Transfer Screws--Making and Using-Pics
/ Transfer Screws--Making and Using-Pics #21
Those screws look like the best approach, but here's another. After the 1st hole is drilled use a laser pointer to the center of the second hole, then install the plate with the first bolt and mark where the laser point is, remove plate, drill and repeat. I've found this to be very successful, especially since it accommodates any accumulative errors.
I like the laser idea. Filing that one away for future reference!
/ Transfer Screws--Making and Using-Pics #22
I used one of my 5 beam lazers transferring a dozen bolt locations (for a skid plate) under the tractor to the concrete shop floor and marked the floor with a pencil. Then it was just careful measuring on the actual 1/4" plate, it worked like a dream!
/ Transfer Screws--Making and Using-Pics #23
I do it the lazy way. Use a tape and make a rough drawing.
Put it into CAD.
Print out at 100%.
Check holes.
Fine tune if needed.
Cut out of 20 ga on the CNC to check fit.
Get a good fit and then load 1/4", 1/2" or 3/4" on the table and cut the part.
Need one or 100, it's just typing on the keyboard.
1 mil+ inches cut, each of the last two years.
/ Transfer Screws--Making and Using-Pics #24
I use transfer screws all the time at work; very handy. The advantage is that they pick up on the thread centers whereas the rubbing and other methods pick out the malformed circle as the thread asymmetrically breaches the plane of the part. If you want to be within say 0.010", transfer screws are the way to go.
Question for the OP, are yours hardened? Nice job!
/ Transfer Screws--Making and Using-Pics #25
I just found about these from another thread after talking about some holes I needed on a plate last summer. Cardboard and hammers is ok for a so so fit, but when accuracy is important like the bolt holes I was trying to get transfered, transfer screws sounds like a simple accurate way to get 6>1/2" holes for 6> 1/2" bolts to fit without using a 5/8" drill bit and a die grinder, the down side would be if one had 10 different size bolt holes to drill, the cost factor might come into play.
/ Transfer Screws--Making and Using-Pics #26
You guys are too fancy for me. I just go buy some pointed set screws when I need to transfer a bolt pattern.
Bruce
Would need to be hardened for actually making a "center punch transfer" but, no, these are left soft.
Bruce
I'm guessing that you use these in an application where the hex is accessible from the backside for installing?
/ Transfer Screws--Making and Using-Pics #29
Screw in with fingers or pliers.
Bruce
/ Transfer Screws--Making and Using-Pics #30
I've never heard of transfer screws... Thanks very much for the introduction...
Looks like your thread has been hijacked....
/ Transfer Screws--Making and Using-Pics #31
Just wondering... why didn't you just drive the tractor over the plate, measure the plate to be square with the tractor, and mark the plate with the laser, using a marker (or a center punch). That way no chance of miss measuring the holes and getting the plate incorrect.
David from jax
/ Transfer Screws--Making and Using-Pics #32
I totally agree with this.
Tractor work typically is with 1/8 to 1/4 inch is close enough, but when making parts for most industries, using that range will make a lot of scrap parts! Shop I worked in for a while had to be temperature controlled building due to the .0005 tolerance on a couple of parts.
David from jax
/ Transfer Screws--Making and Using-Pics #33
If you have the other part that matches to the bolt holes you can use a transfer punch to locate the holes on your new part. Less possibility for slippage if you clamp the parts together. I have punches from 1/8 to 1". Bought on Amazon.
Ron
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
100 GALLON L SHAPE FUEL TANK W/ 12V PUMP (A64276)
100 GALLON L SHAPE...
(2) 3" X 12" HYD CYLINDERS (A64280)
(2) 3" X 12" HYD...
2022 EZ-GO ELITE...
MCCORMICK X4.70 TRACTOR (A64280)
MCCORMICK X4.70...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
