Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #5,301
The snatch block actually needs hooked on that tree if you’re trying to double the pulling power. Then hook one end of the cable to a tree in the direction you’re trying to pull and hook the other end to the tractor.
You can run a single line off of the tree to a safe and comfortable working distance, then hook that single line to the snatch block. A lot easier to rig on the ground than up in the tree.
   / Tractors and wood! Show your pics #5,302
I have a friend who is a tree removal specialist...he has a slingshot he uses for ultimately getting secure lines on insecure leaners etc...I thought what a good possible use a drone might offer for similar tasks...
   / Tractors and wood! Show your pics #5,303
Yep, just gotta be sure that your single line has a working load limit that can handle the doubled force that the block creates.
   / Tractors and wood! Show your pics #5,304
Oh yeah. Put a 5000# line on a 10,00 pound pull and you get a nice slingshot or whip!
Speaking of that type of thing, many years ago my in-laws were getting firewood with a friend of theirs, and they wanted to try and control the direction of fall of a large tree, with a small rope tied to their pickup truck! Well that rope stretched and snapped, came flying back and hit my mother-in-law across both thighs! Knocked her to the ground, ripped her jeans and left huge bruises for weeks. Lucky it didn't hit her in the head or neck. That was the last time they ever attempted to fell a tree.
   / Tractors and wood! Show your pics #5,305
Yikes! The speed of a stretched rope snapping through the air gives you no time to react. She is a very lucky woman.
   / Tractors and wood! Show your pics #5,306
But the use of the block cuts the load on the line in half.......
Add another snatch block & you cut it to a third, that's why you use them.
I can hold a truck in the air if I have enough strands of thread.
   / Tractors and wood! Show your pics #5,307
Not exactly. It increases the pulling strength, but the load on the line is potentially still as high as the tow vehicle can pull.
   / Tractors and wood! Show your pics #5,309
The single line that ties the load to the block is the one that has to handle the full force of the pull. More blocks and lines makes no reduction for it.
Bruce
   / Tractors and wood! Show your pics #5,310
However, we're not talking about that line. We're talking about the line that's attaching the pulley to the tree. That one line will be three times the load on a two pulley rig.
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2016 John Deere 410E 40 Ton Articulated Off-Road Dump Truck (A50322)
2016 John Deere...
2004 JOHN DEERE 5320 TRACTOR (A51243)
2004 JOHN DEERE...
2021 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2021 FREIGHTLINER...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
