Is this pecan log worth anything?
   / Is this pecan log worth anything? #11
I'll go along with that. The Hickory nut and the Pecan are different varieties of course, and the wood, at least around here, is a bit different. Hickory is much harder and more fibrous, at least as far as woodworking is concerned, and look a bit different when finished...both are similar for smoking though. I use Pecan more than Hickory, primarily because I have made use of local sources of Pecan...Hickory is hard to come by here in the central part of the state.
Have you ever used Black Jack Oak? I use it a lot; usually a mixture of Mesquite, Black Jack and Pecan. Don't use fruit woods much, although they are available. They are rather mild in flavor and don't contribute much when you use Mesquite.
Roger that...I am not familiar with "black jack oak"...I find pecan a little sweeter than typical hickory, like to mix it with oak for pork...I like to use post oak for smoking brisket but it is harder to find here than other species...will look for black jack...
   / Is this pecan log worth anything? #12
One of the HUGE misconceptions is, you have to have a clear branch free log to make good lumber!
I have worked with the "so called" defects, to make beautiful furniture...
SR
   / Is this pecan log worth anything? #13
The bark on the log in the picture looks like white oak. All of the pecans I have seen around here have a dark bark similar to walnut.
   / Is this pecan log worth anything? #14
Used to work in a furniture factory for a bit. They made and sold a lot of 'pecan' furniture. I would wonder "who would cut down a good nut tree like pecan for lumber? " That question was solved when I was sent to work back in the 'rough end' for a while....where the raw lumber comes in the door and is worked up into pieces.
It came in the back door as hickory, and left the front door as pecan. Pure magic between those doors.... :D
   / Is this pecan log worth anything? #15
Quercus marilandica - Wikipedia
   / Is this pecan log worth anything? #16
I will remember this, thanks for mentioning bj. oak...like post oak it is scarce around here but does exist...got all the hickory, white, red and chestnut oak I want but I have to buy pecan chips it's not common here in the mountains...in FL I mostly used buttonwood and pecan...until buttonwood (black mangrove) became protected.
   / Is this pecan log worth anything? #17
A guy about an hour North of me has a mill and posts on Craigslist all the time with different woods for sale that he has cut into slabs. I have no idea what he pays for the raw logs, but if you figure out that he needs to make a profit on them, I would guess he gets them for as little as possible.
Mineral Stained Pecan Plank Set - materials - by owner - sale
   / Is this pecan log worth anything? #18
We have a local saw mill that will pick up logs...I think they must be dressed first...haul them to his mill and process them for a 50/50 cut. You come pick up your half.
Well, it sounds like my log is not worth anything except for firewood. I wouldn't mind giving it away if someone wanted to come get it. But if I had to deliver it I would have to charge $1 a mile both ways.
I don't need any more firewood because I just cut down 3 large pecan trees and this one is the smallest one.
   / Is this pecan log worth anything? #20
It's always free to put an ad in craigslist. I tried giving away trees and nobody would show up. I got a few calls, but it was all just a waste of time. Now I don't even bother, I just burn what's not needed for firewood.
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2016 Ford F-150...
UNUSED FUTURE FT36C STAND ON SKID STEER (A54756)
UNUSED FUTURE...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A56129)
2022 BRAZ0 40FT...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A55852)
2003 Pierce Tilt...
