bdhsfz6
Elite Member
- Joined
- Apr 11, 2015
- Messages
- 3,980
- Location
- Northeastern Pennsylvania
- Tractor
- Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
I've found the FEL bucket breakout force to be somewhat lacking on every compact tractor I've used. My experience is mostly with Kubota but I've also noticed the issue on a few JD compacts. I can bury the bucket in a pile of loose soil and easily stall the curl cylinders until I back out a bit. In compacted soil, the problem is much worse. This issue has been discussed here many times in the past but I'm hoping to get some fresh opinions and ideas.
Before I buy new larger cylinders, I'd like to experiment with a pair I already have. They are 1/2 inch larger in diameter than the OEM's on my LA1055 FEL but the retracted length is 10" too long. They would fit if I used a pair of unused holes located farther up the FEL arms:
I'm not certain what these holes are used for except perhaps as a lifting point for installing / transporting the FEL frame.
I realize too much curl strength can damage the FEL frame or even the tractor front end. I'm not looking to pry a house off it's foundation. I'd be happy with just a modest 15 to 20% increase in breakout force.
Any thoughts or suggestions?
