FEL won't raise or lower
/ FEL won't raise or lower #1
EastTxZ
Canton, TX
LS XR4145
This afternoon out of the blue, my FEL hydraulics stopped working. Bucket tilt, third function for grapple and 3 point all still work, but the loader arms won't raise up or down. Sounds like it's trying (straining noise from hydraulics) but no movement. I can't see anything binding the arms. Any ideas? As a side note- I got new stabilizer bar mounting brackets (where it attaches to the frame) from my dealer today. One of mine broke (both were bent) and he told me they came out with a heavier duty version and it really is. Mine was warrantied FYI.
/ FEL won't raise or lower #2
Try disconnecting and then reconnecting the QD’s to your FEL lift cylinders. Can you lower bucket to ground! If so, lower bucket, turn off Tractor and cycle you FEL joystick to all positions to take pressure off FEL. Then disconnect/ reconnect QD’s
Make sure both give you a positive click reconnect. Good luck!
/ FEL won't raise or lower #3
I agree that the QC connection is worth looking at. If you have a chance post a couple of pics of the bent bracket and the new design. thx
/ FEL won't raise or lower #4
Are you talking about the stabilizers on your three point arms? Pictures would be great. I just got a new XR4155HC.
Let us know about you FEL issue.
/ FEL won't raise or lower #5
Is the lever lock engaged or the controller pushed forward into float mode?
/ FEL won't raise or lower #6
If you have remotes check that the valves are in the centered position. Sometimes a remote in the wrong position
can make the relief valve keep the hydraulics from proper operation.
/ FEL won't raise or lower #7
Good point. If one of your remotes has a “detent” position, that could cause your issue with your FEL.
Good luck!
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
2016 DODGE RAM 1500 4x4 CREW CAB PICKUP TRUCK (A59912)
2016 DODGE RAM...
2012 LincolnMKX Hybird Sedan (A61574)
2012 LincolnMKX...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
