B7800 Alternator upgrade
/ B7800 Alternator upgrade #1
SuperDave
Member
Leduc Alberta
Kubota B7800
I just installed the alternator upgrade for my B7800. Everything seemed to go ok despite terrrible instructions. However, there are 2 leads that go under the instrument cluster. One lead connects to the new 50 amp fuse. The other lead goes where???? I started the tractor, and the battery light was on. Has anyone had this problem with the new alternator. Does the 2nd lead (2 wire) attach to something? Any help appreciated.
/ B7800 Alternator upgrade #2
SD - what sort of lights do you plan on adding if any. How many are possible with the upgrade?
Thanks.
I already had 2 utility lights on the rollbar, plan on putting in better headlights and will add a rear facing light on the roll bar as well. The tractor seemed to be fine with the 2 extra lights, but I would like extra light especially when snowblowing my 1 mile driveway in the dark winter days.
How many are possible? I really don't know. I would need someone that is a lot smarter than myselft to answer that.
/ B7800 Alternator upgrade #5
Did you find a kit or piece the upgrade together from seperate parts?
And if you found a kit, may I ask where you found it?
Your local kubota dealer will have the kit. It includes the alternator and all the necessary parts to install it. I found a powerpoint on the web that gives step by step instructions with pictures. The kit was 200.00 canadian. It should allow me to add the necessary lights. If you are interested in the powerpoint, let me know and I can direct you to the site.
/ B7800 Alternator upgrade #8
Kits are no longer available according to several well known dealers (here). Messick's nor Carver's shows the kit in their parts list. It's all in pieces and requires two substitute parts, thus my reason for asking where you may have found the kit.
I would like the PowerPoint file and would really like to find a kit...
Thank you.
/ B7800 Alternator upgrade #11
Anyone still interested in the alternator upgrade kit, you may get it thru your dealer. It is concerned whole goods and the floor salesperson can order it. Just got my kit today $229.00 us. Part number is B7324. Comes complete with all parts. Instructions not worth looking at. Get the power point presentation mentioned earlier in posts.
/ B7800 Alternator upgrade #12
Does anyone have a circuit diagram for the wiring harness?
/ B7800 Alternator upgrade #14
Did you check the links in page one of this thread?
Yes, there are instructions on how to install a kit supplied harness but I need a circuit diagram or the pinouts of the plugs which is what I need to make my own harness as I can't buy it in my country
/ B7800 Alternator upgrade #15
Gotcha.... Can't help w a diagram , there are only 4 wires so it shouldn't be too hard for someone to trace out. I have one in my 7510 but its 0* here. if it warms up, I can try to draw one, but it'll be a while as temps are suppose to stay like this... Keep looking and I'll get back to you when I can...
/ B7800 Alternator upgrade #16
Here ya go. 7800 is the same as 2910
Click For Full-Size Image.
/ B7800 Alternator upgrade #17
I think he would like one with the alternator in it to show the circuitry between the key switch, battery and alternator. The one shown has the Dynamo in it.
David
/ B7800 Alternator upgrade #18
Thanks for the info. I found someone had uploaded the B2910 WSM to Kubotabooks.com a few days ago which had that diagram plus a couple of others that where useful. I also found that the B2410 WSM has a very similar wiring diagram but with the 40A alternator as factory so with those 2 I worked out how to wire it up. I'll upload the info once I get my diagrams sorted, but basically do as follows:
Run a largish (I used 6AWG) cable from the main alternator lug to the starter lug, this is the new main charging output
Run a short wire from each of the 2 aux pins (Top and Vertical pins) to the blue barrel connectors that the dynamo output originally connected to
Cut off the regulator connector as close to the regulator as possible so you have wires to work with (assuming you don't wan't to keep it, mine was burnt so useless anyway), remove the black and red pins since they aren't needed
Get an automotive 12v 4 pin relay and using the regulator plug you cut off wire it up as follows
Connect the Yellow wire (mates with RedYellow on harness) and the Blue wire that you connected to the Top contact on alternator to the common side of the switch contact and also to one side of the coil
Connect the Green wire (mates with WhiteRed on the harness) to the normally open switched contact
Connect the other Blue wire that you connected to the Vertical pin on the alternator to the other side of the coil
Upgrade the 30A slow blow fuse next to the starter to a 50A one if you want or find the 30A keeps blowing
The main issue is that the old regulator put 12V to the charge lamp on the dash (with the other side of the lamp tied to ground) if it wasn't charging the battery, so the lamp comes on to tell you there is an issue whereas the new regulator is designed so that the charge lamp is across the 2 aux pins of the alternator and the Vertical pin is pulled to ground if there is a fault so the lamp comes on.
So by adding the relay coil across the aux pins and the NO relay contact connected to the lamp (with the other side of the lamp still tied to ground) and ACC (+12V when ignition turned on) on the common pin, if there is a fault, the regulator pulls the aux pin to ground which closes the relay and so the lamp comes on. Basically using the new circuit to trip the old circuit
If you don't care about the fault lamp I think you can get away with just connecting the main alternator output to the starter and removing the old regulator and that's it although you may also need to connect ACC +12v to the Top pin on the alternators aux, not sure about though.
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
82" X 18' EQUIPMENT TRAILER (A64277)
82" X 18'...
2007 International 7500 sba Flatbed 6x6 Truck (A62679)
2007 International...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
KUBOTA SVL97-2 (A65643)
KUBOTA SVL97-2...
2022 Kaufman Trailers Trailer, VIN # 5VGFW5035NL009932 (A65563)
2022 Kaufman...
