Oil & Fuel Kubota DEF
/ Kubota DEF #1
BillySunday
Aledo, Texas
Kubota M5-111
I bought a new Kubota M5-111 that now has 480 hours. I got a DEF WARNING time clock lite that said my tractor will go to 1/2 idle then to 10% power. I drained the Kubota DEF and then bought new DEF with a manufacturing date that read the DEF is 3 months old. Still the clock ticks down. I finally called the dealer's service department and was told this is a common problem and I have to bring it in. Their computer said it is a sensor inside the system and the whole thing has to be replaced. Several thousand dollars but warranty will cover the cost. A month later, still in Kubota's shop. Has anyone else had DEF problems with any Kubota product?
/ Kubota DEF #2
I think DEF causes problems in general for everybody and all manufacturers. Too many sensors, too many parts, too many computers to go wrong.
/ Kubota DEF
I totally agree with Mikester. No way do I blame Kubota. For 50 years we have bought equipment from Japan. Never a problem until this DEF issue. That's why we drive a Corolla, Camry, 4-Runner, and GMC Duramax. Politicians did this DEF to our equipment, not the equipment manufactures. I had a Kubota engineer in Fort Worth, Texas want to follow me home to observe me using my Kubota tractor so he could look for ways to improve their products. That is how much Kubota cares about their customers.
/ Kubota DEF #4
I have a neighbor with. M6-131 he has had 14 months. Last winter he had a DEF light problem. They came out, drained the DEF (it was the DEF that came with the tractor) and he had no problem - until this winter. Now we are having the coldest period I can remember in ages. It was -42 actual temp yesterday morning for example. Starting when our temperatures have been below zero Fahrenheit he has been having DEF problems again. It has 386 hours. His invoice doesn't have anything special about the DEF written on it but they did change all the fuel and oil filters and oil (his request - Jerry is 91 and doesn't do much of his own maintenance anymore). When you mentioned your DEF problem it sounded so much like Jerry's experience.
I have a M7-171 I got during this past year. I've had no DEF problems. I used Peak Blue DEF, first having the dealer send the fluid they recommended, later buying it from the local farm store (dealer is 150 miles away). Only thing is my M7 sits out the winter unless we get a real snow where I will need its size. It hasn't run in a day when the morning template been below 20 but the computer on the KVT takes control at cold temperatures. The transmission needs to be warmed up and that warm up time will also give the DEF heater time to melt DEF. I believe my book says if I use DEF faster than the heater can melt it the system will limit power until it can catch up.
/ Kubota DEF
Thank you MHarryE for the response.
/ Kubota DEF #7
Diesel exhaust fluid
/ Kubota DEF #8
While I don't have a Kubota that uses DEF, we have Detroit Diesel's, Cummins and Ford Powerstrokes that do their best to bankrupt you with emissions and DEF related problems. And another company I was working with the other night has a brand new Mack that got towed on it's third night at work.
Thanks EPA!!
/ Kubota DEF #9
:thumbsup:
Thanks EPA!!
:applause:
/ Kubota DEF #10
I think the EPA's goal is to have everything electric. No gas or diesels at all. It will be interesting to see how that works out for them.
/ Kubota DEF #11
It's very easy to blame the politicians for the DEF debacle, but let's not forget that they only do what will get them re-elected. There are lots of folks in this country who have demanded that politicians pass stricter clean air laws each year, and as a result we're saddled with tougher regulations every year. Up until recently, diesel manufacturers got along ok, but now with DEF they've hit the wall. You just can't run an efficient diesel engine with all the sensors and stuff that are now loaded onto them, which I believe is why companies such as UPS are going back to gas engines for their delivery fleets.
/ Kubota DEF #12
Personally, I never thought I would see the day that we would put the people in charge of the motor vehicle department in charge of our healthcare.
/ Kubota DEF #13
I think every mfg has had some form or another of problems with final tier IV. But I am curious to this complete system replacement that I have heard/saw others mention on Kubota's. Who are the other tractor mfg's that can not repair the def delivery and monitor system but have to replace the whole thing? Not trying to pick on Kubota, nor am I saying it is cheap to work on any tier IV unit regardless of brand...just curious as to why individual parts can't be provided. Or is this practice only done on warranty machines? Best of luck on your tractor repairs.
/ Kubota DEF #14
Such stories make me want to run out and hug my little 32HP Shibaura/Ford 1920 again.
The 1920 is just like me!
Old,.... and simple!
Well.....not really just like me.
My Shibaura/Ford 1920 has been completely refurbished.
Unfortunately, that is not possible for ME!
/ Kubota DEF #15
Its about time someone figures out a delete for Kubota.. I know of folks already doing it on fairly new p/u's
/ Kubota DEF #17
/ Kubota DEF #18
Are there lots of Kubota owners having DEF problems? As DEF is only used on the M5, M6 and M7 series, I do not believe there are a lot of users with those tractors on this forum. My neighbor's 2 problems resulted from contaminated DEF. The originator of this thread had a problem but we do not yet know his problem. My M7 has had no problems. Something that needs to be considered is that DEF usage is so low that we need to be talking about extreme cleanliness due to tight clearances. I know so many running tractors requiring DEF who never have problems. Is there a particular area of North America experiencing problems with their tractors?
/ Kubota DEF #19
BillySunday: Just brought my M5-111 to Kubota shop for the same issue with 250 hours. Waiting to see if warranty will apply.
/ Kubota DEF #20
M5-111 has been in the local Kubota shop for five weeks. Initially told the DEF was bad even though it was just changed and from the original fresh clean original container. I did find on the web that one can purchase bade DEF, however. I was also told that the regeneration system was clogged from improper regeneration. I do not know how this could happen as I follow the procedure exactly from the Kubota manual (a copy is kept in the cab of the tractor). Anyway, I was told the parts have been ordered to repair the system , and all should be repaired as of last week. No word from them so I stopped by today to check on the progress. Today, I was told it was a malfunctioning light.
I did learn that you can check your DEF with a refractometer ($80.00) calibrated for DEF. This stuff does have shelf life and can be contaminated and shut down your machine.
I am not sure what happened with my tractor, and I am definitely not happy with the service presently, although I hope it is just a malfunctioning light.
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61572)
2025 JMR 72in...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
AGRI-CRAFT STAINLESS STEEL FERTILIZER TENDER (A63291)
AGRI-CRAFT...
2026 Kearney 102"x32' Gooseneck Trailer (A64119)
2026 Kearney...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
CASE INTERNATIONAL 5100 END WHEEL GRAIN DRILL (A63291)
CASE INTERNATIONAL...
