The B2650 count down has begun!
/ The B2650 count down has begun!
I don't think so. I used the 60" one time the week I bought it with a BX25D and as long as I want overly aggressive, the little BX pulled it fine in wet clay. I can't imagine this much larger and much heavier B2650 with 400 lbs of fluid in each tire would have trouble going up a foot. I'm going to try to Craigslist this one and move up to the 6 foot so that I can cover my tire width.
If your using the standard B2650 tires, the 60" will easily cover your width. Since I'm much wider than a B2650 is normally, I'd rather have the 72".
/ The B2650 count down has begun! #62
I will probably go with the 72 also. I am going to get the larger tires. But as of now I don稚 have intentions on running wheel spacers. I seen where king kutter makes a 66 model. But it痴 actually more expensive then the 72 assuming because it is less common.
/ The B2650 count down has begun! #63
You will be traction limited on a B2650/3350 with a 72" box. If you don't fill it too much with material it should be OK, but if you get aggressive it will likely be a problem. I base this on experience with a previous 29HP B model and the heavier L models. I run a 60" box on my L3200 and it's a good match, but even a 60" box will drag on the tractor when filled with a lot of material.
/ The B2650 count down has begun! #64
I do alot of boxblading with my B2650 regrading my property out back. I have rototilled and regraded a couple acres, with a couple more to go. I run a Land Pride
BB1572 box blade. I can run with a full boxblade of dirt, with all of the teeth 3" in the ground also to break up the dirt, and I have never spun a tire. Of course this is in low range and four wheel drive. I did grading for a living, and have used this setup the last few years and has worked out great.The tractor handles it really well. Looking forward to this year as I just installed a double spool valve and top and tilt to my tractor. Just letting you know my experience with my setup on my property. Good luck.
/ The B2650 count down has begun! #65
Looking great, Rock Crawler!! :thumbsup:
Do you think a 72 box
Blade is to much for a 2650?
It's a bit much if you asked me. 66" is a good one to settle on if the width is greater than 60".
I vote for the EA Xtreme Box Blade with lots of Value and Quality packed in!
Travis
/ The B2650 count down has begun! #66
Rock Crawler: Nice looking machine. Thanks for sharing.
You should make some fender extensions to keep the sh*t from flying up on the move.
/ The B2650 count down has begun! #67
No problem going forward or back but be a little careful with R4's on side slopes I found them to let the tractor slide sideways down hill pretty easily, say in snow, ice, wet grass etc.
I had them on my previous B7500 but after a few years I ordered a set of wheels with turf tires mounted because the R4's were nicking up the yard where I turned when mowing. Anyway come late Fall I always took them off and put the meatier tread Industrial's on for dealing with snow. One year snow came before I swapped the wheels so I went out and plowed with the turf tires still on and low and behold the tractor did a lot better in the snow and ice with the turfs. Actually surprised me. So I ordered my B2650 with turf tires, if my use includes a lot of loader work on bare dirt or mud I'd probably have been better off with R4's. I still may pick up a mounted set if I can find them for a good price.
I found the turfs to be fantastic tires for almost everything I need mine to do, even snow and ice. I was surprised since they look like dragster tires.
/ The B2650 count down has begun! #68
/ The B2650 count down has begun! #69
Nice looking fleet, Ted. And it looks like you have tamed a few pallets as well. :D
Looks like a Pittsburgh Stiller game--Well not yesterday :(
I dropped the backhoe yesterday (literally took about 3 minutes) so I'm going to leave it out back for a while since I have the grader blade on so that I can play with snow. Somehow I put 7 hours on it this weekend just messing around in the 10 degree weather.
I ordered a 10 mil tarp on Amazon, 12'x16' Grizzly Tarp with plastic and metal reinforced bungee holes. Good reviews for a $25 tarp. I'll cover the backhoe to keep the sun, rain and snow off of it until it's time to use it again. I really need to hit the lottery so that I can build a large garage. I just don't have any storage space around here to put things inside. IMG_20180115_150557739.jpg
/ The B2650 count down has begun! #72
Yeah a dedicated shed for my tractor and implements would be sweet. Instead (or for now and probably a long time) I put metal roofing up with a slight slope, under my deck and park her under there to stay dry and mostly out of the sun.
/ The B2650 count down has begun! #74
I ordered a 10 mil tarp on Amazon, 12'x16' Grizzly Tarp with plastic and metal reinforced bungee holes. Good reviews for a $25 tarp. I'll cover the backhoe to keep the sun, rain and snow off of it until it's time to use it again. I really need to hit the lottery so that I can build a large garage. I just don't have any storage space around here to put things inside. View attachment 535967
Pole building.
/ The B2650 count down has begun! #76
Well my 2650 is officially ordered!!!
Got a land pride 66 box blade also to get the 300$ rebate. Bad news is it could be over a month to get it... hope it痴 here sooner.
Mine was right at a month. Trust me brother, it's one big, bad, super long month!IMG_20180113_114506192.jpg
/ The B2650 count down has begun! #78
Heck...........you jealous fellows..........I walked right in and bought a B2650 today........just as it was coming out of the crate....Of course, I did not order anything special.....just the FEL and MMM.
But forgot to ask about the $1000 rebate direct from Kubota. Is that true? The salesman did not mention it other than a $300 discount off on one of the attachments... I think i was off the FEL.
Should get it delivered next week.
Cheers,
Mike
The $1000 ended December 31, quarter 1 of 2018 is $300 orange bonus cash.
/ The B2650 count down has begun! #80
Yeah just 300$ rebate.
My dealer recommended I wait until
Mid March and would probably get better rebates. But since I already sold my BX I need a tractor tomorrow. If I was just trading in waiting wouldn稚 be so bad.
2022 Case 5550 Trident Spreader LOW HOUR (A63118)
2022 Case 5550...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
Unverferth RHD1645DG-36 Rolling Rarrow (A63116)
Unverferth...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
