float returns to neutral
/ float returns to neutral #1
JMarchant
Littleton, MA
JD 301A
Hi - I have a JD301A and the FEL float mode is engaged by pushing the lever all the way forward. The lever should remain there but instead it always moves back to neutral. To use the float, I have to hold the lever pushed forward so this is not a good solution. In the attached images, the lever in is neutral. When I move it forward there is a detent about half way, when I push beyond this I get the float mode. The second picture shows the underside when in float position - the small rod near the top projects out about 1/2 - 3/4" when the lever is pushed forward. Any ideas if there is an easy fix (or should I just rig some sort of catch to hold the lever forward)? IMG_2110.JPGIMG_2115.JPG
/ float returns to neutral #2
Most valves have the detent assembly built into the valve. JD has good parts breakdown on their website I would recommend looking at that.
/ float returns to neutral #5
I bet your detent spring is worn or needs adjustment/
Many detent assemblies are fixed to the end of a spool with a cap screw, (or socket head cap screw) and the screw loosened up. Does the neutral position seem firm and tight?
You can carefully remove the whole cartridge assembly from the end of the valve body and check that cap screw. Use a pie plate and/or a light colored towel under your work area, and beware of balls and/or springs flying out.
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
2015 HAMM H11IX PADFOOT ROLLER (A64279)
2015 HAMM H11IX...
2009 Cummins DGFA-5764071 150kW Standby Diesel Generator (A61572)
2009 Cummins...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
