PTO Generator Scoot
/ PTO Generator Scoot #1
BrokenTrack
Maine
Tractors, Skidders, Bulldozers, Forestry Equipment
This is not the most involved build I ever did, but when a friend gave me a 20 KW, 83 amp PTO Generator, I needed to mount it to something. It did not need to be super portable, but movable if needed. My first thoughts were to mount it to an old woods trailer I had, but it would have taken an 8 foot PTO shaft. So after a little thought I realized I could just build and then mount it onto a scoot. I had the wood kicking around from the old sawmill, so i cobbled some lumber up and carriage bolted everything. It looks pretty weak, but actually is rugged in design.
The generator itself needed a wee bit of work because it did not come with a PTO shaft. This old style generator takes an odd shaft size: 1.125 female smooth bore yolk on one end, and a 1.375 6 spline on the other. Of course a person cannot get 1.125 without ordering it straight from the factory...to a tune of $250, so I bought a regular pto shaft with 6 spline on both ends, then bought a new 1.000 yolk and swapped them out. A bit of machining work brought it up to 1.125, then a little grind on the woodruff key, a drill out of the generator stub shaft to 5/16 and a new roll pin and I was done.
Here is a picture of the Generator on a scoot. Not the best picture, and it still needs a coat of paint, but it works. Total cost was $191.00 dollars, not bad for a 20 kw generator.
/ PTO Generator Scoot #2
Is that an Onan? Looks a lot like the 15 K model I had. The chicken farm where I got it, didn't have it mounted at all. Just lying on something to raise it up inside and a hole in the wall for the pto shaft..
/ PTO Generator Scoot #3
Looks good, especially for the price! Outlets and switch are on the other side of the board? Is it 3 phase?
No, it is a Winco.
As for the chicken farm...I suppose, but I was afraid with all that torque, what little bit of feet it had was not much to keep it from whipping around. Apparently unfounded, but at least I can move it around some.
No the outlets are behind the box in the photo, and no 3 phase, but my farm does not have 3 phase here anyway.
/ PTO Generator Scoot #6
I'm trying to figure out what a "scoot" is. From your picture it looks like a 2 wheel cart minus the axle and the wheels.
A scoot is similar to a stone boat, but has a little higher runners. The following photo is NOT mine, but shows a horse drawn scoot. We always had them growing up, but pulled them behind bulldozers and tractors. On frozen ground with snow, enormous loads could be hauled on them. They are also known as a Sledge in some parts of the world.
Because a Generator is not moved a lot, and it would tie up a trailer, I thought a scoot would work well for this application.
/ PTO Generator Scoot #8
In NC we call that a sled. Years ago we put burlap around 3 sides and pulled through the field to carry the tobacco leaves we had just primed (pulled from plants). The back end was Left open to make easier to load and unload.
/ PTO Generator Scoot #9
I thought a "scoot" is what the wanna-b-badazz's called their Harleys?
SR
What KW is that one? I thought it looked a lot like a Winco I think I've got a lead on, but it's self contained w/ a Wisconsin TJD for power.
It is a 20 KW, 83 amp, Single Phase.
keep in mind, it os often the amps that is the limiting factor on generators. A lot of people go by watts thinking they have a lot more generator then they do.
/ PTO Generator Scoot #12
Exactly true. Try explaining reactive power , capacitance , lagging or leading power factor to 99% of the population and they will think they are being scammed.
Another reason why consumer grade generators should not be continuously loaded past 75-80%.
/ PTO Generator Scoot #13
Maybe because 99.5% are not electrical engineers?
I understand what both of you are saying, but with the internet a little bit or research goes a long ways.
My neighbor who lives a very different lifestyle then most of us, and thus cannot afford to put in grid based power, has blown up more appliances and water pumps with his portable generator. They just do not provide "clean" power, that being in terms of frequency stability and not environmental regulations.
Myself that is why I think for the money, the pto generators give a person the best overall power for the amount spent. Someday I hope to change mine over so that a used Reefer Trailer diesel engine can power it instead of my tractor/bulldozer.
