Mahindra FEL Joystick
/ Mahindra FEL Joystick #1
kgoeke
Springfield, MO
Mahindra 5035
Has anyone else had an issue with the joystick on ML130 loader? Over the weekend, my forward tilt broke and upon investigating, the joystick is connected to a plastic rod inside the joystick housing that connects to the cable that goes to the valve. The top of the plastic rod snapped off. After talking to my local dealer, there are no repair parts offered for these - you have to buy the entire joystick assembly for $475. I am pretty sure this is a KMW loader, but what a poor design and it really reflects bad on Mahindra.
/ Mahindra FEL Joystick #2
If you are interested give me a call, we shoud be able to save you some money on the joystick assembly that you were quoted. 203-393-0642
/ Mahindra FEL Joystick #3
Why should it reflect bad on Mahindra? Other brands use the same design you have.
I am glad my ML275 loader uses all metal rod ends. But they have been known to break also. Over 10 years I have replaced 2 of them. I am lucky cause my dealer keeps them in stock.
hugs, Brandi
It reflects bad because Mahindra will not sell the small plastic part. If you want to make something out of cheap materials, at least make it so the cheap part can be replaced. As is, you have to buy the entire joystick - $475 (plus 3 hrs labor to replace) all because a $5 plastic part failed. I am glad your ML275 loader has metal rods and they can be replaced if they fail.
/ Mahindra FEL Joystick #5
You do understand that Mahindra doesn't make your loader, right? And because they don't, they can't sell you parts produced by another company, right?:sarcastic:
Yes I understand the loader is made by KMW. They can sell replacement parts made by someone else though. They do not make the joystick, but you can buy that. Mahindra is in a position as a very large customer of KMW that they can influence design of the products. If they wanted the joystick to be repairable, they could specify that. They don't because it is more profitable to force the end user to purchase the whole assemby. There are cases of this with every tractor manufacture. I am just pointing out the fact that it sucks. I still love my Mahindra but it will make me think twice in the future.
/ Mahindra FEL Joystick #7
I have an Ansung loader. Can't buy parts from Mahindra or Ansung for the valve itself. The valve is a stock Besko valve. Can't buy parts from Besko, either. If mine dies, I'll replace it with a Brand or Prince. Cheaper, better, parts are available, and it'll take about 45min to replace.
/ Mahindra FEL Joystick #8
Not true.
I broke a plastic piece on the rod for one of the levers on my KMW 3710 back hoe. My Mahindra dealer had 5 replacement pieces in stock. It was $45.00, gold plated, too.
/ Mahindra FEL Joystick #9
Why doesn't it reflect bad on who made the loader? Why doesn't it reflect bad on a buyer not doing due diligence in researching what to buy. Maybe Mahindra could pressure a vendor to make something replaceable with parts, but I am sure KMW doesn't make the valve assembly. So blame KMW for not forcing the valve company to make replacement parts?
Brandi
Oh my Brandi. Can we just agree to disagree.
/ Mahindra FEL Joystick #11
I am not agreeing or disagreeing. I was asking questions. You pointed out it reflects bad on Mahindra. I was taught when you point, 4 fingers are pointing back at you. So one more question.
Do you really think Mahindra can force vendors to force their vendors to make replacement parts?:confused2:
hugs, Brandi
/ Mahindra FEL Joystick #12
Did you ever get your joystick replaced? I was wondering what KMW would say to making replacement parts. Maybe if we (Mahindra owners) give the manufacturers more positive feedback, they can have the replacement parts made? But then, at what cost?
hugs, Brandi
Replaced. Currently working on a 3D printed replacement part to address future failures. Local Mahindra dealer said it is a fairly common issue. New joystick is noticeably smoother. Lubrication may prolong the life of the joystick - not sure if that is in the manual for the loader as I purchased my tractor used and did not receive anything on the loader itself.
/ Mahindra FEL Joystick #14
I would imagine silicone spray would help it stay smooth.
hugs, Brandi
/ Mahindra FEL Joystick #15
You better not mess with my Little Sister Brandi, she shoots a pretty wicked Kimber 45 ACP [ not a measily 357 like I posted in error... ] ...... [[[ :) ]]]
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
1999 Bell B25C 6x6 25 Ton Articulated Dump Truck (A61572)
1999 Bell B25C 6x6...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
