trailer stake pocket d ring tie down
/ trailer stake pocket d ring tie down #1
2rowequiped
McKenzie,Tn.
Allis-Chalmers D-15 series II
I am looking for the formed stake pocket d ring mount that has the pin under the stake pocket, without the d ring. I need a flat plate to build custom mounts for a side tool box and a cradle for boring rods. I could buy the mount and cut the ring off but had rather start with a fresh flat plate. I have looked on line but have not found any available.
/ trailer stake pocket d ring tie down #2
I've seen the drop in stake pocket D rings. Many trailer mfgs. sell them. But I too have never seen them the way you describe. I made my own out of 1/4" thick square tubing and flat plate then welded on the D-rings. You may have to do the same without the D-rings
/ trailer stake pocket d ring tie down #3
I agree, for the cost of pre-made ones, that you'd still need to chop up, make your own. 1.5x3" box tube is avalible, and fits stake pockets nicely.
/ trailer stake pocket d ring tie down #4
What's the use of these?
/ trailer stake pocket d ring tie down #5
/ trailer stake pocket d ring tie down #6
/ trailer stake pocket d ring tie down #7
/ trailer stake pocket d ring tie down #8
/ trailer stake pocket d ring tie down #9
Most flat beds have the pre-mounted strap jacks. They rarely use chains.
However I have them on my PJ and it sure is easier to pull the chain through. Also going through the side rail chips the paint bad. Also the d-ring is nice and smooth, unlike the sharp edges on the side rail. Once you have a couple of sets you will know why folks have them. I bought mine with the trailer for $20 a set.
Stake Pocket D-Ring | TrucknTow.com These folks seem to have good prices and often have sales or free shipping. Special deals in their news letter too. I got my chains and ratchet binders from them (best price hands down). Excellent service and the actually answer emails and their phone. They also sell American made products. There is a chance they could order you the sets with out the rings or put you in touch with the folks that make them for them.
Good luck
/ trailer stake pocket d ring tie down #10
/ trailer stake pocket d ring tie down #11
Good luck
EXACTLY CORRECT!
I do not have any of these yet, but will get some for my equipment trailer this coming Spring.
If I had D-Rings absolutely everywhere, I would not need these.
Seems like I always want a chain or strap, where there is no D-Ring.
Putting a strap through a stake pocket, or around a rub rail, is a quick way to chafe a strap.
Hooking a strap to a D-Ring is foolproof.
D-Rings in stake pockets just means that you have more D-Rings.
In the grand scheme of D-Rings,.....More, is better!
BTW: A company called MyTee Products sells these stake pocket D-Rings (16,200#,/5400# working load) for $10.99 each, plus shipping. MyTee also sells a package of 4 on E-Bay for $53.99, with free shipping. Others may sell heavier duty ones, but my chains, and straps are all 5400#.
/ trailer stake pocket d ring tie down #12
Much better for chain, or strap hook use.
Nah. I don’t think so at least. I like my chain spools for my chains and the rub rail works fine for straps.
I use chains on my my semi flatbed ten times for every time I use a strap.
Nothing wrong with d rings but there are not needed if you have stake pockets, chain spools, rub rail.
/ trailer stake pocket d ring tie down #13
I would just find the size of tube you need to fit, cut to length, weld a plate on top, drill a hole for a pin. You could probably make a dozen for what a couple premade ones would cost
EXACTLY CORRECT!
Thanks fried1765, I received the Mytee stake pocket D rings from Ebay, that you suggested. I appreciate everyones input, but for me it was better to bite the bullet and razor disc the d rings cuffs off the mounts and make shop wall decorations out of them until my next brain storm. I am mounting an 8 foot weatherguard super low side box on one side of my 20' PJ and making a cradle for 5' long McLaughlin boring augers on the opposite side. I am planning to mount a vise on one of the anchors so it can be removed and locked up when not in use. I wanted to be able to remove toolbox and cradle in the event I need the trailer to move a truck, tractor or whatever!!!!
/ trailer stake pocket d ring tie down #16
I agree. I would find a rub rail far more useful than d-rings in stake pockets. While a 10K lb BS/3300 lb WS strap J hook won't go through a stake pocket, it will fit through a rub rail attached to outside of the pockets. I need to add one to my tractor trailer.
/ trailer stake pocket d ring tie down #17
Rub rails are great. I feel lost trying to tie down without it.
/ trailer stake pocket d ring tie down #18
My Diamond C tilt trailer had stake pockets of different sizes. I just bought six 5/8" D-rings and welded three on each side.
/ trailer stake pocket d ring tie down #19
I find that using tie down straps with rub rails, may allow the fabric strap to rub on the top edge of the rub rail.
I like the idea of rub rails, but not the idea of straps rubbing on rub rails.
Straps hooked to "D" rings eliminate any risk of strap damage.
2017 Chevy Malibu (A61574)
2017 Chevy Malibu...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
2019 FREIGHTLINER CASCADIA CA113DC 6X4 T/A DAY CAB TRUCK TRACTOR (A59911)
2019 FREIGHTLINER...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
JOHN DEERE 8 SHANK CHISEL PLOW (A63291)
JOHN DEERE 8 SHANK...
Doyle Conveyer with Honda Engine (A63688)
Doyle Conveyer...
