L6060HSTC Initial Impressions
/ L6060HSTC Initial Impressions
What about a tank and pump for refueling. You can find used ones on Craigslist pretty reasonably. 5 Gallon cans get old when you start filling big tanks.
Regen starts at 100%. The leftmost switch on the left side (sorry don't have the manual handy) needs to be on to allow regen. I don't know if there is a way to trigger regeneration early. I usually go 12-18 engine hours between region cycles. Interestingly, plowing the last 13 inch storm caused the PM reading to decrease without regeneration. Can't help on pins or three point arms as mine haven't been off. Maybe a cat 1 toplink pin and cat 1 to 2 bushing?
Most of my use is off road and its muddy here more than I like. The R4s on my last tractor would load up and get slippery although chains helped some. I went with R1s on this tractor and they are much better off road. Jim
I have considered a tank and pump but the pumps I think are expensive and I worry about having fuel sit over a year not used. I usually go through about 45 gallon a year maybe. I was getting it in the 14 gallon container I had but it won’t work for the new tractor. I see a lot of people using plastic barrels and I suppose I could lift one out of the truck with the loader. Just seems like a pain.
I thought the regen was automatic and that one switch was to tell it to regen if parked?
I wondered if the PM would decrease some automatically if you worked the tractor hard.
I have I think 22 hours on it now which is insane as I have never put that many hours on a tractor in the winter. I forgot how cold it was this morning until I got out of the cab to add fuel. Definitely nice to be able to get work done in the winter now. It will greatly speed up my cleanup around here so I can get these garbage tasks done when the weather is bad and use the warmer weather for more important stuff. Very thankful for that.
Matt
/ L6060HSTC Initial Impressions #42
All regen does is dump in extra fuel that ends up burning to heat the DPF. If you really make your engine work hard & earn it's keep it puts out a lot of heat all on it's own. That heat will help burn off the soot without a full on regen.
How does it determine the PM? Is that a sensor or does it calculate it by runtime/rpms/temp?
/ L6060HSTC Initial Impressions #44
Now you made me pull out the owner's manual :). The tractor is in inhibit mode by default - it doesn't regen unless the operator sets it up. The leftmost button is the auto regeneration switch, when it is on regeneration will happen automatically when PM reaches 100% even if working. The middle button is a parked regeneration button - it allows regeneration while the tractor is parked.
/ L6060HSTC Initial Impressions #45
The early L60 tractors do in fact operate this way. I believe sometime in 2015 (?) Kubota reversed this so that the machine will enter regen by default, and depressing the switch inhibits regen. Sheepfarmer did an in depth write up of dpf operation of the L60 tractors. It’s well worth reading, particularly with parked regens.
/ L6060HSTC Initial Impressions #46
I am waiting for a critical comment on the really cheesy friction lock for 3-Point Postion Control. I modified mine so it will hold. It would be so cheap for Kubota to improve the friction lock.
I do quite a bit of mowing with a Rotary Cutter. I need to adjust the Position Control friction lock fairly often for uniform and optimal results.
/ L6060HSTC Initial Impressions #47
I never use the 3pt lock, but it is pretty poorly made. My only real complaint is the lifting arm leveler. My previous L3410 had a nice crank level for the arm, and the L60’s have that sliding box that is not nearly as convenient.
/ L6060HSTC Initial Impressions #48
Nice addition enjoyed reading this thread.
/ L6060HSTC Initial Impressions #49
I have considered a tank and pump but the pumps I think are expensive and I worry about having fuel sit over a year not used. I usually go through about 45 gallon a year maybe. I was getting it in the 14 gallon container I had but it won稚 work for the new tractor. I see a lot of people using plastic barrels and I suppose I could lift one out of the truck with the loader. Just seems like a pain.
Matt
My L6060 uses a LOT more fuel than my older tractors and hauling fuel cans got to be a problem. I picked up a used 30 gal plastic barrel, mounted it to a simple wheeled cart and bought this cheap $25 hand pump:
Ironton Cast Iron Rotary Hand Pump | Rotary Pumps| Northern Tool + Equipment
At first, I loaded it in my pickup and filled it at the local gas station from their off road diesel pump. Like you said, it got to be a pain. I took a tip from my diesel mechanic neighbor and began filling the barrel with #2 fuel oil from my 550 gal oil burner storage tank. I checked with the Kubota dealer who said he couldn't "officially" recommend doing this but he said a lot of his customers do it. Kubota says to use ultra low sulfur diesel fuel. According to the fuel oil delivery company, the oil they sell is now by law, ultra low sulfur. I filter it before putting it in the tank and I've never had a problem. I guess it isn't an option though if you don't have oil heat.
/ L6060HSTC Initial Impressions #50
Absolutely agree!!! I thought the 5240 was poor but the 5460 is even worse. It wouldn't be acceptable on a cheap video game never mind a premium tractor.
To the OP, I haven't kept track of my fuel consumption but with a 6060 you may find yourself using more than 50 gallons a year. 5 gallon cans may not be much fun when you need to fill the 13 gallon tank.
I finally hit 100% PM yesterday. I knew it was going to happen so I had my phone handy to make a video of the process. After some frustrating time of getting a 3 minute 30 second video on YouTube, I finally managed to get it uploaded (Internet in WV is a joke).
So for anyone curious of what the process looks like start to finish, here it is:
Kubota Grand L Tractor Automatic Regeneration - YouTube
The only thing I noticed during the process is the exhaust smelled a bit different, so I can definitely understand why you would want to inhibit the process when you are indoors.
I decided to clean out a ditch by our driveway while the process was ongoing and kept monitoring it each time I got back in the cab to move the tractor. It took no more than 15 minutes and about 1/5 gallon of fuel and was pretty much hands off. I had 23.5 hours on the tractor when it performed the regeneration process.
Matt
/ L6060HSTC Initial Impressions #52
I apologize that I have not read this entire thread, but I saw the title and want to add my first impressions of my L6060
I've had the tractor since October, but had only 27 hours on it mostly moving it around my yard and a little dirt work on a landscape job. It did regen once while I was moving equipment around the shop.
Yesterday, I spent 10 hours on it pulling a 7' plow. I plowed 10 acres twice in about 10 hours.
When I started, the PM % was at 22%. This is the indicator of when it will regen. I'm not sure what "PM" stands for, but when it hits 100%, it will regenerate. After about an hour, it had dropped to 15%. By the end of the day, it was back up to about 45%
Also, when I started the day, my fuel consumption was at about 0.8 gal. per hour. When I refueled, I reset it and by the end of the day, it was at 1.7 gph.
PM is particulate matter. I wonder if they sense it or calculate it based on RPMs and load. I’ve noticed the same if I have the RPMs up high sometimes it will go down.
I can’t recall what my current fuel usage is other than if diesel were alcohol it would be considered a dangerous alcoholic. I may end up having to get a small fuel tank with a pump. It seems to use quite a bit more than my last NH but it was gear driven. I haven’t done any serious work with it yet other than loader and backhoe work because of the soft ground here due to some flooding we had at the middle of winter.
Matt
/ L6060HSTC Initial Impressions #54
A regen dumps extra fuel into the DPF (Diesel Particulate Filter). That litteraly burns & bakes the particulate matter (soot) out of the filter. If you make your machine work hard it just naturally gets hot & bakes the filter in a similar matter cleaning things up as well.
My 32hp L3200 was burning close to a gallon an hour when I pushed it. 1.4gph or whatever is noticeably less than double the fuel consumption for double the power.
So I have not updated this thread in a great while. Thus far I have used the BH92 backhoe, LA1055 loader (with bucket, forks, and EA grapple), Woods HC60 rotary cutter, and Woods BSM84 7' box blade with the tractor.
My greatest pain point has been the BH92. The relief valves started leaking massively, and it had to go back for service. They supposedly switched a hose and added a tee somewhere. It now doesn't spray fluid every where, but it does leak fluid while I am using the third function. So it has to go back later this year for repairs on that. Also, today I started a new thread about the power beyond hose getting hit by the three point lift rod adjustment square tube and damaging the hose. It seems the engineering around adding the BH92 to this tractor was amazing, but a few things were unfortunately missed. However, the backhoe is an awesome productive tool to have.
At one point I lost about 5 gallons of fluid from my third function line under the tractor. The fitting apparently came loose while I was mowing. I am still unsure if I hit something with it or it just vibrated loose. I did manage to hit a stump that somehow the front axle missed and the support under the fuel tank got. However, I don't think it hit the third function line or it would have bent everything associated with the parts underneath for the third function.
The cab is awesome. I can work longer, in hot or cold weather, and never get dirty. The only downside is not being able to hear the normal tractor sounds, but I'm fine without. I did a lot of box blade work today and it is very dry and the entire machine was covered in dust, but I was not. I can also cut closer to the edges of my fields without worrying about bees, which I already ran into once. When you see a bunch of those suckers tapping on your windows you really appreciated the cab.
The R4 tires have no issues with the box blade but to be fair I did not have the scarifiers down. However, I don't think it would have an issue. However, if it is wet, they will slide, and if it is mud, you are screwed, especially if trying to go up hill. I don't care for the R4 tires when cutting, but they definitely tear the yard up less so I just mowed the yard a couple weeks ago with the rotary cutter because I was honestly too lazy to get the riding mower out and the ground was very hard. The one thing about the R4 tires is they pack the ground hard and don't loosen the dirt. This is great when doing dirt work like I was doing today with the box blade. It compacted the dirt I moved with the blade very hard which should help with runoff tomorrow.
The tractor had no issues in low low or low high with the box blade. Honestly I wouldn't go faster because if I hit a stump it would probably break something. The cutter I think I was doing medium low about 4mph at most in thick brush. The tractor didn't bog down but a few times in really thick stuff. The HST is very nice for work all around. I was surprised at how well it handled the box blade without getting warm today.
The fancies of the L60 are very nice, such as the low/high HST lever on the dash. I am thankful for the electronic HST because it is much less fatigue on my legs and knees and I can work a lot longer without having to get out and walk around.
I performed the 50 hour maintenance which was pretty straight forward. I did not change the main HST filter, only the HST transmission filter, because the main HST filter dumps the fluid and I didn't want to do it at the time. I will wait until I have about 250 hours to do the main filter (Kubota calls for 400 hours), since at 250 hours I have to change the HST filter again anyway.
The tractor came with a variety of pins for the three point which no one explained what they were for.
Here is the low down. Here is what I received:
One setup of these is for cat 1 implements which has the bushings to go to the cat2 setup on the tractor:
One setup of these is for cat 2 implements:
One pin is to hold the drawbar in (I have a swinging drawbar but the dealer gave me back the standard drawbar that came with the tractor, so here is what it looks like with that pin):
And one is for the implement on the drawbar:
The three point goes on very easy and should come off very easy. The BH92 was very simple to remove. I have not removed the LA1055 loader as I have no desire to ever do so.
Here is one project with the backhoe, 2' ditch for french drain and gutter drain around my barn:
The ditch was so easy for the backhoe to dig. It was very quick to get my gutter drains done with it.
Here is another picture with the backhoe on that project:
And this is my latest box blade project:
I did a lot of leveling in the pasture but more importantly had to make the water drain towards the french drain ditch I put in a couple months ago. Prior to doing all this the ground was just full of hoof prints, and when it rained it was a slosh mud mess that took literally over 2 weeks to dry. I am hoping I got the slope correct this time to get things draining towards the french drain I just put in. I expect I'll have more work to do later but I need to determine how the water flows in the next rain.
The only other concern I have is when I go up hill the steering gets hard to turn. I have read where others have had similar issues and would be interested in hearing from anyone with the same issue and if there is a way to fix it. I swear it feels like it runs out of fluid. I sometimes wonder if the intake for the steering is sucking air from the hydraulic tank or something. Sometimes at low RPMs the steering is difficult as well. That is somewhat to be expected, but it just gets weird sometimes when it feels like it doesn't want to turn. However, the biggest issue is definitely going up hills. It really sucks when mowing, and is kind of scary on the hillside.
Overall I am very impressed with the tractor. I am hoping I can get the backhoe issues all resolved.
Thankfully my dealer has been good to resolve any issues. From the horror stories I read from others on the forums and various YouTube videos, I am very pleased with the dealer I chose. All the parts for my 50 hour service they had on hand and were the same price or slightly less than Messicks. I used them for comparison since they do so much business and figured the prices should be close to Messicks' to be fair. I somewhat feel like all the issues have been Kubota issues thus far. The only exception has been the leaking loader nut that I had to tighten, the forgotten defroster switch, and maybe the third function line nut coming undone. But to be fair all that is minor stuff that anyone could miss with so much that goes into the build of the tractor.
That's my thoughts today. I just wanted to post an update since I haven't updated the thread in a while.
/ L6060HSTC Initial Impressions #56
Put a shop vac over the hydraulic fill port & you wont loose more than a few drops over what's in the filter when you pull the filter.
Only 1 of the 2 filters is suppose to be replaced at the 50 hour service. I'm a few hours past 200 & need to replace the other one. I'd use the shop vac trick but the manual calls for replacing all the fluid... I think. I'm a little low on fluid h might have just gotten a 5 gallon pail of SUDT2 to top it up & still have some to spare. Need to double check the manual.
2003 GRADALL XL330 HYDRAULIC EXCAVATOR (A59912)
2003 GRADALL XL330...
2019 PETERBILT 389 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 PETERBILT 389...
2019 JCB 3TS-8T High Flow Compact Track Loader Skid Steer (A61572)
2019 JCB 3TS-8T...
Caterpillar 966C Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 966C...
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
