Neighbor Tractor Accident
/ Neighbor Tractor Accident #61
Not a farm tractor, an implement of agriculture designed to be operated primarily in a farm field or on farm premises, or an electric personal assistive mobility device:
Aaron Z
Hmmm... sounds like just because we were told this all our driving lives, it may not actually be the law.
:tractor::steeringwheel::confused3:
/ Neighbor Tractor Accident #62
I wish people driving trucks and cars on country roads would just heed the advice of my avatar :D
/ Neighbor Tractor Accident #63
That is a great name for my E-Gator! The Electric Personal Assistive Mobility And Rural Operations Logistics Device.
/ Neighbor Tractor Accident #64
I'm a bit surprised that rear view cameras are not mandatory where the driver can't see behind. We run one on the grain cart but have trouble with the cable to the tractor getting damaged and lose connection. It's great when it's working but really hairy making a left turn when you can't see behind the cart. I, like others, will gradually pull over to the center of the road so no one can pass during the run but even that is a bit scary.
Having said that, a previous operator on this 8420 Deere pulling the grain cart was hit by a passing semi when attempting a left turn. It took the left front clean off the FWA. Luckily no one hurt.
/ Neighbor Tractor Accident #65
I thought of that. The cameras that is. How could you ever enforce that. As it is now, the ONLY requirement here during daytime is to have a SMV sign. Yet you see old bent,. faded signs hung on with a crooked piece of rusted wire! Like, a shiny new sign, properly mounted is just too much for some.
/ Neighbor Tractor Accident #67
People wanting mandatory lights and cameras, are you volunteering to stand out in the field and connect them every time wagons are switched?
We still do things in an older fashion, a two row pull type chopper chopping into wagons. Two or three tractors an people hauling and unloading,
one person chopping, the road portion of the haul may be less than a quarter of a mile or up to 5 miles, when we get to the long haul (5 miles)
even taking it easy with the chopper I can stay ahead of the haulers, in corn that's a load every 15 minutes which means a wagon getting dropped
and another hooked up every 15 minutes. How long would all those lights and connectors last and then especially when opening up fields with brush rubbing
along the sides of the wagons or when I split a field stalks rubbing both sides of everything. The complete and total waste of time because people don't
see and realize what that SMV means or just don't care, we moved to the country and you will accommodate and change to suit us? Kiss my ***
Update from my sister who took the pictures I posted. Neighbor had pulled out of his driveway and was driving 100 yards down the road and turning right into his storage field. Truck, for some reason, swung right into the ditch and hit the tractor which was already on the drive into the field. Unknown whether trucker saw a vehicle coming from the other direction and swung into the ditch to avoid a head-on. Both drivers were in shock at the time. Neighbor only remembers going out to get 2 bales for his animals and being banged around in the cab. Sister knows tracks of truck going through ditch to point of collision on the drive into the field. Neighbor is physically okay but mentally in a turmoil. It appears he was in the right, the truck driver was driving too fast, but yet he is 91 years old and the DOT had already misinterpreted the accident when my sister arrived. They assumed he had turned left in front of the truck. My sister pointed out the driveway where he had entered the highway, the distance he had driven, and the right turn he had made never crossing the opposite driving lane.
/ Neighbor Tractor Accident #69
Perhaps some of us would like to make sure you aren't making the papers next week Lou. We all need to learn from this and be as safe as we can.
If you are out on a rural road that gets very little traffic, I can really see your point. Otherwise better make sure all your equipment works and is hooked up when some
texter destroys your silage cart and rolls your tractor. Otherwise they'll make it into your fault. We've had two road mowers locally hit in the last year, one not far from my house.
If you don't pull over once in awhile, don't know how anyone can expect folks backed up behind from not doing stupid things.
People aren't patient, plain and simple.
/ Neighbor Tractor Accident #70
I hear you. But the issue of SMVs and regular vehicles using the same public road ways is a REAL problem. And the Blame goes both ways. Government has acted on much less serious matters. Like the STUPID School Bus laws for instance!
/ Neighbor Tractor Accident #71
Thanks for the update. Totally different scenario.
Once the truck driver had made the error of approaching the tractor at too fast of speed, he did the right thing and tried to miss the tractor. Would have been much worse had he not. I'm guessing when this course of action was determined the tractor hadn't committed to the turn yet. Truck driver thought he could avoid hitting the tractor in the rear end by shooting past him on the right.
Bad situation. Very good end results.
/ Neighbor Tractor Accident #72
Good thing your sister arrived and straightened things out, or the old guy might have been held responsible. Anyhow, glad they aren't physically injured. Could have been much worse.
/ Neighbor Tractor Accident #73
DANG, I thought that I had another reasonable argument to myself not to have a cab tractor, with those dangerous fogged up windows.:laughing:
/ Neighbor Tractor Accident #74
Nope, but I do have to run the AC if I'm in the tractor for a few hours or the windows will fog up.
Terrible the things I'll do to stay comfortable. :laughing:
/ Neighbor Tractor Accident #75
What is Indiana's definition of a motor vehicle in regards to this law?
IC 9-13-2-105"Motor vehicle"
Sec. 105. (a) "Motor vehicle" means, except as otherwise provided in this section, a vehicle that is self-propelled. The term does not include a farm tractor, an implement of agriculture designed to be operated primarily in a farm field or on farm premises, or an electric personal assistive mobility device.
(b) "Motor vehicle", for purposes of IC 9-21, means:
(1) a vehicle that is self-propelled; or
(2) a vehicle that is propelled by electric power obtained from overhead trolley wires, but not operated upon rails.
(c) "Motor vehicle", for purposes of IC 9-32, includes a semitrailer, trailer, or recreational vehicle.
Aaron Z
Aaron, Hmm. I interpret the statute that you quote differently. Para (b) of IC 9-13-2-105 c expressly expands the definition of "motor vehicle" to include "a vehicle that is self-propelled" for purposes of IC 9-21, which is the section MossRoad cited.
I think it's pretty clear that tractors, as well as an "electric personal assistive mobility device" (whatever that is) would be required to pull to the right if three vehicles are backed up. No?
/ Neighbor Tractor Accident #77
I think the farm vehicles ought to have as much safety gear as is reasonable, that said truckers and autos need to get off their phones, get their heads into what they are doing and look for possible farm vehicles driving slowly and making RIGHT turns on country roads. This trucker sounds to be the problem.
MHarryE,
How did the initial report get to be so wrong, was it the cop’s version after talking to the trucker? Thank God for your sister!
/ Neighbor Tractor Accident #78
I had missed that section C expanded the definition for 9-21, you would appear to be correct.
Regarding section IC 9-21-5-7, it says that the slow vehicle "shall give right-of-way to the other vehicles by pulling off to the right of the right lane at the earliest reasonable opportunity and allowing the blocked vehicles to pass"
If one had a creative lawyer (and cooperative terrain) it could be argued that wasn't a place where you one could safely pull off to the right due to the width of your load, oncoming traffic, a shoulder that was too narrow, the dropoff from the paved shoulder to the gravel and/or a curve that obstructed the view of oncoming traffic making it dangerous (and as such, not reasonable) to pull off to the right.
Aaron Z
/ Neighbor Tractor Accident #79
In my area very, very few State roads have a shoulder that's useable. Maybe 10%.
/ Neighbor Tractor Accident #80
Aaron Z
The way I read it, you were correct in that the farm tractor wasn't considered a "motor vehicle" in the description... but then later on it just said "vehicle", not "motor vehicle", and I'd bet there could be some more creative interpretation of the wording in that one, too. :laughing:
Anyhow, around here, its always been construed to mean anyone in anything driving on the road and holding up traffic to the tune of 3 or more vehicles behind you, is supposed to pull over at the first safe place and let the faster traffic pass before continuing on their way.
That would be hard to find a safe place to pull over with the size of some of these harvesting machines, as some are wider than the lane and most of the shoulder combined.... combined... combine. That's a joke son. Do you get it? Combine. Farm equipment. My apologies to Foghorn Leghorn.
It's also just recently become law in Indiana that on a highway with more than one lane in a direction, slower cars have to move out of the left lane and let faster traffic pass, and here's the kicker, no matter how fast they are going! So if the speed limit is 55 and you're in the left lane going 65 and some guy comes up behind you going 66, you have to, by law, pull to the right and let him pass at the first safe opportunity. Only exceptions are, as I recall, if you're going to be turning left soon, or inclimate weather. I love this law. Where's the heart shaped emoji? Cloud 9 will do.
:cloud9:
Jitter Bug (A62613)
Jitter Bug (A62613)
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
2010 GREAT DANE SUP-1114-31053 T/A REFRIGERATED TRAILER (A59914)
2010 GREAT DANE...
CHANDLER 10' STAINLESS STEEL FERTILIZER SPREADER (A64277)
CHANDLER 10'...
