L6060HSTC Initial Impressions
/ L6060HSTC Initial Impressions #1
mljenkins
Gold Member
WV
Kubota L6060HSTC
My L6060HSTC was delivered this week, and I have about 5 hours on it now. I figured I would give a rundown of my initial impressions and update as time goes on for anyone else considering such a purchase. I don't do YouTube much so I figured I would basically give a text description of my initial impressions.
It has been extremely cold out so I haven't used the backhoe much other than to toy with a couple minor drainage ditches along the driveway to make sure it works.
The setup is an L6060HSTC, LA1055 loader, BH92 backhoe, 3rd function, rear remotes, wipers, defoggers, and R4 industrial tires.
It took about 2 weeks for the dealer to receive it from the factory and 3 weeks to build.
Initial problems have been leaking loader hydraulic line (from the loader disconnects on the frame to the tractor connections), forgotten defogger switch, steering wheel would lock up when turning, dash showing metric units, and the hood release won't spring back into place. The steering wheel was resolved when I found the grommet that seals the cab around the steering column had come out and was basically spinning on the column and catching on stuff. I put the grommet back in place and haven't had an issue since (although I probably should have put a small bit of lubricant on the grommet where the column goes through it). The loader hydraulic line it has to go back to the shop for as well as the defogger switch. The dash I switched to imperial by reading some other forum posts because it was driving me nuts not to know how many gallons of fuel I was using without doing liter to gallon conversions). The hood release I still need to look at and see if I can resolve or if the dealer will just have to deal with it when it goes back.
Hydraulic line leak (yellow line):
Steering grommet that I resolved before fixing:
Thus far I have used it mostly for loader work and have not had the backhoe off of it. The first couple evenings I used the loader to back drag the area behind our barn where the ground was mud but is has frozen and making it difficult to walk on for our horses. I used the backhoe for a couple drainage ditches just a few inches deep. I used the mechanical thumb on the backhoe to remove a large rock that was in one of these ditches and causing water to drain down my driveway and create an ice spot (so glad to get that taken care of, never could address it before). Today I used the loader to plow our steep 1000' driveway and I may be doing that again if it doesn't stop snowing.
In the few hours of using it, it has been 20 degrees F or less here, and I have to start taking off my scarf and ear muffs while in the cab. The tasks I have done with it, minus the snow removal, I would have never done when it was this cold out. Honestly the cab was a good investment because I can now work when it is really cold, which is an opportune time to work because when the ground is frozen I do less damage where I am working. When I dug the ditches, I finished the work with the loader and spent more time getting things right rather than just quickly calling it done. I also really like the mirrors on the cab because I can see where my rear wheels are when backing it under my lean to in between things. Also I like the front and rear work lights which are a huge help. I would not purchase the cab without the rear work lights. Perhaps some day I'll make them brighter with LEDs, but after years of not having them, I'm super happy with them as they are now.
Not ever having a cab one thing I immediately noticed as you somewhat lose the feel of being on a tractor, which is good and bad. The bad part of that is to realize where the cab is in relationship to low things like tree branches. Another bad thing is I feel like the tractor is more stable than my last tractor, but it is likely due to being closer to the ground since my last tractor was a New Holland WorkMaster 55 and sat higher. On hills, it feels more like being in a pickup truck and not really feeling tippy. Perhaps it isn't, but it makes me nervous to not even have the feeling since I was so used to that. The other negatives I have noticed is not being able to hear every slight sound, like hitting something with your loader (which I've already scrapped one of the lean to posts on my barn once with it because I didn't hear the initial contact). The obvious good thing is the fact it is a lot easier on your body, and you can pretty much sit things wherever on the sides of you an expect them to still be there when you park it.
The couple things I did notice about the loader joystick are it is a bit stiff compared to my last loader (Ansung on the WM), and the loader lockout I have hit with my leg twice now and locked it out while using it and had to reset the lever. I haven't used the throttle up feature much, but because the tractor is new I reduce the throttle up from the max setting to about 2000 rpm. I have found it handy when I need to raise and dump a load of snow as it speeds things up. My grapple is on order so I can't speak to the third function, but I do think the on/off for the third function is honestly a bit hokey the way they use a strap to attach it to the joystick. If they wanted a switch for that, they should have just put it on the side like back where the loader implement hydraulic disconnect switches would go over on the right.
I traded my last tractor to go back to HST because I have a lot of debris cleanup to do around my property as we moved last year. I thought HST would be second nature moreso than the gear tractor but I've honestly had to readjust to it. I keep wanting to use the HST pedal to increase the throttle and sometimes forget this when I intend to go in reverse (obviously caught after an inch of moving). The hi/lo on the steering column has been pretty convenient when around the house, barn, or cars I can tap it down into low and get a fine control of what I am doing, and then tap it up again when away from anything breakable. The auto hi/lo I have turned on currently, but honestly has not really been that useful yet. The auto throttle I like because I don't have to think about continuing the throttle up/down with the hand throttle, especially since I was used to my floor throttle on my last tractor. I drove a L4060HSTC at the dealer and I thought the HST was a bit jerky, but my L6060HSTC doesn't have this same jerky feel. Not sure why that is, but it could be because I have the backhoe on and my tires are filled, so the weight may help. I did adjust the L4060HSTC hydrostat responsiveness on the dash when I tried it all the way to not be as responsive, but it didn't seem to help. I haven't adjusted it on my L6060HSTC yet, but it seems just fine for what I am doing.
I haven't gotten to use the wipers yet as it is too cold to even try to spit fluid on the windshield. I cycled the wipers once to make sure they both worked but I haven't tried the spray. The defoggers I can't comment yet. I have noticed the cab fogging up after about 10 minutes inside and I make sure the recirculate is off, turn the blowers up a bit higher, and sometimes open a side window for a few minutes. Even below 10F, the cold air coming in the side windows feels good when the heat is on in the cab. However, I can see where in blowing bitter cold snow you would likely want the defoggers, which is why I decided to get them knowing it would be very difficult if not impossible to add them (at least as a factory option) later.
The backhoe is pretty nice, although it's a bit clumsy to get on. It's a bit of a small area and leaves you feeling somewhat trapped between the seat and the controls, especially since I am a bit taller. I haven't had any issues with the controls, and it does everything I would expect it to. I haven't done anything serious as I was trying to break the tractor in gently. The mechanical thumb already paid off as I lived a large rock out of a drainage ditch beside my driveway that was causing issues as I mentioned earlier. In the position it was in, I would have likely had to manhandle it over into the loader bucket which would have been difficult. The thumb was easy to adjust. I have the rubber pads on the backhoe, and that was good because I didn't do any damage to my driveway (despite being gravel) when using the hoe. I've read in the manual the stabilizer pads can be flipped over and it appears so by removing a pin and turning them to the other side, so the triangle is down and you can get better traction if you were in dirt and didn't need to protect the ground. Reaching the backhoe controls from the cab is a bit of a challenge, as I have to open the back window, turn around, put my knee on the seat, and reach out the back window. The backhoe sits further back from the operator seat on the cab model and this is done obviously because of the cab. There is a second mounting plate that is on the backhoe that allows it to sit further away from the tractor cab to make it work on the cab tractor. I haven't tried to get to the loader joystick from the backhoe station, but I doubt it is doable, at least not easily.
One thing I have noticed is a big difference in turning radius on this tractor compared to my last setup. Granted, the front wheels on my last tractor were spaced all the way out, and much larger. I really appreciate the tight turning of this new setup as I think it will help me get around into places I could not before. It keeps me from having to use the independent brake as I commonly had to do on my last tractor when I needed a real tight turn radius.
As far as other oddities, I have noticed the trim on the right side where the controls are does not match up all the way. I thought that was a bit strange. The third function lines could be better protected below the tractor, as expected after reading this thought on many forum posts. The display change switch does not light up when the headlamps are on, which is a pain. Actually I'm not sure the regen lights light up either with the headlamps on. I don't think there is a parking light mode, essentially no headlamps but side lights on. Also the interior dome lamp is dim (will replace with an LED bulb, thanks to a forum post I read on that) and it does not turn on automatically when you open the door (and hence does not go off automatically either).
Trim separation:
Initially I'm fairly pleased with the investment. I bought the setup for clearing debris, so once my EA grapple comes in I hope to put that to the test. It did a fantastic job moving snow today, despite not having a rear blade on. I'm really anxious to get the three point hooked up and try my box blade on it and see how things go. There will be some time before that happens since I need to make sure the backhoe doesn't have any initial issues. I will try to update this thread with any other thoughts as I use it more.
Driveway work today:
Tractor picture in the snow:
I did a lot of research prior to purchasing, and thank everyone that has posted thoughts on the L, grand, and cab models in the past. Likewise there were a few good YouTube videos where folks did a pretty good walk around of the L60 cab models which really helped my purchasing decision in know what options I wanted and which I didn't think I needed.
/ L6060HSTC Initial Impressions #2
Very nice tractor! Hopefully you can work it out to get it just right.
I know if I sunk that much money into a machine, I'd be all over the dealer to make it right.
Thanks. Yeah as much as I put into it I was disappointed it wasn’t perfect but my last purchase was the same way where the tractor went back to the dealer (different dealer) after purchase. I expect it’s probably normal as they likely don’t catch everything with some use.
I wanted HST, 3rd function for grapple, and hoe but I didn’t want to drop much HP especially adding the HST. When I priced it out I just said screw it I’ll go with a longer loan and get the cab since they were doing the 0% for 72. I work on call shifts so I can never guarantee when I can get jobs done so rental never works for me.
I’m hoping the dealer can get it back to me soon after they take it in here in a couple weeks.
/ L6060HSTC Initial Impressions #4
Even when we bought our BX2200, it had to go back to dealer for a couple things. So I know the feeling.
However, I need to brag... our Kubota dealer network (Whites Farm Supply) is excellent, and they have 5 different locations that I could go to get parts and service for the tractor. Which is one of the main reasons why I will always go with Kubota and Whites. I tried dealing with a local New Holland dealer (not going to say their name, but if you Google my locale in my profile, you can kind of figure it out), and no comparison; very unfriendly and their unwillingness to work with me was quite surprising. I guess because we weren't buying a high dollar, large farm tractor... who knows. Whites took care of us before AND after the sale.
/ L6060HSTC Initial Impressions #5
Very nice! The problems with your new machine are minor, in a few months (after they're fixed) you'll forget all about them. And you'll get real fast taking that BH on and off. Just go slow the first couple times, follow the directions in the BH manual, it is easy if you do it in the order they say.
Thanks, I figure that will likely be the case. My NHWM55 I never had major issues with after the first time back to the dealer.
The only thing I have not found videos on is reattaching the three point. The only thing I haven’t really figured out is where the three point sway arms attach. I think it is at the bottom hole right below where the backhoe frame is mounted but there was nothing in the manual that I saw. I figure I’ll likely figure it out once I get there.
/ L6060HSTC Initial Impressions #7
/ L6060HSTC Initial Impressions #8
Have you checked positions on your cab light? One or more of mine have 3 position switches, on, off, and on when door is open. I discovered that I frequently forget to close the cab door when working on an implement and sometimes drive away with my pickup to get parts so mine are all set to always off to protect against drained batteries but I think my L6060 has this function as does my M7.
/ L6060HSTC Initial Impressions #9
Very nice tractor. I am on my second cabbed Kubota grand L and still like these cabbed tractors. Once you take the backhoe off be careful using the loader. With loaded tires alone a full bucket of dense material or a grapple with a big log or stump will make the back end light. I have 800 pounds of juice in the tires and an 1100 pound Gannon boxblade on the three point and that seems to keep the loader counterbalanced nicely. If the windows start to fog turn on the AC and leave the heat on. The AC dehumidifies the air and defogs the windows quickly without using the window defoggers.
/ L6060HSTC Initial Impressions #10
Great write up! Sorry for the issues but they sound small, fixable and just annoying.
I am living through this thread know while I wait for my 4760 :)
Sounds like a great machine you have there!
/ L6060HSTC Initial Impressions #11
Congratulations on the new tractor, I'm in WV as well and just recently traded my L3940 with BH92 backhoe and loader for a new HSTC6060, I got the LA1055 loader with 3rd function and 3 rear remotes.
I have hardly used my backhoe for the last few years so I decided not to go with a backhoe on this tractor.
I replaced the work lights with LED light bars and upgraded the headlight bulbs to LED as well, it makes a BIG difference and provides so much more light.
I've attached a pic of what I did with my 3rd function switch as I did not like it mounted to the lever with the clamp either, my switch was actually bad and the dealer gave me a new one to replace and I decided to drill a hole and mount it as pictured...
The middle part of the switch does nothing. It's like the switch was intended for the tractor to have a door sensor, but it doesn't. The manual just says on/off and from reading other posts and videos, apparently the new grand series does not have a door sensor. I definitely see myself tinkering one of these days to add a sensor :)
Thanks for the tips. I honestly never thought to turn the AC on, I do that all the time in my truck to defog the windows. Great tip.
The back tires are filled on the Kubota. I never had a problem on my NH WM 55 (all tires filled) with what I do, but I think it was a little heavier than the Kubota grand series. I have a 750# box blade I'll likely have on when the backhoe is not on there or my Woods rotary cutter that weighs 500#. I have quick attach forks on order for this tractor from EA, as what I used to use was bolt on forks. I wanted the extra lift capacity of real forks since the tractor has I think slightly less lift than my last one. Occasionally I will purchase a ton of something (usually horse bedding) and need to get it off the back of my truck, so I am hoping it can do that safely without the backhoe and just the blade on the back. Of course all that is on the flat. The grapple is what worries me the most since I will be in the woods usually on the hill, but I figure if I just keep the load low to the ground and not over do things I should be fine.
/ L6060HSTC Initial Impressions #14
I added LED interior lights and wired them to the unused position on the interior light switch, I can use these or the factory light.
/ L6060HSTC Initial Impressions #16
@SteveCornell - that big light bar across the front of your cab - did you just remove the factory lights and then install a lightbar - or is there more magic to what you did?
And - what bulbs are you guys using to replace the "bulbs" in the headlights with LED's?
Apparently I have to start ordering a bunch of this crap to make mine all fancy like you guys when it comes in :)
First, nice setup. Awesome to see someone else in WV with the grand series tractor, let alone a cab. When I was shopping it seemed the grand series were rare to be seen. Does the LED bar on the front add any light on the side? I always thought about putting rock/puddle lamps on my last tractor as one of my pet peeves is not being able to see the tires at night. The current cab lights on the Kubota are at least bright enough to dimly light where the tires are running.
I notice you are running chains. Have you found you need them? Thus far I haven't had any slippage on my R4s other than when I've had the loader down too aggressive when pushing snow. The tractor seems to be very stable on my driveway which really impresses me because I was afraid of the R1s on my last tractor in the snow.
I love what you did with the 3rd function switch. That looks so much better, honestly looks like how it should be from the factory. My hats off to you for this, and I'll likely do that when it gets warmer. I notice too you have a little bit of separation on the trim like I had mentioned initially, so perhaps that is just normal for these tractors.
Just a few more things I noticed from today's snow removal not related to your post:
Tractor does gulp diesel, the dash says about .5gal/hour which seems about right for where the gauge is. My dealer was kind enough to send it to me with a full tank when they delivered. I haven't even be running it hard. Thankfully the location for fueling will make it a thousand times easier than my last tractor, where the fill cap was on the hood in front of the dash.
The defogger wires on the left rear window keep coming undone when I open that window. It's rather frustrating. I tugged on the wires some today again to try to get some slack, but I'm afraid to pull on them too much as I don't know what is above in the cab liner that I could break.
The mirrors are so nice to have. Saves a lot of turning around to look back. I noticed the mirrors are spring loaded so they would break away if you tap them on anything, which is really nice.
I realized if I use the 15 degree seat tilt and tilt to the right and lean out the back glass, I can reach the backhoe swing lever without turning all the way around in the cab. I have been swinging the hoe to the side when I park it because it is parked under my lean to where half of the lean to is tractor space, and half is the horses' run in spot. There is a gate between the horses and tractor space, and when I first got the tractor and parked it there and came back inside, I saw them out the window trying to figure out what was there. They licked the hydraulic cylinder and of course that iced over. I am surprised they didn't end up like Ralphy as cold as it is.
It was 4 degrees this morning when I started it. No issues, I let it run for about 10 minutes while my wife and I cleaned the barn. I'd like to play with the backhoe, but it is 10 degrees F outside right now, and I wave the white flag when it is below 20 F when it comes to outside work for long periods.
The tractor seems to have some sort of magical spell over the weather. Every time I clear the driveway, about an hour later it starts to snow. My mother in law told me to stop plowing the driveway because she's sick of the snow. Honestly if I had the rear blade on, I wouldn't care. But the loader is tearing up the driveway with no help from me since I'm still getting a feel for the loader. If it keeps this white stuff up, I might have to give up and drop the hoe and put the three point on.
Matt
I have a 60" grapple for mine and sometimes wish I had went with a 48", the 60" sometimes is to big in the woods
Wow, glad I got the 60" instead of the 72". Travis from EA cautioned me on that.
/ L6060HSTC Initial Impressions #20
Answering somebody else's question, but... http://www.tractorbynet.com/forums/customization/376458-let-there-light-l4060-light.html. I replaced ny front cab halogens with a LED bar & put in a rear LED bar. I went way overkill on the wiring on mine. Disconnected the stock lights, abandoned their wiring & put in my own overkill fuse/relay box in the roof.
I agree with the sentiment of needing rear lights, but the factory lights suck. The rear light kit is litteraly 1 switch & the 2 light housings. All the wiring is already ran. Just pop the B pillar trim, find the socket for the plug, put the trim back on, stick the plug in, bolt on & plug in the lights. If I were on a tight budget I would replace the stock fronts with some smaller LED pods on the stock wiring. Get your own switch & put similar pods on the rear. If I had a good budget I'd repeat my build, maybe use higher quality, less noisy (RF wise) LED bars.
Edit: also love that repositioning of the 3rd function switch. The stock hoseclamp it to the joystick thing is hokey & easily activated unintentionally. I might copy that. Need to pull that panel off anyway as the dealer didn't plug something in after working on my hydraulics & my front lights stopped working.
(2) 15 Gal Sprayers, 25 Gal Sprayer, Honda Pressure Washer, Wheel Barrel (A64119)
(2) 15 Gal...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
Timberjack 608B FellaBuncher (A62679)
Timberjack 608B...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2004 Chevrolet Silverado 1500 Pickup Truck (A61573)
2004 Chevrolet...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
