Scotty Dive
I am posting this to see if the experts here have any ideas on where to look first. I normally would jump right into this and not ask questions until I got in over my head but my tractor is outside and the weather is just down right cold and getting colder so if I can save some troubleshooting time it would be ideal.
So, clearing the snow we received last night and since no good deed goes without punishment, I was assisting two other neighbors with removing their snow drifts, and my 3pt just stopped working and I could not use the back blade. Loader and power steering (Hoye Kit) are all working fine. It just stopped lifting and dropped to the ground. Of course I was able to lift it up manually. The first thing I will check for is if there is some linkage problem, but I spoke to the good folks at Hoye who believe it could have been a failed ORing. That will be the next item, but that seems to be a challenge since it will take the whole tractor out of service until parts are available and put back in. Its been about 50 hours (a year or so ago) since I last changed the hydraulic fluid, filter and cleaned the screen.
Hoye thought it could be o ring 22 under the knob (13)
Any other theories or things to test / check?
