Good morning!!!!
   / Good morning!!!! #68,561
We have Costco here and are members. But we only go there every few months. Sams club chickens are just as good and you do not have to worry about getting run over by disgruntled Costco shoppers. Our Sams club is closer than both Costco’s.
Best day to shop at Costco here is Wednesday 10:30 am.
   / Good morning!!!! #68,562
Rick- Thanks for your reply.
I was surprised that you reported no snow, so I checked on a couple of surface weather maps and saw a map symbol that I have never seen before (or can not remember seeing) down your way:
Dry Line - a boundary separating moist and dry air masses. It typically lies north-south across the central and southern high Plains states during the spring and early summer, where it separates moist air from the Gulf of Mexico (to the east) and dry desert air from the southwestern states (to the west). Moist air mixing with cold can = fog.
   / Good morning!!!! #68,563
46F right now......very light drizzle........will warm to low 50's today.......shop time today.
   / Good morning!!!! #68,564
while CWB was getting snowed on, I was mowing lawn for the last four hours, kinda. 4 hours of sucking up lawn thatch with the tracvac and man am I filthy. Always a cloud of dust. Emptied four huge loads of thatch, real tinder material, dumped it next to my topsoil pile which I will use to push against and scoop the mess up with the FEL and dump it on the burn pile. That stuff will go off like a bomb.
Before that I put down 500 pounds of fertilizer out in the field and that worked quite nicely, ran out just at the end.
Now for a long shower and then maybe start on a tray of beets to plant. Just had a late lunch, a nap is sounding pretty good.
   / Good morning!!!! #68,565
You are right , I'm sorry, I should have added that when referring to the cause and origin of a fire, spontaneous combustion means it starts from an organic source and has an self-heating or increase in temperature due to exothermic internal reactions.
You did not say spontaneous combustion, just spontaneous, but I jumped on the definition of spontaneous combustion. But we still do not know the exact cause of the fire if accumulated oil from past cooks is ruled out. It's odd that oil has to be looked at in an appliance that is advertised as oil free cooking.
To be honest I just wanted to make you all aware and you can draw your own conclusions. I said I could not verify the circumstances.
But I知 also sorry, I wasn稚 having a good day, or week for that matter and I took it out on you.
   / Good morning!!!! #68,566
We should start a pool on how long it'll be before Drew repaints that tractor. I'll give him two weeks from when the weather's dry and warm enough for the job.:laughing:
If, in the meantime, Drew, you decide to spruce up the old paint with some 303 or Wipe New, it'll play heck with any new paint you might try to apply later unless you can get it all off. And I mean really off, as in scrubbing hard with a strong solution of Dawn dish soap, sanding it all with 800 wet'n'dry, and scrubbing it again with the Dawn.
Depends on the weather. :D
   / Good morning!!!! #68,568
Well, no tractor, I stopped to have lunch so naturally I started posting! I got there and a guy was there with a trailer loading the scoop, back blade and finish mower. The owner wasn’t there, I said did you buy the tractor, he says, No, just this stuff. So finally the owner ambles out there and says well she’s all ready to go! I said it looks like most of it already went! Then he says, well, you just wanted the tractor. I said no, we had a deal on everything. Then the generous SOB says it’s OK I’m going to take $500 off. I didn’t even answer him, I got in my truck and headed to KENT Narrows to the Cracker Barrel for some catfish before my BP got out of hand. I guess I’m never going to get a tractor.
   / Good morning!!!! #68,569
The last Windows 10 update sure messed the computer up.
That's a fact! Tremendously slowed the computer down. And then a couple of days ago, Adobe Acrobat disappeared from my computer. I found it online and downloaded the "new" version which still doesn't work right. So I've made an appointment to take this computer to the Geek Squad (Best Buy) first thing Monday morning.
   / Good morning!!!! #68,570
We still haven't paid for a Costco membership, but we do shop a lot at Sam's Club and that's where we get our precooked chickens.
2019 KOMATSU D65WX-18 CRAWLER DOZER (A60429)
2019 KOMATSU...
1979 Ford F-100 Ranger Pickup Truck (A59230)
1979 Ford F-100...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
JOHN DEERE 6430 PREMIUM TRACTOR (A60430)
JOHN DEERE 6430...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
