stupid question - bucket removal
/ stupid question - bucket removal
Interesting, maybe i'll try that. I'll also give the dealer a call about the bend in the arms.
Here are some pictures I took today. I can get the bucket on with no trouble, and I can get the bucket off if I try right after putting it on. But once I do anything with the bucket, the arms are stiff/locked in place. The pictures are right after putting it on.
/ stupid question - bucket removal #42
take your bucket off and look at the end of the rod with the levers down and see if they have worn a lip into them from using the bucket. Another thought is, when you are using the bucket, it must be putting extra pressure on the release rods which is why you can get it off right after putting it on and maybe if you use the loader to push down on the tip of your bucket before taking it off will help?
also looking at those pictures, you might want to grease those pins up with some Moly grease. The xj2025 SSQA has zerks
/ stupid question - bucket removal #43
That has to be the LAMEST thing ever! How could those bent arms ever get past any Dealer? They must have had a pimple-faced trainee beating on those handles with a sledge hammer.
If your Dealer is not willing to make that right immediately then find another one pronto. Disgraceful!
/ stupid question - bucket removal #44
chsdiyer, as someone else pointed out, your latch arms are bent too much towards the front of the tractor. They should be parrellel to the backside of the bucket. I think you need to also check the workings where these latch arms attach to the latch pins. Something is not right. I switch between my bucket and fork lifts frequently...several times just today. This procedure should work easily without any strain on equipment or operator.
/ stupid question - bucket removal #45
The position of the handle has little to do with the ease of moving the pin. The pin is controlled by the hinged lever with spring assist to hold it in the fastened position. That hinge doesn't know or care what the position of the handle is in.
The OP has already stated that it unlatches with little resistance on his forks. So the problem is in the matching of the SSQA frame and the bucket frame. Maybe the bucket isn't built right? How about dropping the bucket off the FEL and then using an angle finder measure the angle of the SSQA frame face at the left side and then right side and see if they match? A difference will tell you the bucket is built twisted.
If you have a smart phone you can download an Angle Finder App that will provide the tool for this measurement.
/ stupid question - bucket removal #46
A further comment. After studying your pics it's obvious you have no way to grease the pins. My pins slide thru a sleeve with a grease zerk. Keeping them greased helps. You might try some type of dry lubricant such as a Teflon based spray.
/ stupid question - bucket removal #47
Have you tried lubing all the linkages. From your pics in post 41 I don't see any grease or lube on the pins.
/ stupid question - bucket removal #48
chydiyer, below is a diagram of a LS QA. Please note that the bottom of the latch pin is beveled and should be facing directly 180 degrees to long horizontal axis of the bucket. If the entire latch handle/latch pin assembly is turned too much to one side (as could be the case from looking at your picture), then the latch pin is having to be forced into the slot against an unbeveled edge. If the entire assembly is correctly positioned except for the handle being bent out too much forward (which could also be the case from your picture), then you are having to apply too much force because the force is not true to the point of connection of the latch handle and the latch pin link/pin. Both the QA and the bucket, and most implements for that matter, are designed to have some side to side and up and down play. I guess your bucket, QA, or both could be sadly out of whack, but I truly believe the problem is with the latch assemblies. I also agree with other posters....you need to get some lube on all points of contact. Looks like your bare metal to bare metal.
/ stupid question - bucket removal #49
His pins appear to fit the bucket tabs very well. The fact that one unlatches fine and one does not indicates a slight misalignment. This is probably in the construction of the bucket based on the fact his forks work fine.
/ stupid question - bucket removal #50
His pins may fit the bucket a little to tight making it difficult to unlatch.
Most of my SSQA attachments I have gotten over the years have required some grinding where the pins latch into it for smooth latching/unlatching.
/ stupid question - bucket removal #51
By design the pins tighten every chance they get. There should always be downward pressure on the pin by the compression spring.
/ stupid question - bucket removal #52
Don't ever take the bucket on or off at waist level. I was putting mine on at waist level and it came off the mounts. OUCH !!!! five broken toes and a lot of tissue damage.
Hope you heal up fine. I'd recommend investing in a pair of steel or composite toe boots.
I tried greasing the rod a bit but that didn't help. Trying to find some teflon spray to give that a try as well. I've tried pushing the bucket down on the ground to take some pressure off the pins, but that didn't help either. Since there is a recall and they'll be coming to get my tractor at some point, the dealer said they could look at it at that point and see if they can't offer some help getting this resolved. Thanks for all the help here!! When I finally get it working right, i'll post what the solution was. Hope everyone had a merry Christmas and a happy new year!
/ stupid question - bucket removal #54
Dealer needs to "DO" not "TRY". Your Dealers job is to represent your tractors company and "Repair" any problems or defects. Am I wrong? I would certainly not let them off the hook with such an obvious problem. Also, have them prove to you that it works properly before leaving their lot.
/ stupid question - bucket removal #55
Spraying it with Fluid Film worked great for me.
/ stupid question - bucket removal #56
I discovered Fluid Film about 4 years ago. It is truly the best I’ve found. It has become my “go to” lube.
Doofy - The dealer I bought from is not likely to be the dealer who is handling the recall so he might be let off the hook in the end.
I'll be heading to Lowes to get some of this fluid film and see how that goes. Thanks for the recommendation.
/ stupid question - bucket removal #58
Good Luck. I found Fluid Film at my local NAPA and it was also recommended by other forum members. I plan on using it for keeping my snow blower auger and chute slick for better distance and fewer clogs.
/ stupid question - bucket removal #59
I agree that the handles look out of whack, but perhaps it is an optical issue from the camera used to take the picture. Could it be as simple as too much paint/powdercoat in an area causing the binding?
/ stupid question - bucket removal #60
Fluid Film is a great product, just make sure to shake it well before using.
Lot of (15) Hedge / Black Locust Posts (A66408)
Lot of (15) Hedge...
1992 International 8200 Spreader Truck, VIN # 1HSHEDPN2NH418329 (A65563)
1992 International...
John Deere 148 Loader with Brackets (A65640)
John Deere 148...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
Loader Brackets (A65640)
Loader Brackets...
John Deere Zero Turn Lawnmower (A65579)
John Deere Zero...
