/ Harbor Freight Tools that don't suck #8,361
1 MORE THING> I was picking up some air hose that was on sale.. & was thinking, I don't need 50 or 100' of air line to run this little gun.. so I might as well get the 50' & cut it in 2..??
Right above the air line section, on the TOP SHELF were "remnants".. partial left over air lines.. the package said 8-15' air line> $2.25 !!!
That was PERFECT for what I needed..
Did the same thing myself a few weeks ago, and for the same reason. Perfect for when you're doing something from a portable tank and don't really need 25' of hose underfoot.
/ Harbor Freight Tools that don't suck #8,362
That was PERFECT for what I needed. ... pre-made ends & a 300psi burst rate.
Perfect for when you're doing something from a portable tank.
The 8 ft air hose remnants are perfect for lots of applications:
Leave one attached to a spray gun to avoid the lack of flexibility and weight of a coupling and a regulator at the gun - install those 8 ft upstream instead.
In my case I have the compressor in an inconvenient corner with a remnant screwed into the compressor outlet, to get the air supply out where it's easier to hook up. I first did this when I noticed that cheap HF rubber air hoses stress-cracked near their couplers, where the hose bent 90 degrees coming off the compressor. So I considered the remnant was expendable and replacing it avoided the cost of a whole hose. Now I appreciate the convenience.
And of course as a more convenient extension, in place of a 25 or 50 ft hose, when your first hose won't quite reach.
Everybody needs a couple at that price!
/ Harbor Freight Tools that don't suck #8,363
Probably my very first HF purchase, about 15 years ago, was their propane weed burner torch.
Propane Torch
Mine has the orange hose. Back around end of the year I was using it to light off five burn piles at the ranch. It was in low 30’s high 20’s and the hose was so stiff it felt like it was near breaking. I keep hose curled around the top of the propane tank. Trying to get it to uncurl was a job.
I thought, no problem, I’ll go to HF online parts and get a replacement hose, but they came back to me and advised that no replacement parts are available for it.
Closest HF to ranch is about 70 miles each way.
No problem, I’ll just get a new, better hose online. I wanted a longer hose anyway so, I could leave propane tank in the bed of the Polaris Ranger while lighting fires. 10’ would be great. Found a 12’ hose online at at RV Place for $15. Excellent!
Hose received so, I removed the old hose from the burner head. Fitting is 3/8 compression but ........ left hand thread! Whuuut? Now I have a 12’ hose that won’t work. What are these people thinking?
Guess I should have just bought a new torch for $19.99 less 20% coupon. Still would have a 6’ hose.
/ Harbor Freight Tools that don't suck #8,364
My experience with HF replacement parts is buy a new unit. You will have all the replacement parts you need. And maybe a couple for a friend, too! :D
/ Harbor Freight Tools that don't suck #8,365
When I was checking out w/ my HAUL the cashier asked me if I wanted to purchase the "warranty" for, I think> was the sand blaster gun?? 4.00.
I said, "did you just ask me that w/ a straight face"?? The gun costs 20.00!!! NO I don't want the warranty.. Lol it has 1 moving part.. lol
Same thing happened at the mall afew years ago w/ a soldering iron.. it costs 10.00 & the girl asked me if I wanted to purchase the warranty!!
I think the warranty for the "jump box" was 8.00?? & NO I didn't buy that either.. its a battery for gods sakes.. they wear out.
/ Harbor Freight Tools that don't suck #8,366
So, If I have 100' of 3/8" line rolled up on a reel with one end connected to my tank and the other connected to the impact wrench with standard small size fittings I will likely see a significant loss of pressure between the tank and wrench from loss along the way?
When you start "pulling" a large volume of air yes. When you measure it without pulling air from the system, no. Just like electricity. Say your source voltage was 120 VAC. Run it thru a mile of 12 gauge romex. measure the voltage on the far end. It will be 120 VAC. Now put a load on the far end, even a small load like a 60 watt light bulb. It will NOT be 120VAC on the far end now will it? The resistive losses in the one mile will wire will cause a severe voltage drop at the far end. Just as the resistance to the air flow in the hose will cause a loss of pressure at the far end when a large volume of air is drawn thru it. But if you do not draw any air volume thru the hose, the pressure will be the same at each end.
/ Harbor Freight Tools that don't suck #8,367
Harbor Freight Diablo 1/2" x 50' air line, brand new purchased yesterday and installed today. After installing, turned the valve to let air pressure come in and the hose immediately blew up.
Anyone else has Diablo air hose fail?
This is attached to a 155 psi Kobalt 60 gallon 2 stage from about 10 or 15 years ago. 3915.jpeg
/ Harbor Freight Tools that don't suck #8,368
Harbor Freight air line purchased yesterday ... turned the valve to let air pressure come in and the hose immediately blew up.
HF - where final quality control testing is left up to the customer! :)
I had hoped switching to new brand names reflected improved quality. Apparently not, at least for this new Diablo line.
/ Harbor Freight Tools that don't suck #8,369
That reminds me I recently had a bad experience with a Pittsburgh caliper, pictured. I left my good Mitutoyo caliper at the other place and needed something here in Sacramento so went to HF and got this. How bad can it be, I thought to myself. Well pretty bad. The OD side reads about .020 more than the ID side, that is about .5 mm, enough to see by eye.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
BUSH HOG 406-6' ROTARY MOWER (A59823)
BUSH HOG 406-6'...
2014 Ford Explorer AWD SUV (A61569)
2014 Ford Explorer...
GENIE SUPER LIFT CONTRACTOR (A60736)
GENIE SUPER LIFT...
2019 CHEVROLET SILVERADO LD CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
