Lunar Rover
/ Lunar Rover #21
If you had a room with a vaccume and released an air filled balloon, would it propel itself?
Absolutely. But you didn't say the room had no gravitational forces. So this room would not be an analogue for deep space. The balloon would fly about the room and fall to the floor. But it would not fly like it does in an air filled room as the lifting surface of the balloon would not come into play here as it does in an air filled room.
Also if you blew up the balloon in air pressure and then put it into the vacuum chamber it may burst as the air pressure inside the balloon would inflate it further in the vacuum.
/ Lunar Rover #23
In this clip from 'The Martian' at about the .30 mark the protagonist punctures the glove in his space suit and uses the pressurized suit like a thruster rocket to propel himself close enough to be rescued...(FWIW the writer is very keen on keeping all the science in his stories authentic)
The Martian (215): Mark Rescue Final Scene - YouTube
/ Lunar Rover
I can see if you eject mass, there is an opposite reaction. But thrust isn't mass. At lease not very much except in the medium comprising that thrust.
/ Lunar Rover #30
If you removed the shot and wad most of the powder won’t burn and the primer isn’t strong enough for you to feel anything. If you left the wad most of the powder still won’t burn.
And for darn sure it wont activate any automatic action of any kind or cock any internal hammers. and will leave a mess of unburned propellant particles to clean up.
/ Lunar Rover #31
So Industrial Toys, are we all good ?
/ Lunar Rover #32
Think about it this way... no air involved.
In space, rockets zoom around with no air to push against. What's going on?
Rockets and engines in space behave according to Isaac Newton's third law of motion: Every action produces an equal and opposite reaction.
When a rocket shoots fuel out one end, this propels the rocket forward no air is required.
NASA says this principle is easy to observe on Earth. If you stand on a skateboard and throw a bowling ball forward, that force will push you and the skateboard back. However, because your weight on the skateboard is heavier than that of the bowling ball, you won't move as far.
That's the challenge engineers face when designing space engines. Yes, a small amount of thrust does push the spacecraft forward, but it often takes a great deal of fuel to get going anywhere quickly. More fuel means more weight, which adds to the cost of a mission.
from here: How Do Space Rockets Work Without Air?
/ Lunar Rover #33
I'm having a hard time understanding that. If I push my hand out quickly into the air, I don't go anywhere. Push it against a wall and different story. Same with a jet ski. Feed it some water when the jet isn't submerged and it won't have (much) forward movement.
Doesn稚 work that way. Push your hand against something that weighs 200lbs .
/ Lunar Rover
I thought about it and take back the jet ski remark. With that kind of MASS, a jet ski would operate in the air if supplied by water. Witness hanging onto a fire hose!
So my question still stands. How does Rocket exhaust constitute MASS? You are not firing bowling balls out the end of the spacecraft.
And you James, said so yourself. Take the projectile out of a gun and you have appreciably no more action/reaction, aka "kick".
/ Lunar Rover #35
Rocket exhaust consist of a considerable mass. All of the thousands of pounds of hydrazine (one type of rocket fuel) and oxygen combine in the rocket nozzle and every bit of that mass is blown out the back of the nozzle in the gaseous state. When you burn matter in a fire , you do not destroy it. you simply transform it. Matter is neither created nor destroyed in a chemical reaction like a "fire" for instance. Lets say you take a stick of wood that weighs 10 pounds. and you burn it as completely as you can. You will have an amount of "ash" or that chemical part of the wood that that will not oxidize like heavy metals for instance, and you will have a large amount of combustion gasses given off. The mass of all of the gasses and all of the Ashes PLUS the amount of oxygen will add up to more than 10 pounds because of the oxygen added to the chemical reaction. You might be hard pressed to collect and weigh all of the components in a fire, but trust me that is what happens. And trust me again when you see an old Saturn 5 lighting off or the space shuttle or what ever there are tons and tons of mass thrown out those rocket nozzles.
/ Lunar Rover #36
We are going to need to get these basics about thrust and mass down before we start talking about theoretical things like Alcubierre warp drives and such. Industrial Toys, are you with me? Or do we have a ways to go..
/ Lunar Rover #38
Since this thread is basically about moving in space etc...and it's o/t anyway...
What about UFOs?
I've personally never seen a UFO...but have read and heard about a lot of folks that have (not just fake crap like bigfoot etc.)...
You hear a lot of reports about the speed and maneuverability along with the lights/colors etc...but you never hear anything about exhaust trails etc or anything exiting the vessels...no glowing ion trail or radiation streams etc., etc...
Any thoughts on out of this world propulsion systems that would allow something to move with speed and in ways unknown to humans? (or terrestrial humans anyway)...
/ Lunar Rover
Zero Point Energy? What do I know?
I like to see stuff demonstrated although I know even that means little.
Of all the spacecraft and satalites, you know (apparently) there isn't a single photograph of Earth? Don't believe me? Look into it. Some stiched together and filled in ones from satalites. That's it!
And why does the UN logo use the flat earth map? All very strange!
/ Lunar Rover #40
Are you kidding? Tell me you are not a flat earther?
Unused 2023 Maybridge M79 3 Point Hitch Carrier Chain Harrow Lift Tractor Attachment (A66734)
Unused 2023...
2017 CATERPILLAR 249D SKID STEER (A65056)
2017 CATERPILLAR...
2014 TROXELL 130BBL VACUUM TRAILER (A67714)
2014 TROXELL...
2018 RAM 5500 FLATBED (A67714)
2018 RAM 5500...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
Kubota L4740 Grand L HST Cab Tractor
Kubota L4740 Grand...
