L4701 for 100 acres?
/ L4701 for 100 acres? #1
V53
Member
Tennessee
None
I'm trying to decide on our first tractor. We own 100 acres which 60 to 65 of flat pasture and the rest wooded.
Major task will be bush hogging, gardening and loader work.
The L4701 seems like a good choice to start with as an all around general tractor to meet most of the task, and then maybe later down the road upgrade to a larger tractor if we ever start trying to do our own hay.
/ L4701 for 100 acres? #2
GUIDE: Shopping/Sizing A Tractor​
The best way to shop for tractors is to list your tasks first, then determine how much bare tractor weight you need to SAFELY accomplish your tasks. Bare tractor weight is a tractor specification easily found in sales brochures and web sites.
For most tasks greater tractor chassis weight is more important than tractor horsepower. This tractor fundamental is difficult for people new to tractors to comprehend.
Hillside work demands more tractor weight than flat land work. Heavier tractors have greater wheel spread making them more stable. Heavier tractors have larger wheels and tires better able to bridge holes, ruts and logs in the woods. Larger wheels and tires provide a smoother ride over rough ground. Heavier tractors have more tractive power pulling ground contact implements. Greater mass of heavier tractors resists rollovers when transporting heavy loads in the FEL bucket, the most hazardous of routine tractor tasks, especially hazardous on rough or sloped land.
Tractors under 3,000 pounds bare weight are offered in one configuration. Most, such as the high volume kubota standard L series, are prosaically equipped to hit competitive price points. Others, such as the Yanmar YT235 and Kubota B2650/B3350 series, include productivity and operator comfort upgrades as standard equipment.
Most tractors under 3,000 pounds bare weight are operated in residential applications on one to five fairly flat acres. These "residential tractors" fit in a typical garage.
Tractors over 3,000 pounds bare weight are generally offered in a utilitarian configuration and a deluxe configuration, on a common chassis. Deluxe kit enhances productivity and operating comfort ~~~ but you have to pay. Many are too tall to fit in a typical garage, even with ROPS folded.
Shop your weight range within tractor brands. Budget will eliminate some choices. Collect a dealer brochure for each tractor model in your weight range.
I like to spreadsheet tractor and implement specs, often a revealing exercise. I have a column for cost per pound.
It takes a 50% increase in tractor weight before you notice a significant tractor capability increase. It takes a 100% increase in tractor weight to elicit MY-OH-MY!
Selling a used tractor is easy. Selling multiple light implements in order to buy heavier, wider, implements for a heavier tractor is a pain and often a big hit in depreciation. ((Ask me how I know.)) Some who buy too light tractors buy too light implements.
A quality dealer, reasonably close, is a priority for me; less so for others, well experienced with tractors, who do their own maintenance. For most new to tractors a quality dealer, reasonably close, available for coaching, is important. My kubota dealer is six miles away. I feel my local dealer continues to add value to my equipment.
Horsepower is a primary consideration only operating PTO powered implements.
BUY ENOUGH TRACTOR.
/ L4701 for 100 acres? #3
Consider a Kubota 'Grand L' L4060 or utilitarian MX4800 on the same heavy chassis, in lieu of Kubota 'standard L' L4701.
If you will spend a lot of hours in the tractor seat the L4060 will leave you less tired at end of the day. Especially if you are 6' tall or taller.
3,307 pounds, bare tractor (L4701) to 3,527 pounds, bare tractor (L4060), is still on the light side, in my opinion.
Consider the Kubota M60 series too. M60 = 4,387 pounds bare tractor to 5,027 pounds, bare tractor. You will not need to upgrade for hay if you initially invest in one of the M60 tractors.
Cabs are wonderful options but with A/C add $8,000 (+/-) to tractor cost.
Here is a Mowing Calculator: Mowing Calcuator | How many acres can I mow in an hour
I guess upgrade was the wrong choice of words. If I do grow to that point, I'd be looking to purchase a larger M6060 or the 70.
I'd keep the smaller tractor for garden work, trimming around the fences, and mowing the alleyways
/ L4701 for 100 acres? #5
If you compare the physical dimensions, the three are not too much different.
TRACTORDATA LINK: Compare Tractors - TractorData.com
Older tractors almost never receive the TLC newer tractors receive.
If you have two tractors about the same size, the older will sit, the newer will be used.
/ L4701 for 100 acres? #6
Major task will be bush hogging, gardening and loader work...
I didn't read any other comments, I'll give you my thoughts. L4701 is a smaller tractor for what you need to tackle but it could do it, just takes more time. Do you have the free time? I have a smaller tractor, it gets everything I need to get done... just a little slower. (I think of it as "more seat time!") I only cut once a year the whole place...
One thing I would point out about buying tractors, is there is an "ante" of sorts, to get to a certain price point. Going a bit larger later on will cost you more than upgrading now and getting a bigger tractor to start with.
/ L4701 for 100 acres? #7
Me personally there’s no way that size of tractor would be what up I used as a main one for me if I had that much land. I’m not rich by any means but have more money than time and when it comes to mowing, I want to get it done and over with ASAP. I don’t want to do 5acres a day to when I’m done I have to start back over. I would recommend buying a 100hp-ish and a batwing for mowing. It makes things much faster and efficient. A cab is a must for me too. I don’t mind mowing as much now however, I’m almost as efficient as I can make my set up. I have gps to reduce overlap because the more I cut at once reduces my time in the field
Brett
/ L4701 for 100 acres? #9
If I understand correctly, you plan to mow 60 to 65 acres....
If so, one must ask how much time do you have for mowing.
Yes, you can mow 60+ acres with 40-45 HP but you will be spending a great deal of time mowing. Indeed, you can do it with a 25 PTO HP Ford 8N and a 5' mower (I've done it.) but one must really love mowing to do so.
A 40-45 PTO HP tractor will handle a 6' rough cut mower in most (no not all) conditions. Yes, such tractors will handle a very light weight 7' mower in IDEAL conditions and even a light weight 12' BW mower in ABSOLUTELY IDEAL conditions but you will be moving slowly in even moderate cover. Mowing 60+ acres with a 6' or 7' mower takes a long time, especially if the cover is heavy forcing low ground speed. How often do you plan to mow your 60+ acres?
I've spent over 40 years mowing with various tractor/mower combinations in various conditions and I would consider nothing less than 90 PTO HP and a 15' BW mower to mow 60+ acres unless I considered mowing to be therapy, as I once did but no longer do. BTDT.
Currently, I have an L6060 combined with a HD 6' mower to mow my parcels with many obstacles and to cut-in (1 or 2 rounds) my larger parcels. I also have an M9960 to mow the larger parcels. Recently, I've been using a HD 7' mower (sold the HD mounted 10.5' cutter for various reasons) with the 9960. I try to mow as fast as my mowers will cut and clear properly, and yes, in the spring when cover is heavy, the 90 PTO HP 9960 is sometimes HP limited in EPTO with the 7' mower. I'm currently shopping for a 12' or 15' BW for use with the 9960, albeit at considerably lower ground speed and never in EPTO.
HP is like money and (for a young man) women. Some's good and more's better.
SDT
/ L4701 for 100 acres? #10
jeff's boilerplate is good but we could use more info.
Is this for "business" or hobby?
If a business you might want to think a little larger at the outset, like a MX5800.
With 40 acres of wood - what are your plans for that?
Trail building?
Firewood?
Small personal sawmill?
Are you going to keep all the pasture "pasture"? How much bush hogging do you plan to do? 65 acres several times a year or run sheep and just an occasional touch up?
And have you looked at other brands? Kubota is noted for being "light", with other brands such a Kioti being heavier.
Overall the L4701 seems like a good starter choice.
And as far as "If you have two tractors about the same size, the older will sit, the newer will be used." Not true, buy a tractor for every attachment, saves time on hooking up the 3pt :)
I've looked at mahindra, but have decided to not go that route since they're not competitive price wise over my Kubota prices.
I like Kioti but distance and ease to dealer would be worse.
It'll be run as a small cattle farm eventually, which I plan on rotation grazing. The pasture is already padlocked off.
I may have my friend to mow it in hay letting him keep the majority just to keep from mowing it all.
I plan on eventually buying a ban sawmill but more for personal use than trying to saw commercially. Plus cutting firewood for the outdoor boiler
Plus I have a shop that could fit a tractor of this size but not the M6060 that I've priced, so I could keep it out of the weather.
I priced a new M6060 with a cab and loader for 40,000 and some change. Plus a slightly used L3301 with 100 hours on it for 13,000
/ L4701 for 100 acres? #12
Trail building?
Firewood?
Bingo.
I've 8 or 9 user tractors, all intended for a specific purpose. All have implements mounted and I do not remember mounting/dismounting implements in over 10 years.
That said, one would be wise to buy considerably more HP than is necessary to power the most HP intensive task that you anticipate if you have only a single tractor.
SDT
/ L4701 for 100 acres? #13
I would think a tractor like mine would be more ideal. I have a M6800 with a landpride 15 foot batwing. I am actually selling both and going to purchase a Grand L 6060 and a 12 foot batwing. I have shuttle shift but I just prefer hydro. Also, while my acreage is the same as your mine is primarily wooded.
/ L4701 for 100 acres? #14
A small/ short wheelbase tractor will beat you down and find every small hole on your place.
You can still have " seat time" and it will be more enjoyable with a larger/ heavier/ bigger tractor.
/ L4701 for 100 acres? #15
My dad mows about 40 acres. He has a 60 hp cab tractor with an 8-foot HD pull behind Bush Hog. Tractor is the right size for that work, but I'd rather run a 10 or 12-foot cutter and would plan my tractor around that. Of course, 4wd and a loader is a MUST.
/ L4701 for 100 acres? #16
I own a L4701 and I think it is a very good tractor. But I think I'd look for a bigger tractor for a property that size. Rhino does make a batwing that's 12 feet in width that looks like the L4701 could handle if you go that route.
/ L4701 for 100 acres? #17
Which models were you comparing? In my area Mahindra is cheaper than Kubota and seems like a much better deal but I hear so many great reviews about Kubota that I haven't made a decision yet. Would be interested to know if the pricing between the two is area or region specific.
I priced a 5570 mahindra and an open M7060 kubota. The price difference was 2,000 between the two.
That wasn't going to be a wide enough gulf for me to go mahindra over Kubota.
Now I'm focusing on Kioti or Kubota. I did a Google search on dealerships and it didn't bring any near by. I went to their main page and found one as close as the Kubota dealer. So I'm focusing on between them since there's a 6 to 8 thousand price difference between Kioti and Kubota.
/ L4701 for 100 acres? #19
The M7060 Kubota is a very good utility tractor, if a bit light. I shopped it before buying my M9960, deciding on the (larger than needed) M9960 because I thought it was a better deal.
I know little about Mahindra or Kioti, and the jury is still out on both.
SDT
/ L4701 for 100 acres? #20
At a minimum look at the 5E series from Deere. The smaller ones are 45-75hp. They are large frame but lower hp of that makes sense. Utility tractor should be what you’re focusing on vs a compact in my opinion. You could run an 8’ shredder pretty easily with the larger ones or a smaller 12’ batwing
Brett
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
KUBOTA M1066 PIN ON IDR ATTACHMENT (A62130)
KUBOTA M1066 PIN...
(HRS SHOW-11370), EROPS, S/S, HYD TILT, 14.00R24 TIRES, 168" MOLDBOARD, DRAWBAR, S/N-DW770CH578729 (A62129)
(HRS SHOW-11370)...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
