Auto Throttle Control
/ Auto Throttle Control #1
Kubota 2350
Michigan, In The Thumb
2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM
Anyone use the auto throttle control on the Ehydro, tried it while plowing snow yesterday and not sure if I like it or not.
What do you guy's do?
Anyone have a JD tractor with auto throttle?
If so do ya ever use it?
/ Auto Throttle Control #3
I had a Kubota with auto throttle. I didn’t like it. I prefer to adjust the throttle manually. My biggest complaint with it was it pretty much kept the tractor at 2700 rpm.
That's why I was asking, seems to really rev the engine when you press the peddle.
I usually run the engine at 1800 to 2000 RPM while using the tractor.
Thanks
/ Auto Throttle Control #5
Another problem is it doesn’t fit how a HST is supposed to be driven. When the going gets tough you need more throttle and less pedal. Not less throttle and less pedal.
/ Auto Throttle Control #6
I use auto-throttle when pushing heavy snow;I plow my woods road about 1/2 mile long with an 8ft.front FEL mounted plow.The way I under-stand it;it up's the throttle and lowers the gear ratio in the HST.Seems to work well,never stall the tractor when using it.
/ Auto Throttle Control #7
The auto speed setup up on the TYM tries to maintain engine rpm by slowing the wheel speed, I use it when the cruise control is set. Problem I have is it takes to long for wheel speed to return. It's most noticeable during heavy grass cutting, therefore I only use it when the grass is beening maintained regularly, unless I know of a bad spot that may slow the unit.
2006 KENWORTH W900 (A60736)
2006 KENWORTH W900...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
2016 Chevrolet Tahoe SUV (A60352)
2016 Chevrolet...
2018 CATERPILLAR 304E2 CR EXCAVATOR (A62129)
2018 CATERPILLAR...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
