Stumped
/ Stumped #1
T boy
Watertown, Tn
6310 John Deere, 1999
I own a 1999 John Deere 6310 with power quad and reverser with 6900 hours on it. Last year the reverser began clicking out of gear when engaged from the park position. It only happens when coming out of park after the tractor has warmed up and operated for several minutes. Any thoughts?
/ Stumped #2
...Any thoughts?
I would post a new thread in the John Deere section of the forum and give the thread a better title like: "John Deere 6310 - Problem with Reverser".
Even though this reply doesn't answer the question, it does bumped it back up into the "New Post" section so that hopefully, someone with a John Deere background will see and reply to it... Good Luck and Welcome to TBN!!!
/ Stumped #3
Did you change out the hydraulic oil filter?
/ Stumped
I will post in John Deere section. The hydraulic filter is on my list of things to check. I did not mention that it only randomly does this. We might run several days without it happening and then it does and only coming out of park.
/ Stumped #5
G'day had one at work a few months ago doing exactly the same and it was a pressure switch on the bottom of the trans under a cover with four bolts from memory
Jon
2025 Ranger 1000 XP Northstar Premium (A62679)
2025 Ranger 1000...
TEST YOUR BID BUTTON! (A64277)
TEST YOUR BID...
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
set of 4 tractor trailer tires Roadforce (A63689)
set of 4 tractor...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
