Heat Pump and power consumption
   / Heat Pump and power consumption #61
Our last month's bill here in central Va is the highest since we've lived here in 17 years. This is with a 3 kw solar panel system that saves us about $50/month. We've 3 heat pump systems. Only one (the biggest) do we allow the heat coils to kick in because it will not keep our family room warm enough with some heat coil assist. We've the upstairs heat pump's heat coils locked out via the thermostat because it is on our generator and would overload it. The basement ductless units do not have a heat coil backup and are the most efficient system we have. All are fairly new.
Ralph
How much was your bill? I am hearing this all over here in KY. Everyone is talking bout how high their electric bills was....basically everyone has exact same story as you......"just received my highest bill in 5 years...20 years" etc. I am still waiting on mine. Father in law's was $700 but his house in a monster and not insulated well.
Mine was $251 and I heat and cool around 5,500 SQ Ft. But the meter read date was 12/27 and I think that is right before the cold snap.
   / Heat Pump and power consumption #62
This thread has got me more curious about my electric Trade furnace/heat pump setup along with an inline Honeywell Electronic Air Cleaner. Checked my breakers... both the furnace and heat pump are 50amp. I pulled the electronic filter and prefilter and washed them with detergent and rinsed are blowing them out with air. They should have been a lot dirtier since I cannot remember the last time they were cleaned! :ashamed: Letting them dry now. I'm hoping this will improve the flow and efficiency as well.
   / Heat Pump and power consumption #63
The sequencer stuck on my heat strips last night. I had the thermostat set on auto and noticed the house felt too warm. Turns out the heat strips were running and the unit had switched to AC mode to try and maintain temp. It was holding at 75 where I had the AC set but it had to be eating some amps. I turned off the heat strip breaker and let it run a few minutes to cool off then shut the whole system down and opened some doors. Weather warmed up to the point I had to turn the AC back on. Unit will work fine with the heat strip breaker off for now. The sequencer clicked open when I pulled the wires to test it and it may work okay but I ordered a new piece anyways. Last time the sequencer failed it burned up my heat strips also but I caught it in time to save them this time.
I wish I could find a thermostat that would allow one setting for heat and AC but they all have a 3 to 5 degree spread. If you put it on auto and set the heat to 70 the AC won't come on till it's 73-75.
I have an old two mercury bulb thermostat and it will allow mechanical changes to the point of overlap where both are running... super simple and requires no power or battery... bet it will outlast me.
   / Heat Pump and power consumption #64
We just moved to N.C. in September and have zero prior experience with heat pumps. This thread has been very helpful as I try to wrap my head around how this system works. Just got my monthly bill yesterday. 1700 sq ft of house built in 1992 with what may be the original system. $157 with an electric hot water heater to boot. I’m not too displeased for as cold as it has been.
   / Heat Pump and power consumption #65
Wrapping my head around them as well. I’d like to clean my outdoor unit once the weather turns better. My indoor furnace is Trane and my outdoor unit is Bryant so it is not a matched set. Once I get it all cleaned up I think I will call a heating/air conditioning guy out to check all the refrigerant pressures, etc.
   / Heat Pump and power consumption #66
When I checked again with the temp showing about 2deg less than the setting, the furnace was on but no heat pump.
The best I understand it at our temperatures now (30s, 40s) your outdoor unit (indicating heat pump operation) should be running anytime your indoor f��urnace is running. Unless it is just cycling down. Otherwise you are just running electric strip heat? Someone more knowledgeable may chime in.
   / Heat Pump and power consumption #67
I've got a 12 SEER, 2.5 ton Goodman heat pump w/10k aux. strips that was installed in my new 1700 sf house 12 years ago. My unit works well as a heat pump down to around 18 - 19F degrees but does have to defrost quite a bit at that low of temps. My strips do not engage when in defrost, under normal operation. We set our t-stat at 74 the beginning of heating season and that is where it stays until a/c season. The only time my aux strips kick in are when the heat pump cannot keep the temp within 2 degrees of the set temp. and then the heat pump continues to operate while the strips are engaged until it gets the temp to the set temp. Then the strips will kick off and the heat pump will continue to see if it can maintain within 2 degrees of the set temp If it drops to 71 degrees, the strips will kick back on and the heat pump will continue to run/defrost until it hits 74 again. I use supplemental wood heat here too so the heat pump rarely engages the strips. Usually early a.m. when the fire has died down quite a bit and it's in the single digits outside.
   / Heat Pump and power consumption #68
I'm still trying to understand my set up. It was installed shortly before we bought the place 10 years ago. I thought I had an electric furnace with aux heat pump that mainly provided A/C in the summer. A/C is something I have never had before living in the PNW. Now I see the heat pump is providing significant heat too. After doing some research on model numbers, I see my 'furnace' is really an 'air handler'. I have some more to learn.
   / Heat Pump and power consumption #69
Anyone who is running a gas furnace with LP gas and straight AC system would basically be pretty dumb not to invest in replace the indoor coil and outdoor unit with a heat pump / coil. Straight AC unit generally takes the same indoor coil from the manufacturer that their outdoor heat pump uses. You might spend a little more for the heat pump unit than an AC unit, but the fuel savings on LP gas is pretty good when you don't have to use your furnace for heating until you hit the teens for outdoor temps. I replaced my Lennox pulse furnace in the attic years ago (straight gas / AC system) and cut my LP bill by 35%. Replaced one more system in the basement with a straight heat pump and cut the bill by 60%. LP company always seems to be trying to make it up to me now with their varying LP rates.
The term "hybrid fuel" is what Carrier coined years ago for dual fuel systems (using heat pump with gas furnace back up for heat).
Needless to say per the first paragraph on savings, this applies when LP gas costs more than electric, which it does around here at least.
   / Heat Pump and power consumption #70
This is what I will be installing next. I have resistive aux heat along with heat pump and when it is time to replace my unit my aux heat will be converted LP and my primary heat pump....as you said....dual fuel. That setup really shines with LP systems. I had a dual fuel at my other house but it was natural gas and that was less expensive that running the heat pump.
DEUTZ MARATHON...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
Deere 310L (A53317)
Deere 310L (A53317)
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
