Snow Equipment Owning/Operating Pictures of your snow weapons
/ Pictures of your snow weapons #4,081
Do you have any pictures of the drive line from your mid PTO to the blower. This looks like and interesting set up. Might even work for a front mounted flail or something else.
The mid PTO usually runs at 2500 rpm. Finding attachments or modifying can be difficult.
/ Pictures of your snow weapons #4,082
we received 12" of snow overnight.....been up since 3am moving snow as i have to work this morning. 20180112_034801.jpg 20180112_041233.jpg
/ Pictures of your snow weapons #4,084
Sure wish you would send some of that snow south. Here it is middle of Jan. and I have not had my sled out one time yet.
ive lost count, but i think we've had 48" accumulated since November. we had 120" last season. problem is this year, its 7F one day then 40 a few days later. now there calling for 3 days of rain and 36. it sucks.
/ Pictures of your snow weapons #4,085
Weird weather here down east. After 2 weeks in the "Arctic Vortex", we set a record high temp yesterday of 14.3*C (57.7*F), today my thermometers are reading 16*C (60.8*F) and now there's a Flash Freeze Warning for tonight. All our snow is gone except the remnants of plow banks.
/ Pictures of your snow weapons #4,086
Here are a couple of pictures of my Ferguson TO 30, this year I bought a heater Houser and built the roof, back and side curtains to make it full enclosure. I should have done this many years ago as I was warm as toast in last week's sub freezing weather.20171211_074255.jpg20171211_074310.jpg
/ Pictures of your snow weapons #4,087
Neighbors where happy when I fired the old girl up, did 3 driveways and put her away, took about an hour, nothing fancy, just rear blade for now.
/ Pictures of your snow weapons #4,088
Christmas day tractor supply sale ordered spreader. Changed to more aggressive agitator and it will spread sand/salt mix.
/ Pictures of your snow weapons #4,092
We use walk-behinds in our Boston neighborhood. Our latest is on the right: an Ariens RapidTrack Pro 28 (hydrostatic) with a 420cc Briggs with 21 lb ft of torque. And heated hand grips. :dance1: The Honda is a 928 track, also hydrostatic, with the GX270.
We do three driveways and a few hundred feet of sidewalk most storms.
/ Pictures of your snow weapons #4,093
Not sure where you are in NB, we're West of Moncton. We lost every bit of snow we Had, also lost all the hard pack on our gravel drive! Ugh
/ Pictures of your snow weapons #4,094
Did the same here in Ontario the other day....frozen solid as a rock again now, more snow tonight.
/ Pictures of your snow weapons #4,095
Like Poncho62 said, don't worry, the freeze will return! Here in S. New England we too went thru a thaw and heavy rain and all the snow is gone but the frost is back, the ground is hard and the snow is coming Wed.
/ Pictures of your snow weapons #4,096
Never having used a walk-behind I have to ask - what is the advantage of the tracks? I usually think of agriculture where they are great for traction and flotation but flotation is certainly not what you are concerned about and I would think a grip tire would give you plenty of traction. Plus I would think the tracks would be harder to turn with.
/ Pictures of your snow weapons #4,097
/ Pictures of your snow weapons #4,098
Kubota B2620 with FEL, blower and rear hydraulic angle blade. And the 2004.5 Polaris sportsman 500 H.O. with Glacier Razor quick attach plow.
Both have been 100% reliable and fun to use. Also very low fuel useage. I don't even use the plow trucks at home. This is how I relax.....play with the toys.
/ Pictures of your snow weapons #4,099
I just got a new Honda 928 couple days ago and i can confirm that it is much harder to turn around. Manually that is! With the engine running it's just as easy as the Toro i have, as long as you pull the lever...
It will however push through snow without riding up onto the snow and will push right on through it. The Honda is definitely something to get used to, but after an hour i got it figured out without having any issues.
/ Pictures of your snow weapons #4,100
Haven't used 'em myself, but I can see where they'd have advantages. Key would be reliable and easy to use drive-controls. Until you get into really big walk-behinds, tire-chains for wheeled units are a good idea up here, to deal with the limited contact area of wheels.
Nobody likes to deal with flat tires on anything, but they're esp. irritating on a blower in the dead of Winter..... at 5:30am....
Main downside I can see of track-drive is additional cost. Given Boston snow loads, I can understand spending the money though.
Rgds, D.
8052 (A61165)
8052 (A61165)
2023 VOLVO VNL760 6X4 T/A  SLEEPER TRUCK TRACTOR (A59908)
2023 VOLVO VNL760...
New/Unused Landhonor Transfer Pump (A61166)
New/Unused...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
New/Unused Top Cat Quick Attach Stump Grinder (A61166)
New/Unused Top Cat...
