well. The 14.9x24 front Agribibs on my massey are tough as nails and show no appreciable wear still.
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A60736)
2009 VOLVO VHD...
SHOP TOOLS (A58214)
SHOP TOOLS (A58214)
2019 FORD F250 PICKUP TRUCK (A59908)
2019 FORD F250...
2019 VOLVO SD115B SMOOTH DRUM ROLLER (A62129)
2019 VOLVO SD115B...
