Good morning!!!!
   / Good morning!!!! #70,201
My wife’s reflux had gotten way worse over a period of a 3-4 months, same time she noticed occasional mid chest pain radiating to her back. She insisted it was digestive, it wasn’t. She of all people, should have known to follow up on it, but we all tend to be blind of our own situation.
   / Good morning!!!! #70,202
Tuesday, driving home from work after dark, i noticed my headlights would occasionally flash brighter. Also got a check engine light, code P0142 low voltage. The other thing is my gas mileage has dropped way down.
This is my honda with 350k miles, not sure i want to spend much to investigate. Replaced alternator last yr. Not sure what is causing the lights to flash.
   / Good morning!!!! #70,203
So sad, but often so true.
Bupps, don't let it persist. I have heartburn when I eat certain foods. Bellpeppers. Chili,...I have to go easy on stuff with that.
Prayers for Rip's wife, and for cures for cancer.
I have 3 types of electric powered saws on stands in my barn right now. A tilting bandsaw, table saw, and a 7x12 metal bandsaw. Not to mention my numerous skilsaws.
I still have about five, 3/4" pneumatic impact drivers, 3 or so 1/2" models, and a few 3/8" drive sizes too. Also have about 5 pneumatic hammer/chisels that I rarely use... Yes, I need to off load some stuff.
Currently in my house, I have (working) 3 desktop computers, 2 laptops, 2 iPads (one broken), and 4 cell phones potentially hogging up bandwidth.
   / Good morning!!!! #70,204
Check your battery cables at both ends? Especially the ground.
   / Good morning!!!! #70,205
Check the cables close if they have any corrosion at all could be inside the cable is also corroded and not supplying enough amperage to run things correctly!!
   / Good morning!!!! #70,206
Buckeye, also check body grounds, that many miles bound to have corrosion in places you don't want it. Also, check connectors in wiring harness. Don't forget to check out voltage regulator after checking body grounds and battery cables, it could be faulty.
PJ listened to some of your Antonio Soler, nice. Looking forward to your you tube channel.
   / Good morning!!!! #70,207
Good evening all. 27F for the start, clear sky, light breeze. High temp was 57F, moderate wind, clear sky. WBS duty again today, general putter this morning, got some firewood split for next year this afternoon.
Happy birthday Mrs. Ed!!
Prayers for all.
   / Good morning!!!! #70,208
Thanks. Will check cables this weekend. It starts ok. Thought maybe alternator going out, it was a rebuilt. Or voltage regulator.
Drove the BAT mobile (Big Azz Truck) to work today. It guzzled some gas.
If i wasnt following someone, i probably wouldnt have noticed the lights flash occasionally. I also had the same engine code last week, but it reset itself and went off tue morning.
The battery might be getting weak, but it still starts on some pretty cold mornings.
   / Good morning!!!! #70,209
2018-02-09, 0337
18 right now...high in the mid-20's today.
Bit more snow coming in...with rain.
   / Good morning!!!! #70,210
Get a battery load tester, they tell you what the alternator is putting out. Bought one years ago and it paid for it's self many times over. Amazon has them for $29.99 so it isn't that many $$$$. Ed
2020 NISSAN Versa Sedan (A53424)
2020 NISSAN Versa...
2021 KENWORTH T880 5 AXLE DUMP TRUCK (A56129)
2021 KENWORTH T880...
(50) 12' 2"x6" Boards (A53316)
(50) 12' 2"x6"...
Golf Cart (A55853)
Golf Cart (A55853)
58" 3pt Snowblower (A50775)
58" 3pt Snowblower...
Mitsubishi FGC25 (A47477)
Mitsubishi FGC25...
